Hansen 的單體都是自己設計生產的
KING 有兩25mm顆高音,一顆在前,一顆在後,安裝在6mm的鋁版上
兩顆182mm的中音單體,採多層複合的三明治結構
使用Hansen幾合最佳化的驅動系統
最下方兩顆269mm的低音單元也採用跟中音單體一樣的設計與作法
可看到低音反射孔在下方
整體曲線非常美,也考量的聲學上的處理,例如不對稱的曲線及箱體大小對應了單體
DRIVERS
TWEETER X 2
- Engineered, designed and manufactured for Hansen Audio
- 25mm high performance dome mounted on a dispersion optimized 6mm aluminum plate
- Precision assembled
MID BAND DRIVER X 2
- Engineered, designed and manufactured by Hansen Audio
- 182 mm drivers
- Exotic multi-layer composite sandwich cone
- Optimized geometry "Hansen motor system"
- Hand assembled "Hansen Architecture" frames
- Sound wave deformation prevention
WOOFER x 2
- 269 mm drivers
- Exotic multi-layer composite sandwich cone;
KING為Single-wiring設計,採用WBT端子
所搭配的角錐為德國finite elemente cerabase產品
分音器做了頻響與相位的最佳化,所採用的元件也都是手工挑選
整個分音器也是手工打造
CROSSOVER
- Hansen Audio Enlightened Technology
- Frequency and phase optimized
- Hand assembled
- High grade hand selected components
- Point to point high grade solder connections
