顯示結果從 1 到 4 共計 4 條
主題: NuForce Air DAC
    預設 NuForce Air DAC
    NuForce Air DAC uWireless SystemTM | MSRP $179
    (uTX + Air DAC set)
    NuForce Air DAC iWireless SystemTM | MSRP $199 (available 3/22)
    (iTX + Air DAC set)
    NuForce uTX TransmitterTM | MSRP $59
    NuForce iTX TransmitterTM | MSRP $79 (available 3/22)
    NuForce Air DAC ReceiverTM | MSRP $149
    Introduction
    NuForce Air DAC's wireless technology lets you stream music from your computer USB port or mobile devices to up to four different receivers throughout your home or office. Easily get CD-quality sound with no latency and no interference throughout your environment-wirelessly, with Air DAC.
    The NuForce Air DAC wireless DAC/receiver and associated TX transmitters are based on a new wireless technology known as SKAA (www.skaa.com). SKAA provides seamless operation and a consistent user interface across different SKAA devices. SKAA technology has several advantages resulting in CD-quality sound and ease of setup described in more detail below.
    Air DAC offers:
    CD-quality sound, no latency, no interference with other Wi-Fi signals
    Simple control and setup - no software, setup or pairing
    Stream music to up to four receivers, and from up to four devices
    Works with any digital audio from music, movies, and games
    Works anywhere without interference - no wifi "hot spot" needed for reception
    About the Air DAC and SKAA wireless technology
    With Air DAC, you don't move to the music - the music moves with you.
    The Air DAC Wireless System is a combination wireless transmitter (iTX or uTX) and radio receiver (Air DAC) that operates in the 2.4GHz radio band. The Air DAC Receiver utilizes a premium quality Digital-to-Analog Converter (DAC) stage and simple one-button SKAA control.
    Unlike similar devices, the Air DAC and associated TX transmitters do not experience the typical loss in sound quality or interference capability of cell phones and other wireless devices. Rather, they offer CD-quality sound, virtually no latency, a 15-30 meter range, and a spread-spectrum technology that detects and chooses from among available frequency spectrums in order to avoid interference.
    The NuForce Air DAC Wireless Receiver and any device fitted with an appropriate matching TX transmitter can be combined to form a wireless audio network. Each transmitter can send audio to four receivers, and each receiver can connect to as many as four transmitters.
    Just link your Apple mobile device wirelessly to multiple amplifier/speaker systems located throughout your home. Then simply walk into any room with your portable player-the system automatically locks on to its signal-and stream your music to the speakers in that space. Move to the next room and stream music from the same device to that room's receiver or pair of speakers. Wherever you roam in your home or office, your music is with you.
    Features
    Can receive and lock with up to four independent iTX-100/uTX-100 transmitters.
    Simple operation -Use the single front-panel switch to step through each of the available transmitters within range of the receiver. The cycle returns to first transmitter after selecting the last available transmitter.
    CD-quality performance
    Extra-wide wireless audio range covers larger environments - iTX-100 range approximately spans 10-20m; uTX-100 range spans approximately 15-30m depending on conditions.
    The uTX (for USB device) Transmitter is cross-platform (Mac/PC), so there's no need to install drivers.
    The iTX similarly connects to a standard analog dock when mated with Apple iPod , iPhone and iPad.
    Compatibility
    NuForce Air DAC is compatible with the following products using the iTX transmitter:
    iTX is compatible with all iPod devices that have the 30-pin connector (i.e. except Shuffle).
    iPod touch (1st, 2nd, 3rd, and 4th generation)
    iPod classic
    iPod nano (1st, 2nd, 3rd, 4th, 5th, and 6th generation)
    iPod with color display
    iPod mini
    iPod with Click Wheel
    iPhone 4S
    iPhone 4
    iPhone 3GS
    iPhone 3G
    iPhone
    iPad 2
    iPad
    Apple, AirPort Express, Apple TV are trademarks of Apple Inc., registered in the U.S. and other countries.
    Specifications
    16-bit/48kHz x 2-channels
    Operates @ 2.4GHz
    RCA Output 2.1Vrms
    THD+N 0.03% @ 1kHz.
    Frequency Response 20-20kHz
    SNR > 91dB A-weighted
    Power Requirement 6.5V, 600mA, 100-240VAC (Worldwide AC)
    Dimensions 3.2"W x 3.4"D x 1.1"H
    Weight 1.5 lb. Shipping weight 5 lb.
    Included Accessories Power Supply
    Charge Cable ( Only iTX )
    http://www.nuforce.com/hp/products/airdac-tx/index.php
    無線好似成為新顯學了...................
  5. #4
    無線的優勢是方便!
