第260頁,共274頁 第一第一 ... 160210250258259260261262270 ... 最後最後
顯示結果從 2,591 到 2,600 共計 2736 條
  1. #2591
    名稱:  6107F9A9-3F39-4CC4-81CF-13CA34C90623.jpeg
瀏覽次數: 194
文件大小:  462.1 KB 名稱:  2FC58E87-5658-4F4F-BA81-0D907D93D539.jpeg
瀏覽次數: 162
文件大小:  448.5 KB 名稱:  927EA878-33BA-4813-A64F-4FD0DB6FBEDC.jpeg
瀏覽次數: 184
文件大小:  59.7 KB
  2. #2592
  3. #2593
  4. #2594
    H&K MARK 23
    The HK Mark 23 Caliber .45 ACP pistol gives shooters match grade accuracy equal to that of the finest custom made handguns — yet exceeds the most stringent operational requirements ever demanded of a combat handgun. The Mark 23 provides this accuracy without the need for hand-fitted parts common in custom-built match pistols costing thousands of dollars more. One of the most thoroughly tested handguns in history, the MK23/Mark 23 project originated in 1991 when HK began development for the U.S. Special Operations Command, the organization that directs the activities of America’s most elite military units, including the Navy SEALs and the Army Special Forces. On May 1, 1996, the first HK MK 23 pistols were delivered to the U.S. Special Operations Command for operational deployment, making the MK 23 the first caliber .45 ACP pistol to enter American military service since the venerable Government Model 1911A1. During testing, MK 23 pistols met the most stringent operational and accuracy requirements ever demanded of a combat handgun. Endurance testing demonstrated a service life of over 30,000 rounds of +P ammunition. To meet the reliability requirement, the pistol had to demonstrate a minimum of 2,000 mean rounds between stoppages (MRBS) with both M1911 ball and +P ammunition. All pistols exceeded the 2000 MRBS with an average of 6000 MRBS. In more than 450 accuracy test firings from a precision firing fixture at 25 meters, MK 23 pistols far exceeded the government requirement, averaging 1.44 inches, with 65 groups of less than one inch. There were four groups of .5 inches, with 5 rounds going through the same hole! The U.S. Special Operations Command for operational deployment, making the MK 23 the first caliber .45 ACP pistol to enter American military service since the venerable Government Model 1911A1.
    Features:
    • Buffer system to minimize recoil forces
    • Ambidextrous safety lever
    • Ambidextrous magazine release
    • Separate decocking lever on the left side
    • Extremely corrosion resistant surface coating of all metal components
    • Hard chrome plated polygon barrel
    H&K MARK 23
    HK Mark 23口徑.45 ACP手槍使射手的匹配等級準確性與最好的定製手槍相等——但超過了有史以來對戰鬥手槍最嚴格的操作要求。 Mark 23提供了這種準確性,而不需要定製手槍中常見的手工安裝部件,價格高出數千美元。 MK23/Mark 23專案是歷史上測試最徹底的手槍之一,始於1991年香港開始為美國開發。 特種作戰司令部,是指導美國最精英軍事單位活動的組織,包括海軍海豹突擊隊和陸軍特種部隊。 1996年5月1日,第一把HK MK 23手槍交付給美國。 用於行動部署的特種作戰司令部,使MK 23成為自受人尊敬的政府型號1911A1以來第一支進入美國兵役的.45口徑ACP手槍。 在測試期間,MK 23手槍滿足了有史以來對戰鬥手槍最嚴格的操作和準確性要求。 耐力測試表明,使用壽命超過30,000發+P彈藥。 為了滿足可靠性要求,手槍必須在停機(MRBS)之間至少顯示2000發平均彈,同時使用M1911球和+P彈藥。 所有手槍都超過了2000個MRBS,平均為6000個MRBS。 在25米處的精密射擊夾具的450多次精確測試射擊中,MK 23手槍遠遠超過了政府要求,平均1.44英寸,65組不到1英寸。 有四組0.5英寸,5發子彈穿過同一洞! 美國 用於行動部署的特種作戰司令部,使MK 23成為自受人尊敬的政府型號1911A1以來第一支進入美國兵役的.45口徑ACP手槍。
    特點:
    • 緩衝系統,以儘量減少後坐力
    • 雙手靈巧的安全槓桿
    • Ambidextrous雜誌發行
    • 左側獨立的去孔槓桿
    • 所有金屬部件的極耐腐蝕表面塗層
    • 硬鍍鉻多邊形桶
    此篇文章於 2022-06-08 07:16 PM 被 999369 編輯。
  5. #2595
    名稱:  C7D74C7D-5F10-4CCA-BAFC-4759E0B54D4B.jpeg
瀏覽次數: 180
文件大小:  647.9 KB 名稱:  722192D5-331B-4B4B-9B5E-98CB112F10DA.jpeg
瀏覽次數: 167
文件大小:  707.9 KB
    今槍枝是某些人(槍枝管理法修正案)的熱鬧話題 在怎麼變怎麼改 對我這(己近人生七十才開始的人)無啥可憂慮操心的
  6. #2596
  7. #2597
  8. #2598
  9. #2599
  10. #2600
