Golden Gate Solid Perfect-Surface Copper(PSC) Conductors Double-Balanced Asymmetrical Geometry Foamed-Polyethylene Insulation Gold-Plated RCA Plugs Metal-Layer Noise-Dissipation System(NDS)
此篇文章於 2012-04-12 05:57 PM 被 kib 編輯。 原因: 補充資料
虛空有時盡 我願仍無窮
Big Sur Solid Perfect-Surface Copper+(PSC+) Conductors Double-Balanced Asymmetrical Geometry Foamed-Polyethylene Insulation Direct-Silver Plated Pure "Red-Copper" RCA Plugs Metal-Layer Noise-Dissipation System(NDS)
Sydney Solid Perfect-Surface Copper+(PSC+) Conductors Double-Balanced Asymmetrical Geometry Polyethylene Air-Tubes Direct-Silver Plated Pure "Red-Copper" RCA Plugs Carbon-Based 3-layer Noise-Dissipation System(NDS)
此篇文章於 2012-04-12 05:52 PM 被 kib 編輯。 原因: 補充資料
Victoria Solid Perfect-Surface Copper+(PSC+) Conductors Double-Balanced Asymmetrical Geometry Polyethylene Air-Tubes Direct-Silver Plated Pure "Red-Copper" RCA Plugs Carbon-Based 3-layer Noise-Dissipation System(NDS) 72V Dielectric-Bias System (DBS)
此篇文章於 2012-04-12 05:50 PM 被 kib 編輯。 原因: 補充資料
Yosemite Solid Perfect-Surface Copper+(PSC+) Conductors Double-Balanced Asymmetrical Geometry FEP Air-Tubes (FEP is a Fluoro-Polymer) Direct-Silver Plated Pure "Red-Copper" RCA Plugs Carbon-Based 3-layer Noise-Dissipation System(NDS) 72V Dielectric-Bias System (DBS)
此篇文章於 2012-04-12 05:46 PM 被 kib 編輯。 原因: 補充資料
Angel Solid Perfect-Surface Silver(PSS) Conductors Double-Balanced Asymmetrical Geometry FEP Air-Tubes (FEP is a Fluoro-Polymer) Direct-Silver Plated Pure "Red-Copper" RCA Plugs Carbon-Based 3-layer Noise-Dissipation System(NDS) 72V Dielectric-Bias System (DBS)
USB Cables Forest USB Solid LGC Conductors Gold-Plated Pins Low-Jitter, Low-Distortion Audio Signal Conductors Controlled for Digital Audio Directionality
此篇文章於 2012-04-12 06:29 PM 被 kib 編輯。
Cinnamon USB Solid 1.25% Silver Conductors Gold-Plated Pins Low-Jitter, Low-Distortion Audio Signal Conductors Controlled for Digital Audio Directionality
此篇文章於 2012-04-12 06:30 PM 被 kib 編輯。
Carbon USB Solid 10% Silver Conductors Direct-Silver Plated Pins Low-Jitter, Low-Distortion Audio Signal Conductors Controlled for Digital Audio Directionality
Coffee USB Solid 10% Silver Conductors 72V Dielectric-Bias System (DBS) Direct-Silver Plated Pins Low-Jitter, Low-Distortion Audio Signal Conductors Controlled for Digital Audio Directionality
此篇文章於 2012-04-12 06:31 PM 被 kib 編輯。
