顯示結果從 1 到 1 共計 1 條
    預設 【新品】Audeze 將發表兩款新耳機 LCD-X,LCD-XC
    Audeze在出色的LCD-2和LCD-3之後,進而推出兩款新的高端耳機LCD-X和LCD-XC。
    使用場極式技術(Planar Magnetic Technology)。
    LCD-XC有個有趣的地方,是Audeze首次使用closed back的設計。
    LCD-X和LCD-XC使用新的驅動設計,稱為Fazor的技術,達到改善相位響應,更好的聲音延伸,平滑的頻率響應和卓越的成像。並採用了更輕更薄的振膜,造就更快速更細緻的表現。
    兩款產品外觀都非常時尚。
    LCD-X 官網介紹(規格在本文最下方)
    The reference-level LCD-X is an exciting addition to our LCD planar magnetic headphone collection. The LCD-X features a newly-developed and processed transducer made of a thinner and lighter alternative material with new Fazor technology.
    Our patent-pending Fazor elements are unique to the LCD-X and LCD-XC and help guide and manage the flow of sound in the headphone. The result is improved phase response, greater frequency extension, smoother frequency response, and remarkable 3D holographic imaging.
    The LCD-X transducer is specifically designed to work with a wide variety of driving sources. From portable players to studio use, the LCD-X provides high volume without a headphone amplifier even though all LCD-series products benefit from a high-quality amp.
    The LCD-X earcups are made from polished anodized aluminum with sloped ear pads of either premium lambskin leather or a leather-free super-suede microfiber fabric. The earpads are designed with specially-crafted foam offering the proper firmness and acoustic balance.
    LCD-XC官網介紹(規格在本文最下方)
    Our first foray into closed-back design, the LCD-XC has been in research and development for several years. Now featuring exclusive Fazor technology, we’re proud to release the XC, a fully-enclosed headphone with classic Audeze-quality sound for a more exclusive experience in noisy environments.
    Our patent-pending Fazor elements are unique to the LCD-XC and LCD-X and help guide and manage the flow of sound in the headphone. The result is improved phase response, greater frequency extension, smoother frequency response, and remarkable 3D holographic imaging.
    For the purest, most discerning audiophile listening sessions, open headphones remain the favored choice, but our closed-back LCD-XC is the best enclosed headphone experience you’ll find.
    The LCD-XC wood cups are available in hand-worked Bubinga, Purple Heart, Iroki or Walnut. The enclosures are made from precision-crafted anodized aluminum with sloped earpads of either premium lambskin leather or a leather-free super-suede microfiber. The earpads are designed with specially-crafted foam offering the proper firmness and the right acoustic balance.
    The technical specifications of the LCD-X are as follows:
    Style: Circumaural - open
    Transducer type: Planar magnetic
    Magnetic structure: Proprietary self-closing design, acoustically transparent
    Magnet type: High-grade Neodymium
    Transducer active diaphragm area: 39.8 sq cm (6.17 sq in)
    Maximum power handling: 15 W (for 200 ms)
    Sound pressure level (SPL): >130 db with 15 W
    Frequency response: 5 Hz - 20 KHz, usable high-frequency extension of 50 KHz
    Total harmonic distortion (THD): Less than 1% throughout entire frequency range
    Impedance: 22 ohms, purely resistive
    Efficiency: 96 dB/1 mW
    Optimal power requirement: 1-4 W
    Cable length (both): 2.5 m (8.2 ft)
    The technical specifications of the LCD-XC are as follows:
    Style: Circumaural - closed
    Efficiency: 95 dB/1 mW
    官方網站 http://www.audeze.com/
    台灣代理 音悅音響 http://www.hifi.com.tw/adm_root/index.php
    此篇文章於 2013-10-17 11:30 AM 被 Ted Chen 編輯。
