Constellation Audio 新 Inspiration 慕尼黑將亮相
Constellation Audio 即將推出新系列 Inspiration ,包含 PREAMP 1.0 前級、AMP 1.0 Stereo 後級和 MONO 1.0 後級。這次的新前後級將在即將到來的慕尼黑音響展展出,但是這個系列還包含綜合擴大機、唱放、DAC和媒體播放器,這些則會在今年稍晚一點推出。
Constellation Audio 的 CEO , Murali Murugasu 指出 Inspiration 是具有里程碑意義的系列,提供一個獨特的價值給 High-End 用家。用相對溫和的價格提供高性能的表現。擴大機的核心設計來自獨特的平衡橋接電路結構,如同過去的 Reference 和 Performance 系列結合了多個全平衡單端放大模組。
為了確保訊號的平衡, AMP 1.0 和 MONO 1.0 在 Line Stage Gain Module 都有一個 servo 電路,無論輸入訊號來源,確保其為完全平衡的。
規格 :
AMP 1.0
Power Output: 200 W/ch. into 8 Ohms, 400 W/ch. into 4 Ohms @ 0.2% THD+N Bandwidth: 10Hz-80 KHz @ 0.5% THD+N
S/N ratio: >95dB, A-weighted
Inputs: Constellation Direct, XLR Balanced, RCA Unbalanced
Output: 1pr. Binding post/Banana socket/channel
Features: 12V trigger, USB control
Power consumption: @idle = 110W, @full power TBD
Dimensions (W x H x D): 17” x 8.5” x 19”; 43.2 cm x 21.6 cm x 48.3 cm
Weight: 55 lbs.; 25 kg.
MONO 1.0
Power Output: 400 W/ch. into 8 Ohms, 800 W/ch. into 4 Ohms @ 0.2% THD+N Bandwidth 10Hz-80 KHz @ 0.5% THD+N
Output: 2 pr. Binding post/Banana socket/channel
Weight: 60 lbs.; 27.2 kg.
PREAMP 1.0
Bandwidth: 10Hz-100 KHz @ 0.1% THD+N S/N ratio: >105dB, A-weighted
Output = 17 Volts RMS
Inputs: 3-XLR Balanced, 3-RCA Unbalanced Output: 2pr XLR & RCA/channel
Remote Control: Volume, Balance, Home Theater Bypass, Mute, Phase Features: internal power supply, 12V trigger, USB control
Power consumption @50W
Dimensions (W x H x D): 17” x 5.25” x 15”; 43.2 cm x 13.3 cm x 38.1 cm
Weight: 25 lbs.; 11.3 kg.
Constellation Audio : http://www.constellationaudio.com
台灣總代理 鈦孚音響 : http://taifuaudio.turnv.com
The Following User Says Thank You to Ted Chen For This Useful Post:
