顯示結果從 1 到 10 共計 14 條
    預設 【耳機/耳擴/DAC】Furutech ADL H128, EH008, A1
    ADL H128 頭戴式耳機
    ADL H128是日本Furutech最新發表的頭戴式耳機,共推出三種顏色組合,包括Silver-Black(銀黑)、Silver-Brown(銀咖啡)、Dark Blue(黑藍)。H128來自H118的進化,除了保留H118的平衡、流暢外,進一步在動態、力道有所提升,讓音樂的活生感可以更好,H128的耳罩可將您的耳朵完整的包覆,讓低頻的表現更好,並且讓耳罩裡的駐波與反射減少以減少失真。耳罩上的人造皮革相當柔軟,戴起來相當舒適。H128為密閉動圈式設計,振膜為特別訂制的,擁有高噪音消減與低失真的特性,其使用超大40mm的單體、其磁鐵經過深冷處理,mini XLR母座是鍍銠的,使用非常輕量化、非常特別的銅鍍鋁合金的聲圈。內部的配線採用Furutech的製品,並有附上Furutech Alpha-OCC的耳機線,包括一個Furutech 3.5mm轉6.3mm的轉接頭。
    Features
    •Dynamic closed-back circumaural headphones
    •Furutech designed high noise attenuation and low distortion tailor-made diaphragms
    •40mm extra-large high-flux α(Alpha) Cryo-treated magnet
    •High quality PEEK trembler film
    •Ring betweenvoice-coil and diaphragm keeps ultra-high-frequencies in phase
    •Sturdy vibration damping aluminum headband
    •Excellent transient response from extremely light-weight coils of copper-
    coated specialaluminum alloy wire
    •Furutech nonmagnetic rhodium-plated α(Alpha) cryo-treated mini-XLR socket
    •Included in package 3.0 meter Headphone Cable & F63(G) Gold- plated 1/8”
    (3.5mm) to 1/4”(6.3mm) adapter 1.3 meter iHP-35X high performance Alpha-O
    CC headphone cable terminated with Furutech mini XLR and FT-735 3.5mm stereo connector
    Specifications
    Acoustic Design:Dynamic closed-back
    Driver:40mm diameter special high-flux magnet
    Sensitivity: 98dB SPL (1mW) at 1KHz
    Frequency response: 20Hz ~ 20kHz
    nput Power:200mW(Max.
    Rated Impedance:68ohm @ 1KHz
    Ear pad:Leatherette
    Head Band Pressure:4.5N Approx.
    Connector: Nonmagnetic rhodium-plated stereoα(Alpha) mini-XLR socket
    Weight:280g (9.84oz) Approx. (without cable) 320g (11.2oz) Approx. (with cable)
    ADL EH008 耳道式耳機
    EH008採用雙動圈單體,其中低音為8mm的單體、高音為5.8mm的單體,均經過深冷處理。5.8mm的高音單體為鈦金屬振膜,擁有高解析再生的能力。耳機內部使用了特殊的ABS樹脂,可讓單體穩定的運作,外部則使用了碳纖維,擁有非常好的阻尼特性,另外還加上了一圈橡膠與矽膠,以強化聲音的隔離效果及增加配戴時的舒適性。隨耳機會附上三種尺寸的耳塞。
    Specifications
    Acoustic Design: Dual Dynamic Driver
    Driver: : 8mm and 5.8mm α (Alpha –Cryo treated) magnet drivers
    Sensitivity : 100±3 dB SPL (130mW input at 1 KHz )
    Input Power: 2mW / 5mW (Max.)
    Rated Impedance: 19 ohm @ 1KHz
    Left and right balance: ≦3dB, @ 100Hz and 1KHz
    Connection: α (Alpha)–OFC conductor wire with 24k gold-plated stereo α (Alpha) 3.5mm angled plug
    Weight: 15g (0.53oz) Approx. (cord and plug included)
    ADL A1 DAC/耳擴 (DSD 5.6MHz, Android數位解碼)
    ADL是一台隨身型的DAC與耳擴, 支援DSD解碼(5.6M),其USB Mini-B可連接到PC/Mac進行解瑪播放,並且可以充電,USB-A則是給Android系統使用,透過OTG(On The Go)的線材可直接讓Android系統的手機數位輸出到A1解碼,另外還有光纖與類比輸出,一個3.5mm的耳機輸出。內建的電池可持續7.5小時,充飽電約需5~5.5個小時。
    Specifications
    High-performance CIRRUS LOGIC CS4392K 24bit/192kHz DAC chip (accepts PCM data and DSD audio data )
    Controller supports ASIO and Asynchronous mode
    VIA VT1736 32bit/192kHz USB chip ,USB 2.0 High Speed compliant accepts DSD 2.8M or 5.6M signal & 44.1 /48 /88.2 /96 /176.4 /192 kHz sampling rates supported
    TEXAS INSTRUMENTS TPA6130A2 Headphone Amplifier chip -TPA6130A2 high fidelity Stereo Headphone Amplifier with an SNR of 98 dB
    OP AMP: TI- LME49726 High Current, Low Distortion, Rail-to-Rail Output Audio Operational Amplifier
    Max Headphone Output Levels (at 1%THD 1KHz) : 70mW(12 ohm), 80mW(16 ohm), 65mW(32 ohm), 38mW(56 ohm), 9mW(300 ohm)
    Charge Time: approximately 7 hours approx. (DC 5V, 0.5A USB bus power)
    Charge Time: approximately 5~5.5 hours approx.(AC/DC 5V, 1.0-2.0A switching adaptor)
    Music Playback Time: Up to 7.5 hours when fully charged
    Size: 68(W) x 118(D) x 16.5(H)mm
    Weight: 150g approx.
    仲敏: http://www.geniusloci.com.tw/a2008/index.asp
    ADL: http://www.adl-av.com/
    ADL A1是一台隨身耳擴/DAC,而且特別設計支援Android系統手機,能直接透過USB連接數位輸出給ADL A1解碼,再經由更好的類比放大驅動耳機,聲音當然比直接使用手機聽來得好上許多!
    ADL H128共有三種顏色,耳罩的包覆性很好,具有良好隔音的效果,人造皮革柔軟透氣,重量加上線材僅約320g
    AADL A1的體積就算是女生也能輕鬆的一手掌握,並放在隨身的口袋當中
    H128 Silver-Brown(銀咖啡)版本
    Dark Blue(黑藍) 版本
  6. #4
  8. #5
  9. The Following 4 Users Say Thank You to Leo Yeh For This Useful Post:
  10. #6
    小葉這樣拍不行啦!!
    光圈開太大,細節都看不清楚了!!!!
  11. The Following User Says Thank You to sean333 For This Useful Post:
  12. #7
  13. #8
    根本就看不到耳機啊!!!!!
  14. The Following User Says Thank You to pokilai66 For This Useful Post:
  15. #9
  16. #10
    大家都忽略了器材.................
    魔術勒???
  17. The Following User Says Thank You to 小曾 For This Useful Post:
