第2頁,共3頁 第一第一 123 最後最後
顯示結果從 11 到 20 共計 24 條
    Custom Luxury Home Designs in California - design by Marc Canadell, for sale on Bird Streets, LA
    This custom luxury home in Los Angeles by Marc Canadell is luxury living at its best. Set high above the celebrated Sunset Strip on the famous “Bird Streets", this custom home design boasts five bedrooms, eight bathrooms, one acre and over 9,000 sq. ft. of pure extravagance. This private property is fully decked out from the outside in. A spacious deck with an infinity lap pool and an expansive outdoor entertaining area with a fireplace is a real hotspot, and leads into the home through expansive sliding glass doors. Interiors are contemporary in style, finished with rich custom details. Dark-stained wood floors add drama to each room, offering a formal elegance to everyday spaces. “Everyday” is by no means “ordinary” in this house – just check out the amazing spa-inspired bathroom and the decadent dressing area! Ultra-modern lighting illuminate interiors artfully, which open onto an outdoor terrace overlooking West Hollywood. The amazing luxury home is listed for sale through Mauricio Umansky at a price of $17,995,000. Marc Canadell Design
    via Contemporist
    Posted on July 23, 2009 10:22 PM
  2. #12
    引用 作者: 小余 查看文章
    你應該要貼一下你國外那幾棟房子的...
    你是說天橋下跟公園長椅旁那幾個紙箱嗎?
  3. #13
    via Contemporist
    請教有人知道中間那塊木頭是甚麼牌子的嗎??
  4. #14
  5. #15
    這樣的家,只住兩人嗎?
    家大,則一闊三大
    走來走去很遠很累人
    還有什麼什麼的
  6. #16
    外國豪宅的客廳好像都不喜歡擺電視..
    via Contemporist
  7. #17
    $17,995,000豪宅 年房產稅就要近200萬台幣想一年總共要有300萬台幣基本開銷在這房產上[如現金付清]
    富商或超級明星收入太高[年薪千萬或上億N億美元]付政府裞可達50%就是一半
    開銷如房貸及利息及房產裞可報銷少交稅,因此花的多還省回來
    於是~~~~~~~~
    此篇文章於 2012-04-30 11:49 PM 被 999369 編輯。
  8. #18
    引用 作者: Tosca 查看文章
    外國豪宅的客廳好像都不喜歡擺電視..
    除了公寓或是比較小的房子,一般美國的房子有客廳(living room)和family room。客廳是招待不熟的客人(坐幾分鐘就走的),所以很少擺電視。通常是幾張沙發椅(比較正式,坐起來也不特別舒服的)和幾張桌子。 Family room是家人休息娛樂的空間,這裡的家具就以舒服為主,當然電視和音響通常也在這裡。不是熟人,一般是進不到family room的。
  9. #19
    是的!
    而且重視美觀的很多都是要用時才會出現[電動] 及專用影音室
    浴室也都會有隱藏防水式的影音器材 豪宅就是想的到的都會有
  10. #20
    國情不同,民情也不同.
    我去美國肯定會"悶"瘋掉!!
