第2頁,共2頁 第一第一 12
顯示結果從 11 到 15 共計 15 條
    Cedrus 訪客
    進駐預備....
    不知道該發在這邊就好還是改PO在用家Club那?
  2. The Following 2 Users Say Thank You to Cedrus For This Useful Post:
  3. #12
    其實可以放在 CLUB那裡...集中討論......
  4. The Following User Says Thank You to sound196 For This Useful Post:
  5. #13
    Dyna自己的amp真的比其他許多牌子和拍,許多8萬內的綜擴搭excite也沒有xeo好聽,尤其在高音厚度和低音控制方面
  6. The Following 2 Users Say Thank You to 統元音響 For This Useful Post:
  7. #14
    Danaudio Xeo wireless HI-FI
    Hi-fi without cables? If this is your domestic dream then Dynaudio has the solution with its Xeo wireless audio system. If Wi-Fi is traditionally associated with lo-fi then Xeo looks to set a higher standard with its bespoke transmitter capable of streaming music, up to 16-bit/48kHz resolution, to its Xeo 3 standmount and Xeo 5 floorstanding loudspeakers. Both speakers include two 50W amplifiers for their bass and treble drivers while the partnering Xeo transmitter features analogue, USB and Toslink optical digital inputs for compatibility with a wide range of hi-fi sources. Not only does Xeo support multiple sources but it will also stream out to three independent speaker zones, spreading its lively and dynamic sound quality throughout your home.
    無線HI-FI?如果這是你的家用夢想,DANAUDIO XEO無線音響系統就是你的解答。
    如果傳統上WI-FI會讓人聯想到LO-FI,而XEO是尋求更高的標準在發射機能力來撥放音樂,16-bit/48kHz是XEO3和XEO5的標準數值。
    落地式喇叭。兩個喇叭在低音方面都包含了50W擴大並驅動,配合XEO發射機可以接收類比、USB、和Toslink光纖數位輸入可廣泛並兼容多種音源。xeo不只是支援數種音源也可分享至三個獨立喇叭區域,讓你的家裡充滿生活化和動態聲音品質。
    http://www.eisa.eu/award/3/european-...2012-2013.html
    此篇文章於 2012-08-16 02:29 PM 被 Ted Chen 編輯。
  8. #15
