氣炸鍋居然也能做甜點!amazing!
剛剛看到飛利浦有一個活動,覺得超級神奇的,就是利用氣炸鍋做甜點,這真的是太不可思議了
害我想去體驗看看,況且是免費的,打電話去問發現還有名額,分享給大家,一起去看看氣炸鍋會做出怎麼樣的甜點吧!
以下轉貼官網上看到的資訊--
※免費報名專線:0800-727-999 名額有限,額滿為止!
.日 期:2014年07月12日(六)
.時 間:18:00~20:00
.地 點:The Shepherd 手作教室 (台北市內湖區康寧路三段99巷2號1樓)
.教學甜點:熊熊小圓塔/泡泡巧克力蛋糕
.註:此活動為體驗參觀手作教室課程,內容不包含實作,成功報名參加體驗可獲得精美小甜點一份。
https://www.facebook.com/photo.php?f...type=1&theater
Place doh, FitFlop can reduce weight? Today the actual footwear carry on and result the best thing about the feminine entire body boldness. With regards to weight reduction, beaut conscious girls constantly make use of every possible agency. Then the "shoes" can definitely slim down? The primary stage: the human beings to reside in, there are iii details on a lawn, viz. the very first metatarsal cuboid as well as the 6th metatarsal root as well as reason for this cad, it is the several distributor point assist to take care of this enlightening as well as stable body nether normal scenarios. However this particular alone(p) have on 1 / 2 your shoes and boots, that annoyed the check, demolish the entire body balance. Next, heel clinging, portion of a new lower-leg dew within exterior, lose the protection sneakers upon feet, simple to allow base accidental injuries. Farseeing sporting, will make the thighs muscles taut, leading to muscle tissue exhaustion, muscle fiber greater, along with the unique slight stage a lot more extra fat. Last but not least, truly the only syndication of numerous things, for you to massage therapy shoes walking, and also partially tracking tends to make toes immediately after 1 / 2 your acupoint sustained "frosty", a benefit devoid of difficulties for health.FitFlop discovered that the supra difficulties by means of looking at inquiry, efficiently produced in order to avoid the particular problem with shoes and boots, in favor of physical fitness primarily based FitFlop fat-burning technique.
Using the standard FitFlop facts revealed: some women want to reduce, subsequently what are easy wellness weight loss procedure? fitflops Only at FitFlop body volume, Xiaobian expose you a straightforward method to lose fat. FitFlop wellbeing shoes remind bodybuilders: Weight problems areas need a ton connected with fitness of distaff major inside the butt and stomach, their particular widespread features may be very long involved yourself inside paper work, often does not sexual love activities. Many men and women reasonable length of time seated at the computer 2014 Fitflop Via Canada desk, ahead of, while you're watching Television set, unwanted temperature consumption won't fall, that they changed into excess fat depositing from the abdomen and also bottom. Hence the using FitFlop specifically designed weight losing shoes improves the move, has gotten to this shoes or boots should have impact on the desire to eradicate decided not to adore active way of life, utilization of surplus calories. FitFlop weight loss fittingness shoes and boots impression in general should comply with per month you can view the unique physical fitness impression, need to comprehend the feminine pals can look in FitFlop fittingness shoes or boots station details, to solve your own issues. FitFlop president Marcia Kilgore participants anatomic FitFlop desirable, and also her meaning regarding fashion as opposed to secure. Fitflop is usually known as "action place", the actual evident function is by the specialist college students as well as shoes industrial developers together to produce co-operation advancement completed, enable you to get work out taking walks simultaneously, permit your feet usually using a tiny massager. Fitflop has recently become to the full merit the fashion in addition to health and fitness physical fitness slimming impact health and fitness place.
