P7 Mobile HI-FI
P7 provides a truly immersive sound, combined with the luxurious comfort and impeccable build quality you expect from Bowers & Wilkins.
Total immersion
With P7, everything is designed to allow you to lose yourself in music. Bass is tight, vocals are precisely defined, and there’s a wonderful sense of space, balance and clarity across the whole frequency range. At the same time, the over-ear design and snugly-fitting ear pads ensure you become completely immersed in your listening. Because when you’re hearing sound this good, you don’t want anything to interrupt your enjoyment.
Speaker inspired drivers
With P7, we have created a headphone driver that works more like the drive unit in a hi-fi speaker, with a diaphragm focussed purely on the job it’s supposed to do: generate sound. Which means a drive unit with a more precise, controlled movement – and a giant leap forward in sound quality.
Daul cavity ear pads
P7’s ear pads feature a dual cavity cushion design that helps the pads mould to the contours of the wearer’s head. This design maintains a consistent volume of air between the drive unit and the surface of the ear at both sides of the head. Not only is stereo imaging enhanced, but the sound is optimised for every listener.
Finest materials
We’ve cut no corners in terms of build quality and our choice of materials. Moving parts and back plates are constructed from brushed and stainless steel, as is the ingenious folding mechanism. The logo plates are crafted from brushed aluminium. The headband and ear pads are encased in luxuriously soft leather, making them a delight to wear even for long listening sessions.
Performance meets design
As Bowers & Wilkins first over-the-ear headphones we were able to maximise P7’s acoustic properties. But we wanted to ensure P7 was wearable and portable, so thanks to an ingenious new folding mechanism using a highly durable stainless steel hinge, P7 folds up like a pair of sunglasses, and comes with a soft-cover carry case perfect for messenger bags or briefcases.
Made for iPhone
P7’s cable comes with a remote/microphone attachment, so it works seamlessly with your iPhone. And because the cable is so easy to detach and swap, P7 is also compatible with all other mobile phones and MP3 players.
Model P7
Technical features Dynamic driver
Nylon damped diaphragm
CCAW coil
Dual cavity cushion
Absorbing wadding
Changeable ear cushions
Detachable cable
Folding (hinged) design
Description Circum aural headphone
Drive units 2x Ø40mm
Impedance 22 ohms
Frequency range 10Hz to 20kHz
Distortion (THD) <0.3% (1KHz/10mW)
Max. input power 50mW
Sensitivity 111dB/V at 1kHz
Inputs 3.5mm stereo mini jack (on cable)
2.5mm mini jack (on Headphone)
Height 192mm folded out, 130mm folded in
Width 190mm
Depth 70mm
Cable length 1.2m
Weight 290g
Finish Real leather and metal
Apple compatibility The remote and mic are supported only by iPhone 3GS or later, iPad, iPod touch (2nd generation or later), iPod classic (120GB, 60GB), and iPod nano (4th generation or later). The remote is supported by iPod shuffle (3rd generation or later).
Audio is supported by all iPad and iPod models.
http://www.bowers-wilkins.net/Headph...7/explore.html
