第19頁,共39頁 第一第一 ... 9171819202129 ... 最後最後
顯示結果從 181 到 190 共計 388 條
  1. #181
    Mytek Manhattan (DRC, DSD)
    Digital Audio Processor
    Headphone Preaplifier
    Manhattan (DAC、耳機擴大機、前級擴大機)
    雕刻設計上是由世界級工業設計師以獨特的形式呈現,漂亮實用的散熱和電器阻尼。
    雙金屬加工,內部為鋼製的底盤外頭使用鋁合金材質,有助於抑制外部電磁干擾和降低噪音。
    8公斤的質量阻尼衰減震動,隔離並減少機械震動,提供穩定的聆聽過程。
    高功率雙輸出耳機擴大機,零阻抗專用耳擴,不受電源下降或阻抗不匹配影響。
    後面板安裝增益開關,增加耳機的需求和擴大機輸出之間的匹配。
    隔離的類比和數位電源,降低噪聲和干擾,並提高功率及一致性。
    使用自家 C7777 架構的新時鐘,可以測量水平抖動,並適當降低底噪聲。
    可支援高解析檔案, PCM 最高可支援 32 bit/384 kHz,和 DXD 到 DSD 256。
    提供 USB 連接,兩組 RCA , Firewire 。
    “The Manhattan DAC Headphone Preamplifier represents Mytek’s finest achievement. Listening comes first and foremost, from the quality of sound in our designs to our customers voices. In this vein, we created a device who’s look and feel is only surpassed by its sound”
    Construction
    Sculpted Design
    Working with worldclass industrial designers a unique form emerged. Beautiful yet practical for heat dissipation and electrical dampening
    Bi-Metal Fabrication
    The inner steel chassis covered in our custom milled aluminum enclosure helps to reject external electrical interference and lowering noise.
    Elevated & Isolated
    The 18lbs (8kg) mass dampens vibrations, while isolation spikes diminish mechanical vibration providing a stable, artifact free listening experience.
    New Features
    High Powered Dual Output Headphone Amplifier
    Zero impedance proprietary headphone amplifier. free from power sag or impedance mismatch issues typical in lesser headphone amps.
    Variable Gain Headphone Driver
    The rear panel mounted gain switch allows for “gain stage” matching between the demands of headphones and the output of the amplifier
    Discrete Analog& Digital Power Supplies
    Two isolated power supplies power the analog and digital stages separately. Lowering noise and cross talk while increasing power and consistency.
    Femto Clock Technology
    Our new Femto Clock incorporated into our C777 Clocking architecture pushes jitter below the measurable level while measurably lowering the noise floor.
    Highest Resolution Support
    Modern high resolution audio formats support for PCM 32 bit 384 khz DXD to Quad DSD256 11.2 mhz.
    Metropolis Cable Technology
    Mytek’s proprietary cabling Included with every Manhattan DAC Headphone Preamplifier purchase. Cables Include USB • 2x RCA interconnects • Firewire
    此篇文章於 2014-05-21 01:46 PM 被 Ted Chen 編輯。
  3. #182
  4. #183
  5. #184
  6. #185
  8. #186
  10. #187
  11. #188
  12. #189
  13. #190
