【空間校正】KRK Systems ERGO Studio Room Analysis & Correction System
使用簡介:
安裝軟體,用firewire插上MAC or PC,接上麥克風跟後級,第一點測量聆聽點正對喇叭中間,之後移開取不同位置的聲音,多少都可以,軟體會顯示讀取房間資訊的進度,最少要超過90%,然後軟體會模擬出空間對聲音的影響,做出校正後將校正資料存入機器,以後接上前級,通過這台機子的訊號都會播放校正後的音樂,之後也不用再接著電腦,電腦只是校正界面的操控而已。
代理商
新麗聲
http://www.sls-music.com.tw
此篇文章於 2012-07-18 08:45 PM 被 AndyChu 編輯。
The Following 4 Users Say Thank You to AndyChu For This Useful Post:
Correct room acoustics with 3D imaging and filters for accurate mixing.
The KRK ERGO Room Correction System brings you close to the acoustics of a perfect room. A great mix starts with a great recording room. But when it comes to achieving the most accurate mix, your room may have the upper hand. Like any room, your studio's acoustics include offending frequencies and room reflections, and none of these help your mix. Getting a handle on these problems has traditionally meant the installation of soft foam or fabrics, which is a great start. But now you can get even closer to a perfect room, and a perfect mix, with help from ERGO Room Correction System.
While conventional room correction systems utilize simple analysis and limited bands of EQ (often fewer than , ERGO uses multiple measurements and proprietary algorithms. This sophisticated room analysis and correction system within ERGO, "RoomPerfect", was developed by Lyngdorf Audio in Denmark after many years of research and development by some of the best audio engineers in the world. It creates a 3D image of the room and then applies 1024 dynamic filters to control the audio environment. This 3D model allows users to preserve the good characteristics of the room, while correcting the bad. It doesn't color the sound or produce an artificially sterile environment, but it does produce a "best" mix for a given room - one that will translate better to other listening environments, since it was mixed in a "perfect" room.
ERGO integrates with all PC and Mac-based computer recording systems. In these environments, it appears as a standard FireWire audio interface, so setup is easy and compatibility is assured. With its analog inputs you can still use whatever non-computer-based recording hardware you are currently using without having to reconfigure your system. In analog mode, it sits between your existing recording interface or mixer and your speakers. It also integrates with Pro Tools by allowing a S/PDIF signal to be digitally connected. Because all processing resides inside ERGO, no overhead is needed from the computer audio system.
KRK ERGO Room Correction System Features:
- RoomPerfect system developed by Lyngdorf Audio in Denmark
Creates 3D image of room to better show good and bad areas
Applies 1024 dynamic filters to maximize the acoustics of your studio
PC and Mac compatible
Integrates with Pro Tools
Illuminated controls: Volume, Headphone Volume, A/B Speakers, Room Correction, Focus/Global
Calibration switch on back panel to enable measurement microphone
Headphone output
KRK ERGO Room Correction System Specifications:
- Dimensions:
ERGO: 7"W x 2.2"H x 4.2"D
Microphone length: 7.75"
Weight (ERGO): 610g
Processing
400MHz Blackfin DSP
RoomPerfect Algorithm Sample Rates: 96KHz
Room correction frequencies: 20-500Hz
1024 tap FIR filter for room correction
FireWire Specs
Mac, WDM, and ASIO Driver support FireWire recording interface capable simultaneous 4 in, 6 out
Audio Specs
Audio Spec A/B Speaker Select/Control
Stereo Audio-In
S/PDIF In (32KHz-96KHz)
118dB SNR THD+N - 100dB
The Following 2 Users Say Thank You to 999369 For This Useful Post:
跑去吃飯回來就有人幫忙post了,感謝啊,會在試用過後再進一步介紹
ERGO Room Correction Demo
The Following User Says Thank You to 999369 For This Useful Post:
虛空有時盡 我願仍無窮
KRK ERGO Fix Before U Mix, Part 1 of 2 錄音室用
KRK ERGO Fix Before U Mix, Part 2 of 2
設計是給錄音室用的,不過原理接近,音響室也可嘗試一下
作者: Yeh捨
為何標題是錄音室.?
給專業用的嗎.? ^^.
那就接在你訊源跟綜擴之間啊,多輸入接在前級跟後級間是方便而已
作者: kib
不知道綜擴也可以用嗎 ?
