Gryphon Mephisto Solo
肯定是最近最夯的話題,來自丹麥的Gryphon,在之前發表了新的旗艦後級Mephisto後,又發表了Mephisto Solo,Solo代表的是更猛的單聲道版本,純A類200瓦(8 Ohm),一直成線性輸出到800W(2 Ohm),零負迴授,使用80顆高電流雙極輸出電晶體及1百萬微法拉的電容容量!
Pure Class A 200 Watts (8 Ohm), 400 W (4 Ohm), 800 W (2 Ohm), continuous RMS
Monoblock configuration
Zero global negative feedback
80 high current bipolar output transistors
1,000,000 microFarad capacitor bank
DC servo-coupling
Gryphon internal wiring
Output coupling via massive copper bussbars
No output relays
Decoupled transformer castings
Military spec. double-sided printed circuit boards
Optimal circuit layout for shortest possible signal path
Two separate Holmgren toroidal transformers with internal magnetic shielding
Separate power supplies for amp and digital circuits
Gold-plated Swiss Neutric XLR input sockets
Gold-plated custom-built Gryphon binding posts
Backlit, touch-sensitive front panel controls
12V remote power trigger for automatic turn-on
Automatic Green Bias setting or manual Low/Mid/High bias
Non-invasive protection system
Power consumption at idle below latest EU requirements
Designed and built in Denmark
www.gryphon-audio.dk
The Following 6 Users Say Thank You to Leo Yeh For This Useful Post:
吼....
我超愛這數據:
這才是真正大電流+瞬間爆發力的絕對保證!!
能敢這樣標示的廠家,真的沒幾家的啦!!
The Following 2 Users Say Thank You to 將軍 For This Useful Post:
我想"continuous RMS"對將軍大應該也是重點之一
The Following 2 Users Say Thank You to deng_s924 For This Useful Post:
作者: deng_s924
YES!!
如果不是RMS,一點意義也沒有!!
The Following 3 Users Say Thank You to 將軍 For This Useful Post:
原廠資料中提到不用橋接(bridge)方式,而用並聯(parallel)方式來 "turbo charge" Mephisto stereo amp modules into mono 以達到 half distortion, double current 和維持 input impedance and damping factor 不變,倒是相當用心的設計,同時也符合追求極致好聲的目的。
The Following 3 Users Say Thank You to HChi For This Useful Post:
