第2頁,共2頁 第一第一 12
顯示結果從 11 到 17 共計 17 條
    Figure 1 shows how to connect the PurePower and Audiophilleo1/2 together. There is no need for any installations or configuration. Just
    make the following 3 cable connections:
    1. Use the included 12 inch barrel connector cable to connect the AP1/2 barrel connector to the PurePower “AP POWER” connector.
    This connection is shown in green in Figure 1.
    2. Just use a standard USB A-B cable to plug the PurePower “PC USB” connector into any available USB port on your computer and
    charging will begin automatically. This is also shown in red. Note that a Mac may ask you to configure a network device. You should
    do this so that it does not ask it again (While charging using Option 2 below, the PurePower has to configure itself as a USB device in
    order to legally draw 500mA from the USB port).
    3. You have 2 options for connecting the AP1/2 USB port to the PC:
    a. Option 1: Connect the AP1/2 USB port to the PurePower “AP USB” port using the included 12 inch USB A-B cable. This
    connection is shown in red in Figure 1. Option 1 makes connection of the two devices very convenient due to less cabling.
    Note that the “AP USB” port is directly connected to the “PC USB” port and therefore simply passes power and signal
    through to the AP1/2 like an extension cable.
    b. Option 2: You may alternatively plug the AP1/2 USB port directly into the PC as shown in Figure 2. In this case nothing is
    plugged into the PurePower “AP USB” port.
  2. #12
    引用 作者: sayhifi 查看文章
    最近打算购入一个数字界面,听说Audiophilleo还不错,不过M2tech EVO貌似也可以,不知道各位有没有使用的,说下感受,参考下,谢谢了。
    徵求團購者,不知你(sayhifi)是否有意願?
    小余大
    請問有此audiophilleo 1/2 試用心得分享嗎?from psycho's comments?
  3. #13
    引用 作者: edward31 查看文章
    小余大
    我還沒有用過,正在等小余借給我、然後找理由不肯還....:P
  4. #14
    其實我在抉擇到底AP1與AP2在聲音處理上(實際上)有無差異?如果真的只是多幾個功能,出來的聲音都一樣,我應該早就衝了AP2....
  5. #15
    老實說,從CAT的經驗我是『猜』多了螢幕的AP1應該會變差,但是如果實測發現AP1>AP2我也不驚訝,因為看看樂之邦的03 USD與01 USD互比,就知道XMOS或XILINX這種軟體化的硬體是可以『做出市場區隔的』.....:)
  6. #16
    我在本论坛的用家俱乐部已经建立了ap的帖子并发表听感很久了,请大家移步前往。
  7. #17
    引用 作者: CR1972 查看文章
    小弟我在用家俱樂部有幾個問題請教,請幫小弟我解惑
