顯示結果從 11 到 13 共計 13 條
    預設 最殺的W4S μDAC 開賣囉!!!! 快來預購吧!!!!
    最夯的W4S,又有超高C/P值的迷你DAC了!!!!
    與DAC1同等級的DAC晶片~裝在迷你的航太鋁合金盒子裡,
    有同軸、光纖(24/192)、USB(24/96)輸入,RCA輸出。
    可選擇由USB或外部9V供電~
    價格超殺!!!! 只要 NTD 15,600 ~~~
    預計六月到貨!!! 要預購的請快跟小余聯繫~~~
    這麼優的東西,只能說...太殺啦....
    https://www.facebook.com/events/413580698667049/
    可直接站內信跟我聯繫!!!!也可在此或是fb留言登記~~~
    感謝!
    http://www.wyred4sound.com/webapps/p.../117839/618197
    W4S ΜDAC (ΜDAC) - DACS
    ALL NEW!! Measuring at just under 3.5"x3.5"x1.25" this DAC will fit almost anywhere!
    Now Shipping!Some great customer feedback!
    "I really like the unit, great imaging, a little warmth, fine bass. I know there are more expensive, maybe better DAC's out there but this is so good that I don't really care. The µDAC is a very nice product that just disappears and does its job. I kind of wish for a remote that I could use to switch inputs but at that price I can't complain. – Thanks"
    The Wyred 4 Sound µDAC is the perfect solution for digital streaming made simple. In many cases, the price and overall size of most dedicated DACs deters music enthusiasts from going digital. Whether it be for a second system or to begin digital streaming for the first time, the µDAC can surely impress. There are currently a handful of DACs available with a similar foot print to the µDAC but we have ensured that this piece has more to bring to the table. In fact, after learning about the high resolution support and stellar sonic performance, you may consider making this the go to DAC in your home and or office.
    There are two S/PDIF inputs which support 24 bit 192 kHz signals as well as an asynchronous USB input for computer streaming. Any of the inputs will provide the kind of performance expected from a price tag many times higher. From Internet radio to high res streaming the µDAC will not miss a beat. We adopted the very same USB technology used in our DAC-1! We were even able to include an ESS DAC to take full advantage of the limited real-estate in this 3.5”x3.5” chassis.
    Not only will the µDAC perform sonically, its soft lines and smooth finish make for a sleek looking product. Made from machined aircraft-grade aluminum with the W4S logo as a lock light (lights up blue when the DAC is locked onto a signal!), the µDAC is very functional yet so simple. Power is fed directly through USB when streaming from a computer. When using the S/PDIF inputs the USB cable is plugged into an outlet using the supplied adapter. Simplify and improve your digital streaming today!
  2. The Following 4 Users Say Thank You to 小余 For This Useful Post:
