第108頁,共274頁 第一第一 ... 85898106107108109110118158208 ... 最後最後
顯示結果從 1,071 到 1,080 共計 2735 條
  1. #1071
    Better Life
    誠實 守信 善心對待做人處事
    有些人自認佔了便宜[不實信]但生命路途上的得失更大。
    希望 人 都能注意更看到這些
    為什麼有些人會能得到 Better Life
    這看到一些老美[或有些人]斤斤計較 總想佔別人便宜,唉![到頭來越來越窮困]
    Why I Have The Better Life !???
  2. #1072
    引用 作者: 999369 查看文章
    其實這台買時就覺得賣方動作怪怪的[不用時就關机],才知道會過熱不想玩了換了一些配件[小賠了一些就當吃了一頓健康海鮮大餐]
    目前不在買東西了[老婆戒嚴令]也夠了
    安全背帶扣是必要的:P
  3. #1073
    引用 作者: DeadHeart 查看文章
    安全背帶扣是必要的:P
    現全部吉他及背帶都裝上了,有三種不同形式
  4. #1074
    說到Strap,The Gear Page也有不少討論,看過幾次發現Moody, El Dorado等較高階的Leather Strap很多人用,還有很多廠牌就是幾乎沒聽過的了。:^)
  5. #1075
    目前不在買東西了[老婆戒嚴令]也夠了
    (sweat) (sweat) (sweat)
    Fender 64 Vibroverb Custom Guitar Combo Amp
    少有的Fender特製 手工裝配真空管吉他音箱 Hard- To -Find
    几乎很難找到[新]二手的電吉他音箱
  6. #1076
    Fender '64 Vibroverb Custom Guitar Combo Amp
    A custom shop reissue of a 1964 classic, hot rodded.
    The Fender '64 Vibroverb Custom Guitar Combo Amp is the '64 with hot rod modifications by "Amp Doctor" Cesar Diaz. ""This is an all-tube, completely hand-wired combo with a solid finger-jointed pine cabinet"" and a 15" speaker for a unique, throaty sound. From the front it appears to be a faithful reissue with all the crystal-clean Vibroverb tones, while the back panel features switches that kick it into overdrive for a cranked up "Texas blues" sound. 2 channels. 50W tube power. Includes a 2-button reverb/vibrato footswitch and cool embroidered cover.
    Features
    • Hand-wired
    • Featuring special circuitry designed by Cesar Diaz
    • 40W @ 8 ohms or 4 ohms (Tube Mode),
    • 50W @ 8 ohms or 4 ohms (Solid State Mode)
    • 2 channels
    • Tube-driven spring reverb
    • Tube vibrato
    • Tube/diode rectifier switch
    • Stock/modified circuit switch
    • 4 -12AX7A preamp tubes
    • 2 - 12AT7 tubes
    • 5AR4 rectifier (switchable to diode with rectifier switch)
    • 2 - GT6L6 GE output tubes
    • All USA-made tubes
    • 15" 8-ohm special design speaker made in the USA by Eminence
    • Solid finger-jointed pine cabinet
    • Black, heavy-duty textured vinyl cover with silver grille cloth
    • Standby switch
    • Extension speaker jack
    • Tilt-back legs
    • Reverb output
    • Input RCA jacks
    • 2-button reverb/vibrato footswitch and embroidered cover included
    此篇文章於 2012-04-13 03:57 AM 被 999369 編輯。
  7. #1077
    Moody 2.5" Luxury Camel Leather Guitar Strap with Cream Leather Back
    下次去買這條來搭配PRS電吉他
  8. The Following User Says Thank You to 999369 For This Useful Post:
  9. #1078
    安全背帶扣是必要的:P
    背帶扣分類三種 Warwick貝吉附有Warwick自己品牌的
    Gibson吉他用電鍍金色按壓式的 其他的吉他[如Fender吉他及貝士吉他]用的是滑入扣式的[電鍍銀色]
    這樣整整弄弄、換來換去也可搞個一天兩天的
  10. #1079
    其本圖中有三種不同品牌或型式的接頭
  11. #1080
