第59頁,共103頁 第一第一 ... 949575859606169 ... 最後最後
顯示結果從 581 到 590 共計 1021 條
  1. #581
    引用 作者: jacklu866 查看文章
    twc兄,您太客氣了...指導不敢當
    小弟Reference與High La Musika電源線也才剛插上,正再調整中...有了心得後再來與兄分享:o:o:o
    jacklu866兄,
    您的Millennium LP-MAT是否正快樂使用中...?!:P
    上週您來店當天感謝您的指導~:)
  2. #582
    musk兄,
    Millennium LP-MAT現正快樂使用中:*:*:*
    我還要感謝您讓我感受到Acapella的不同搭配(bow)(bow)(bow)
    引用 作者: musk 查看文章
    jacklu866兄,
    上週您來店當天感謝您的指導~:)
  3. #583
    SONY STR-DA5500ES
    State-of-the-art 7.1ch A/V Receiver with HD sound and DLNA streaming
    HDMI™ 6x in/2x out, 1080/24p upscaling, Digital Media Port
    * Experience digital HD surround effects at home
    * Connect up multiple A/V devices via HDMI™
    * Stream video, photos and music to DLNA devices
    http://www.sony.co.uk/product/hcs-ho...r/str-da5500es
  4. #584
    SONY STR-DA5500ES
    這一台不知道要多少錢喔?
  5. #585
    Sony VPL-VW85 SXRD 1080p Video Projector
    The BRAVIA VPL-VW85 home cinema projector is designed to impress the serious home cinema enthusiast due to the wide of array of Sony’s innovative technologies contained within it. This projector features Sony’s SXRD (Silicon X-tal Reflective Display) panel technology that delivers exquisitely fine-grained 1080p Full HD for a truly cinematic experience. Furthermore, the innate high contrast of SXRD technology is leveraged by Sony’s new Advanced Iris 3™ system to enable this projector to produce a super-high native contrast ratio of up to 120,000:1. This projector also incorporates Sony’s innovative Motionflow™ Dark Frame Insertion system which makes motion much smoother with a method called Double Speed Processing. Eight-stage real-time signal processing by Sony’s BRAVIA ENGINE 2 ensures outstanding colour and visibly superior overall image quality.
    Features
    • High Contrast Ratio – 120,000: 1 with Advanced Iris 3 technology
      The Advanced Iris 3 contrast enhancement works like the human eye, responding dynamically to the level of light in each scene, always selecting the optimum contrast. With a very high range of 120,000:1, Advanced Iris 3 can bring out the detail in darker sequences and prevent bright scenes from looking washed out.
    • Motionflow with Dark Frame Insertion technology
      This technology brings fast-paced, cinematic action to your home. Motionflow with Dark Frame Insertion technology makes motion much smoother through a method called Double Speed Processing. This innovative process creates and inserts artificial frames, first comparing key visual factors on successive frames – for example the position of a car hubcap – then calculating the split second of ‘missing’ action. The optional insertion of darkened frames heightens the contrast and eliminates any judder – by allowing the eye to naturally blend one frame into the next. This action mimics that of actual movie projection.
    • 1080 Full HD SXRD Panel technology
      With three of Sony’s 1920 x 1080 SXRD panels at the heart of this projector, a consistently superior image is produced across the entire screen. The unique combination of three separate panels of 1920 x 1080 resolution (one each for red, green and blue) means that SXRD can deliver over 6.2 million pixels. SXRD provides film-quality smoothness by minimizing the space between pixels (0.25µm) for smooth and dot-less pictures.
    • 3 x Cinema Modes
      In Cinema Mode, films can be viewed as close to the original director’s cut as possible, reproducing details such as natural skin tone, lighting, colour, and contrast.
    • Digital Picture Processing – BRAVIA ENGINE 2
      The unique BRAVIA ENGINE 2 delivers vibrant colours and exceptional image quality. It consists of eight separate stages of image enhancement – carried out in real time – each has a specialised function. Together they generate a picture that is optimised in every way, from the accuracy of the contrast to the precision of the colour reproduction.
    • Panel shift and alignment function
      The panel alignment function allows users to select R (Red) or B (Blue) to make adjustments based on G (Green), and to adjust the horizontal and vertical direction by shifting a full image or each zone from 16x9 points of each colour, achieving the perfect colour registration of the projected images.
    • Anamorphic Zoom Mode
      The VPL-VW85 has an “Anamorphic zoom” mode in the wide modes to enjoy wider aspect ratio. With this mode, it is possible to create a full 2.35:1 image just like a movie theatre when using a commercially available anamorphic lens.
    • 24p True Cinema mode
      This feature allows films to be watched as intended by the director for the big screen, at 24 frames per second.
    • ARC-F (All Range Crisp Focus) Lens (1.6x)
      Projects crisp and beautiful full 1080p HD images right to every corner of the screen.
    • Selectable 11 gamma base line with White/Black Level adjustment
      Flexible user setting for picture quality.
    • Automatic motorized lens protector
      Opens automatically when the projector powers on, then closes up again.
    • Real Colour Processing (RCP)
      Allows you to adjust the hue of a specific colour without changing the whole image.
  6. #586
    聽說鄧董把我幫小高買的香煙看成SACD拿走了
  7. #587
    是用吸的sacd嗎~~~~~~~
  8. #588
    MY-HIEND年度聚餐在HOTTERS舉辦完畢後,我跟小葉站長,就到了twc家中,聽說有好料的可以看。:P:P:P
    影片過年前大掃除,已經所有DVD片下架,現在都是Blu-ray片子了。:O:O
    WD 1.0 TB 存放了很多高解析的影像檔喔!:*:*:*
  9. #589
    什麼!SONY已經躺在地下了!一代旗艦地位已經不在,twc過年前,又換了新的投影機囉!
    當然要來個開箱照!祇不過twc祇留個小箱給我而已
  10. #590
