第4頁,共25頁 第一第一 ... 2345614 ... 最後最後
顯示結果從 31 到 40 共計 242 條
  1. #31
  2. The Following 5 Users Say Thank You to hojuiyang111 For This Useful Post:
  3. #32
  4. #33
    別忘了到極光407房
    搶最新到貨的這張老虎魚最新技術的CD
    The Stockfisch DMM-CD/SACD Vol.1
    More and more music lovers are discovering the unique sound of a vinyl record. We have thought about whether it is possible just to make the sound creation factors of a vinyl record audible. A pressed record however has many artefacts arising from the vinyl pressing i.e. distortion, rumble, groove noise, vertical and lateral aberrations, clicks, etc. and other artefacts that are detrimental to a good sound.Having said that, music lovers have already become accustomed to these disadvantages.
    We call our new production method "DMM-CD". With this solution, we can eradicate the aforementioned disadvantages of the pressed record - and yet still maintain the typical vinyl sound:
    It starts by cutting onto a copper substrate. The sonic imprint of the cut is determined by the complex electronics and mechanics of the cutting facility.Immediately afterwards, we play back the cut using the best possible transfer technology and digitize the result. The Neumann VMS-82 cutting lathe is used in this case as the “original record player". After the cutting process, we leave the copper master on the lathe held firmly by vacuum suction. This way the disc has no vertical or lateral movement, which would affect the tracking of the pick-up stylus. With a pressed vinyl record, this source of error is inevitable. read more…
    Stockfisch-Shop
    compilation track list:
    artist
    title
    album
    A new audio format: the „DMM-CD/SACD“
    Using the best possible components, we play back the signal from the freshly cut groove. The components used are: an EMT TSD-15 Pick-up, a factory built special version of EMT’s legendary Broadcast TONDOSE TSD-15 and incorporates a diamond made from a square natural rod. This diamond is refined with a highly sophisticated shape with multiple facets resulting in a frontal parabola measuring 17 x 25 µ. This diamond quality secures not only very little distortion, but also very low FIM (Frequency Intermodulation Distortion). Moreover we decided to use an EMT 997 pick up arm and a top of the range EMT JPA66 valve pre-amplifier. With critical listening tests, this combination has proven to us to be the optimal chain when it comes to obtaining a sound as close as possible to the master.
    The output of the JPA66 cutting curve equalizer transfers the analog signal to the A/D converter, a "Meitner EMM Labs adc 8 MK IV". This is still regarded as a reference for the best possible conversion to the 1-bit Direct Stream Digital format. The DSD signal is then recorded at a sampling rate of 2.8224 MHz on to our SADiE DSD8 mastering system. Later, on the finished Hybrid-SACD, you will find this true 1-bit DSD layer and also a generated CD format at 16-bit/44,1kHz.
    To enhance the tonal quality of the DMM transfer for the DMM-CD, we cut the music programme at 45 rpm, and basically only use the area between the two zero crossings of the cartridge arm. This is the area where the geometry of the pick-up arm is optimal. However, this decision costs a few copper blanks more, as it reduces the running time per side as opposed to the pressed vinyl LP.
    With this new sophisticated process, a new digital recording media (DMM-CD) has emerged retaining the original sound of a Vinyl-LP but without the unwanted side effects. The DMM-CD/SACD gives you the direct sound of the DMM Copper cut - without having to go through the stages of pressing a record.
    Depending on the quality of your D/A converter, you will experience a new listening pleasure when comparing our "DMM-CD/SACD" with a correspondingly pressed vinyl record. Certainly it will be an emotional decision!
    You can view a short movie about creating a DMM-CD/SACD and about more technical details on the Stockfisch YouTube-Channel.
    LINKS
    INFO
    Die Hybrid-SACDs include a 16bit hybrid layer and can therefore be played on any CD-Player! • SACD stereo sound requires SACD player for playback.
    These releases are available for you in our professional online shopping-cart system. Payable with credit-cards or PayPal - of course via safe SSL connection. Normally orders will be dispatched the next working day.
    up
  6. #34
    第23屆音響大展CD曲目
    1. 韓信拜將 / 韓信點兵
    震撼之鼓,噴薄而出,排山倒海,挟風裏雨。東方鼓魂震地驚天之鴻篇,國韻管弦撥楚釋漢之樂宴...,以中國楚漢相爭的歷史為主軸,透過10首取目來闡明十則歷史故事,主角是劉邦旗下的大將韓信,從他投靠劉邦的韓信拜將開始述說,最後結束於他協助劉邦佔領關中建立漢朝的明修棧道,中間經過霸王別姬、十面埋伏等耳熟能詳的經典故事,透過中國傳統樂器與中國國家交響樂團、中國愛樂樂團、北京交響樂團,以及中國愛樂合唱團與北市大合唱團的合作,打照這張勢力萬均、氣勢磅礡的歷史音樂大作。
    2. 以心傳心 巴哈 / 伊沙易小提琴
    林以信 Joseph Lin,1978年出生於美國,來自台灣的第二代,四歲習琴,13歲進入茱麗亞音樂先修班,2000年以優異成績畢業於哈佛大學,他的成熟技巧及藝術深度,波士頓郵報評為小提琴大師,1996年美國藝術家協會國際大賽第一名,1999年法國Pro Musicis大賽首獎,2000年德國漢諾瓦國際小提琴大賽第四名,2001年紐西蘭Michael zHill國際大賽第一名。他曾和許多的交響樂團及名家如馬友友等的合作,波士頓樂團,新日本愛樂,哈佛交響樂團,及美國.日本各大樂團,包括台灣的國家交響樂團,現任茱麗亞弦樂四重奏小提琴手。他也曾至北京中國國家音樂學院習古琴音樂。本片於2007年於日本東京的錄音。曲目;巴赫及伊沙易的無伴奏小提琴曲,另加一首盛宗亮改編中國民謠“小河淌水“小提琴曲。本片音響效果非常的優秀,音色音場的層次分明,定位場感佳,高低平衡良好。
    3. Moments musicals, D 780(OP.94) - No.5 in f minor : Allegro vivace
    舒伯特:樂興之時/鋼琴奏鳴曲 Channel Classic
    鋼琴彈奏家,Dejan Lazic是七歲習鋼琴,師事匈牙利的Kocsisk大師,一出師即獲得二樣大賽金牌,後來進入莫札特音樂學院薩爾姿深,後來加入萊茵愛樂交響樂團,更與多個名樂團合作,已是年青一代最知名的鋼琴家,本片他彈奏舒伯特的第十五號鋼琴奏鳴曲D960遺作,而本曲可說繼貝多芬奏鳴曲之後最完美的奏鳴曲,另加他的六段小巧的樂興之時,錄音以史丹衛名琴,琴聲優美。詮釋成熟,音效十足。
    4. Vaughan Williams: Fantasia on Greensleeve馮‧威廉斯「綠柚子幻想曲」
    英國作曲家馮‧威廉斯(1872-1958)以合唱曲與交響樂聞名。曲風受印象派與國民音樂派影響,強調旋律,喜好對位與調式和聲,雖然後期作品和聲複雜,自由運用不協和音,基本上仍然有傳統曲式。作品中以九首交響曲(倫敦、南極最著),「G小調彌撒」、「感恩讚歌」、「塔利斯主題幻想曲」、「雲雀飛揚」與這首「綠柚子幻想曲」最受歡迎。「綠柚子」的著名旋律早就流傳名間,馮‧威廉斯在他的劇「戀愛中的約翰」(依據莎翁喜劇「溫莎的風流娘兒們」譜寫)而由女主角演唱此一歌曲,之後再由歌劇獨立出來成為「幻想曲」,曲子由優美和聲的弦樂奏出,中間使用諾福克州民謠,長笛添增效果,最後以主旋律收結。
    5. 陳其蓮美聲歌劇吟唱 歌劇選曲
    陳其蓮出生於中國大連,畢業於瀋陽音樂學院,之後赴比利時進修。曾在比利時黃家歌劇院中擔任獨唱角色,演唱的曲目包括"唐卡羅","玫瑰騎士","蝴蝶夫人"等。 本片中由保加利亞Pleven愛樂交響樂團伴奏,以一系列歌劇大師普契尼名劇中的名曲,吟唱出13首美妙的詠嘆調。 劇情生動出色,非常傑出。
    6. Brighten Spanish Guitar : Albeniz – Tango
    在西班牙,吉他是最主要而普遍的民族樂器。
    雖然吉他多用於民間歌唱與舞蹈伴奏,在嚴肅音樂仍然歷史悠久,大部分重要的吉他名手都是西班牙人,18 世紀的阿瓜多(Aquedo)建立了現代吉他的原則,索爾(Sor)寫作許多優越吉他曲,塔瑞加(Tarrega)則是最偉大的演奏家,他的學生塞戈維亞 (Segovia)更是二十世紀將吉他古典音樂傳遍全世界,並對十六世紀的古代吉他音樂再生貢獻良多。
    隨著古典吉他的復興,與佛朗明哥(Flamenco)舞曲舞蹈密不可分的吉他也隨著許多西班牙佛朗明哥吉他好手推廣到世界各地,當然西班牙與整個拉丁美洲仍是主要重鎮。至於二十世紀帶有電子擴音的電吉他更廣泛流通於民間流行,藍調、爵士、搖滾音樂。
    7. All Rise Together 同心同行
    「愛」是生命起源裡最初的單字,簡單卻又深刻的意涵,道盡了人類所有的情感。
    不論你身在何處,不管你扮演著甚麼樣的角色,「愛」一直隨著你的心跳而存在著。
    人,不只是為了現在而奮鬥,更應該為了未來而做準備。傾聽你心靈最深處的聲音,讓你重新擁有力量去面對未知的世界。
    8. I Wish You Love / 佐藤真由美 演唱
    來自福岡的佐藤真由美,出身柏克萊音樂學院、擁有純正的爵士聲樂訓練和豐富的現場演唱經驗;備受多名傑出爵士樂手讚賞的她,與鋼琴家青木弘武、鼓手 YAS 岡山、貝斯手則是井島正雄三位音樂家的合作,堪稱日本爵士樂壇的年度盛事。這張「你情我願」,是佐藤真由美在千呼萬喚下終於推出的首張個人專輯;她以略微低沉、卻充滿溫暖光輝和高雅醇厚質感的嗓音,演唱了多首經典爵士情歌,在端莊卻閃耀著情感光輝的音樂聲中,飽含空氣感的豐富音調,詮釋出深情又略帶寂寥的美感,完全展現爵士樂的傳統魅力。
    9. HARRY BELAFONTE 貝拉方堤 DANNY BOY
    貝拉方提以一個民謠歌手出身,以他的實力與資歷而言,曾兩度獲邀在卡內基廳演出,是不可思議的傳奇,確實也值此身份。1960年5月2日,卡內基廳最後一季的節目,邀請到貝拉方提,特別為了這場演出排出了全新的演唱曲目,並破天荒邀請了許多當時聲名鼎盛的藝人同台,與他共享盛舉。這場演出使所有聽眾感動異常,卡內基廳也決定不拆除了。同年,貝拉方提鮮活的人聲,及定位清晰的優秀錄音,也實至名歸地因另一場演出的實況錄影,獲得艾美獎。
    10. 「鴻雁」蘇云---女兒情 LP版
    蘇云的「女兒情」(CD版為「驚豔」),是將經典浪漫華語流行歌曲,刻意打造的發燒唱片。名師陳小東在音效混錄下足功夫,所有綠葉正為烘托蘇云的牡丹歌藝.。蘇云具有深厚的演唱功底,略帶磁性的沙啞嗓音,從「女兒情」,「鴻雁」, 「感恩的心」,「愛的禮物」到「一帘幽夢」,不論高亢激昂或低迴婉轉,她都保持赤子純真,沒有矯情忸捏。「鴻雁」是懷鄉曲,隨著雁啼,隨著蘇云的歌聲,雲遊:「鴻雁在天上,隊隊排成行,江水長,秋月黃,草原上琴聲憂傷。鴻雁向南方,飛過蘆葦蕩,天蒼茫,雁何往 ,心中是北方家鄉---酒喝乾,再斟滿,今夜不醉不還。」
    11. 阿朗壹古道 Alangyi Gudao
    「阿朗壹古道」被喻為臺灣海岸的最後一片淨土,蘊藏許多原住民歷史意義的古道。但是,隨著社會環境急速的變遷與開發,「阿郎壹古道」將可能面臨被開採、破壞的處境。因此,我們希望藉由音符及旋律,能讓這美麗淨土的故事繼續傳唱下去。
    12. 台灣咖啡幻想曲 黃昏的故鄉
    本片由西班牙吉他演奏家桑吉特SANGIT PRATS獨立完成及演唱;他出生於1958年西班牙,從小學音樂並彈奏吉他及演唱,他對古典音樂也是非常有興趣的;他在本片中以關心的二首台灣曲調為開頭曲,來作為本張專輯的主打曲。其自由奔放的演唱,保持了我們喜愛的曲調及融合南美的演奏表達方式;其他的曲目更加上他自己的演唱及表演方式,真是一張別具風格的創作吉他曲。
    13. 掌聲響起----國語 / 鳳飛飛 演唱
    鳳飛飛的心意仍然不變。
    她,鳳飛飛,台灣流行音樂史上一個不朽的名字;
    十八年來,她,共在台灣出版了65張唱片(不包括海外),總銷售數量超過1000萬張,可能是國內一個難以動搖的記錄。
    --因著這個記錄,她的歌曲以及她的聲音,成為近20年來台灣社會的集體記憶。
    台灣人心目中的台灣,可能是:城隍廟、擔仔麵、魚丸湯、和鳳飛飛。
    關心社會現象的社會學家或文化觀察者很早就注意到這個「鳳飛飛現象」,他們注意到她容貌並不艷麗,大約式一種清秀的「鄰家女孩」。卻成為演藝界的超級偶像;他們也注意到她的聽眾層極為寬廣,包含不同的年齡、性別、和教育程度。
    她不是某一種人喜歡的鳳飛飛,她實際上是所有人都喜歡的鳳飛飛。
    她自己,即使已經是別人心中的超級巨星,即使唱片銷售數量已經超過1000萬張,她的純樸心意不變──她喜歡台灣,喜歡鄉土,喜歡唱歌,喜歡接觸人群;她一再站在舞台,期待──掌聲響起。
  7. #35
  8. #36
    圓山飯店有很多中國客投宿, 包括她們的高官, 不曉得我們台灣人可以進入嗎? 看到好幾次台灣人, 有的為了爬圓山健身, 有的為了進入該飯店喝咖啡, 而被她們的警察打的頭破血流的畫面, 至今仍心有餘悸, 怕怕 ...
  9. #37
    昨天還有看到很多陸客~~~~
    安啦
  10. #38
    想在週五下午去看音響展,對非聽(看)不可的展示間,小葉兄可有建議?
    若有建議可否分:
    一、黑膠房
    二、CD房
    三、劇院房
    四、軟體房
    五、其他
    這樣可以方便不同類型的發燒友在最有限的時間內看到自己想看的展示間。
    對了,不知道今年在展示範圍內是否有供應吃、喝的?
    謝謝小葉大!辛苦您了!
  11. #39
    哈哈 這個就靠大家分享了
    阿榮沒掛的話 今天就會有很多圖片先看了………………
  12. #40
    呼叫阿榮大!您要撐住,千萬不要掛了。
