顯示結果從 1 到 5 共計 5 條
    預設 賣了上萬台了 Neil Young Pono Music 新的隨身高解析撥放器
    不僅可解高解析,還可直接線上下載高解析音樂
    On the “low end” of higher resolution music (CD lossless, 44.1kHz/16 bit), PonoMusic files have about 6 times more musical information than a typical mp3. With ultra-high resolution recordings (192kHz/24 bit), the difference between a PonoMusic digital file and an mp3 is about 30 times more data from which your player reconstructs the “song”.
    The PonoMusic.com Store uses FLAC (Free Lossless Audio Codec) audio format as its standard, for compatibility, although the PonoPlayer can play most popular high-res music formats from other sources. PonoMusic has a quality spectrum, ranging from really good to really great, depending on the quality of the available master recordings:
    CD lossless quality recordings: 1411 kbps (44.1 kHz/16 bit) FLAC files
    High-resolution recordings: 2304 kbps (48 kHz/24 bit) FLAC files
    Higher-resolution recordings: 4608 kbps (96 kHz/24 bit) FLAC files
    Ultra-high resolution recordings: 9216 kbps (192 kHz/24 bit) FLAC files
    https://www.kickstarter.com/projects...iscovers-music
    http://www.ponomusic.com
    不知道聲音如何?蠻好奇的。
    看过去作工不错的样子
    聽說是Ayre設計的........
    我有預購一台,雖是量產第一批但也得等到十月才能拿到
