顯示結果從 1 到 5 共計 5 條
    預設 Vienna Acoustics- SCHÖNBERG 美型喇叭
    http://www.vienna-acoustics.com/prod...schoenberg.php
    Providing the ultimate true-to-life sonic experience, SCHÖNBERG will bring the emotion of music to your
    home. Outstanding innovations and inventions transformed the task of developing optimum sound for
    near-wall-applications into an advantage: pure high-end sound performance without compromise.
    The opportunity of an enlarged two-chambered cabinet volume for the drivers provided by SCHÖNBERG´s
    height, together with the system of the prescribed transmission function filter with “outside the driver
    parts,” created a synergy that allowed SCHÖNBERG to evolve into a true full-range system, being able
    to fulfill the demands of high-end audio reproduction with ease. The lower driver´s upper frequency
    output is strategically tapered off as frequency increases whereas the upper mid-bass driver handles
    the full bass range as well as the midrange, thereby taking advantage of its close physical proximity to
    the unique (three-neodymium magnet construction) tweeter for improved integration between the two
    drivers. This complementary driver technology is perfectly supported by the stunningly shaped cabinet
    of SCHÖNBERG; a thoroughly thought-through masterpiece lacking parallel walls, to avoid internal
    standing waves, of remarkable rigidity, curved to optimize both stiffness and resonance control, so
    vital for natural sound. Self-evident is SCHÖNBERG´s precisely CNC machined surfaces, finished with
    the highest grade bead-blasting and transparent anodizing. Its adjustable three-point, spiked stand
    provides for perfect decoupling and stability; developed for placing the speaker close to the wall for
    optimum performance and convenience.
    SCHÖNBERG perfectly spans the sonic requirements for high-end two-channel systems, as well as the
    most sophisticated home theaters, while gracefully integrating into any listening room. Each detail of
    musical presentation is an illustration of our commitment to audio performance bettered only by the
    live experience.
    The opportunity of an enlarged cabinet volume for the drivers provided
    by SCHÖNBERG´s height, together with the system of the prescribed
    transmission function filter with “outside the driver parts,” created a synergy
    that allows SCHÖNBERG to produce especially deep bass response. Dual
    mid-bass drivers, working within a two-chambered system optimized for
    low bass performance, allowed SCHÖNBERG to evolve into a true full-range
    system, being able to fulfil the demands of high-end audio reproduction
    with ease. The upper mid-bass driver handles the full bass range as well
    to the unique tweeter for improved integration between the two drivers.
    The lower driver's upper frequency output is strategically tapered off as
    frequency increases. In this way, for bass reproduction, the larger surface
    area of the combined drivers allows for superior performance, while the
    upper frequencies gain advantage by being produced with the reduced
    surface area of a single driver. The resulting low frequency output is
    robust and unrestrained, yet delicacy and focus is maintained troughout
    the higher frequencies.
    To provide maximum bass capacity with absolute authority, SCHÖNBERG
    features two bass-reflex ports of different lengths.
    SCHÖNBERG features an adjustable four-point stand for perfect decoupling
    and stability. It was developed for optimum sonic results for a distance of
    0 – 40 cm (0 – 15 inches) from the wall.
    To ensure the best possible appearance, the surface of SCHÖNBERG
    is treated with the highest grade of aluminium processing. After being
    precisely machined and CNC milled, all aluminum parts are bead blasted
    and transparently anodized. To maximize internal volume, we profited from
    the stiffness of aluminum to realize a slim walled cabinet. Furthermore, the
    aluminum panels are curved to optimize both stiffness and freedom from
    resonance, which is so crucial for natural sound. This curve means that
    while the average depth of the speaker is 50 mm (2 inches), it reaches
    a maximum point of 84 mm (3.3 inches) in the center of the arch. The
    extra available space in the middle of the cabinet allows for the use of
    physically deeper pure high-end mid-bass drivers. An additional benefit
    of SCHÖNBERG´s shape is the lack of parallel walls, which avoids internal
    standing waves from adversely affecting performance. In extensive
    research we found out that it is vital not to use a single enclosed form
    in creating the box, but to break the cabinet into two separate elements
    connected by MDF, with additional damping strips between the MDF
    and the aluminum, in order to completely eliminate deleterious cabinet
    resonance.
    With our flatspeakers, mid-bass drivers and crossover are created as one
    unit. By using this “outside the driver” concept in creating the mid-bass
    transducers, the crossover follows a prescribed transmission function
    as it relates to the design features of the woofer, which in turn was
    designed with the characteristics of the crossover in place. By designing
    both crossover and driver in tandem, it most efficiently and effectively
    provides an unbelievably rich foundation of bass regardless of the size
    of the cabinet. The results are astonishing, with bass performance of the
    same quality as speakers having three times the inner volume. At the
    same time the maximum acoustic output could be increased by fully 50%.
    Apart from this special filter configuration, the crossovers feature the same
    outstanding development and quality components which characterize all
    Vienna Acoustics speakers. The result for the listener is the pure pleasure
    of full frequency response that posesses a complete sense of ease and
    effortless at any volume level.
    The tweeter is of a completely new design. Three neodymium magnets are
    center drilled, guiding the internal sound waves into a damping chamber,
    which itself is vented again to the outside world for complete control
    of internal pressure. Compression effects are thereby totally avoided,
    and the resonance frequency is lowered as a result with benefits for
    optimizing the tweeter's midrange contribution. The second of the three
    neodymium magnets is a “countermagnet” for total magnetic shielding,
    caused by its reversed magnetic stray-field. This enables the speaker
    to be placed next to any television monitor. The handcoated silk dome
    ensures perfect resolution of highest frequencies, and is protected by a
    non-detachable hexagon metal grille. The voicing of the speaker system
    as whole was accomplished with this grille in place so as to allow for the
    highest resolution with complete protection. A one-point-decoupling and
    mechanical isolation mounting system for the silicone damped tweeter
    cabinet ensures the performance benefits of these features, allowing high
    frequency reproduction of astonishing clarity and precision.
    The silver plated binding posts are placed in the 16 mm or 6 inch wide
    border between the two aluminum walls, allowing it to be isolated from
    the cabinet and invisible to the eye.
    System Type:
    2 ½ way system
    6/6/12 dB Bessel
    Bass System:
    Bass reflex
    Frequency Response:
    40 – 25.000 Hz
    Mid-Woofer:
    2 x 6” VA
    Transparent XPP Cone
    Tweeter:
    3-Magnet Neodym VA
    Ventilated Chamber
    Handcoated 1“ Silk Dome
    Shielding:
    100%
    Sensitivity :
    91 dB
    Impedance:
    4 Ohms
    Recommended Power:
    30 – 200 Watts
    Weight per Speaker:
    13.5 kg / 30 Ibs
    Dimensions (WxHxD):
    10.5x41.3x3.5“
    268x1050x90mm
    此篇文章於 2013-01-17 12:05 AM 被 小余 編輯。
    開箱囉~~~左右聲道是固定的,高音都向內
    此篇文章於 2013-01-16 11:53 PM 被 小余 編輯。
    端子的部分只能用香蕉插或是波浪插
    所以附了一個轉接插方便其他形式的喇叭線使用
    Vienna Acoustics- SCHÖNBERG 兼顧了外型與音質
    相當適合擺放
    在現代裝潢的客廳中!
  6. The Following User Says Thank You to 小余 For This Useful Post:
