第3頁,共3頁 第一第一 123
顯示結果從 21 到 26 共計 26 條
    主要也跟原廠的聲音設計方向有關,Michael Fremer對I代有點意見,不過另外一位Fred Kaplan在評II的時候就完全相反,非常好評
    http://www.stereophile.com/floorloud...ii_loudspeaker
    In his review of the Sarastro I, my friend and colleague Michael Fremer complained that, though the SPL meter said otherwise, the speakers never sounded loud enough. "I was never kicked by a kick drum or seared by squealing...guitars," he wrote. MF may have a more demanding standard of loudness than I, but I didn't have a problem with the IIs. To me, the key in capturing loudness isn't so much the decibel level as whether the music swells as it gets louder—whether it expands in volume, in the spatial sense of the word. The Sarastro II got that right—whether it was the swelling of the strings in Michael Tilson Thomas and the San Francisco Symphony's performance of Mahler's Symphony 9 (SACD, SFSO 821936-0007-2), or Radiohead's kick drum and wailing guitars.
  3. #22
  5. #23
    Verity Audio原廠根據我的聆聽空間計算出了三種擺設方式
    我試了其中兩種,Placement 1與Placement 3
    兩者聽感差異很大
    我自己還是喜歡近一點聆聽的方式 (Placement 1)
    較近,質感定位清楚
    拉到最大,音場氣勢凌人、頻率也更為平衡(Placement 3)
    Placement 1:
    Distance between the listener and the wall in front of him: 7.78 meters;
    Distance between the center of the woofer driver and the back wall: 2.75 meters;
    Distance between the center of the woofer driver and the side wall: 50 cm.
    Placement 2:
    Distance between the listener and the wall in front of him: 7.8 meters;
    Distance between the center of the woofer driver and the back wall: 2.5 meters;
    Distance between the center of the woofer driver and the side wall: 70 cm.
    Placement 3:
    Distance between the listener and the wall in front of him: 6.24 meters;
    Distance between the center of the woofer driver and the back wall: 2.34 meters;
    Distance between the center of the woofer driver and the side wall: 76 cm.
  6. #24
    這低音單體果然不好run,比起一個禮拜前聲音越見凝聚,低音樂器形體越見明確,音場氣勢與規模持續進步中
  7. The Following 3 Users Say Thank You to chsiang For This Useful Post:
  8. #25
    現在這樣的擺位跟toe-in相當不錯...........
  10. #26
