第7頁,共10頁 第一第一 ... 56789 ... 最後最後
顯示結果從 61 到 70 共計 98 條
  1. #61
    別用他提供的ASIO模式,用KS模式在測試看看吧! 我用KS就幾乎沒藍屏了@@ 除非BUFFER亂調...調太低這樣~
  2. #62
    小弟今天購買了Wireworld家的一哥!馬上接上mINT跟W4S家的廠線PK一番,首先Wireworld的聲音是令人驚訝的、生活的,聲底上算中性的。在Kenny G的Heart And Soul下 薩克斯風的聲音就像活了起來。
    W4S家的廠線表現也著實不差,並不會讓我感到差距明顯尤其是中頻線條清晰,低頻的量感非常充足!十足的美式風格,但美中不足的大概就是高頻延伸性沒有白金那麼好...但是以mINT一起買的加購價,CP質非常之高!
    W4S的愛用者如果預算上不那麼充足W4S真的是一條非常不錯的選擇!
    以上純粹個人心得,還請大家不吝指教!
    此篇文章於 2012-04-24 09:09 PM 被 zeal761021 編輯。
  3. The Following 5 Users Say Thank You to zeal761021 For This Useful Post:
  4. #63
    我还用了W4S的XLR线也很棒。都釆用PCOCC材质,性价比很髙。
    此篇文章於 2012-04-29 10:23 AM 被 CR1972 編輯。
  5. The Following User Says Thank You to CR1972 For This Useful Post:
  6. #64
    最夯的W4S,又有超高C/P值的迷你DAC了!!!!
    與DAC1同等級的DAC晶片~裝在迷你的航太鋁合金盒子裡,
    有同軸、光纖(24/192)、USB(24/96)輸入,RCA輸出。
    可選擇由USB或外部9V供電~
    價格超殺!!!! 只要 NTD 15,600 ~~~
    預計六月到貨!!! 要預購的請快跟小余聯繫~~~
    這麼優的東西,只能說...太殺啦....
    https://www.facebook.com/events/413580698667049/
    可直接站內信跟我聯繫!!!!也可在此或是fb留言登記~~~
    感謝!
    http://www.wyred4sound.com/webapps/p.../117839/618197
    W4S ΜDAC (ΜDAC) - DACS
    ALL NEW!! Measuring at just under 3.5"x3.5"x1.25" this DAC will fit almost anywhere!
    Now Shipping!Some great customer feedback!
    "I really like the unit, great imaging, a little warmth, fine bass. I know there are more expensive, maybe better DAC's out there but this is so good that I don't really care. The µDAC is a very nice product that just disappears and does its job. I kind of wish for a remote that I could use to switch inputs but at that price I can't complain. – Thanks"
    The Wyred 4 Sound µDAC is the perfect solution for digital streaming made simple. In many cases, the price and overall size of most dedicated DACs deters music enthusiasts from going digital. Whether it be for a second system or to begin digital streaming for the first time, the µDAC can surely impress. There are currently a handful of DACs available with a similar foot print to the µDAC but we have ensured that this piece has more to bring to the table. In fact, after learning about the high resolution support and stellar sonic performance, you may consider making this the go to DAC in your home and or office.
    There are two S/PDIF inputs which support 24 bit 192 kHz signals as well as an asynchronous USB input for computer streaming. Any of the inputs will provide the kind of performance expected from a price tag many times higher. From Internet radio to high res streaming the µDAC will not miss a beat. We adopted the very same USB technology used in our DAC-1! We were even able to include an ESS DAC to take full advantage of the limited real-estate in this 3.5”x3.5” chassis.
    Not only will the µDAC perform sonically, its soft lines and smooth finish make for a sleek looking product. Made from machined aircraft-grade aluminum with the W4S logo as a lock light (lights up blue when the DAC is locked onto a signal!), the µDAC is very functional yet so simple. Power is fed directly through USB when streaming from a computer. When using the S/PDIF inputs the USB cable is plugged into an outlet using the supplied adapter. Simplify and improve your digital streaming today!
  7. The Following User Says Thank You to 小余 For This Useful Post:
  8. #65
    什麼時候進music server~不知道國外有沒有評價?
  9. #66
    引用 作者: yk42b2001 查看文章
    這次會先跟µDAC一起進來demo測試機
    請大家耐心等候小魚的測試報告><""
  10. The Following 2 Users Say Thank You to 小余 For This Useful Post:
  11. #67
    小弟还很喜欢古河,入了一条古河旗舰gt2usb线,与w4s 的pcocc usb线一对比,同为pcocc材质古河细腻有余而气势不足,在屏蔽的处理上w4s也技高一筹,声音更加清楚一些。
  12. #68
    古河GT2 也是條不錯又平價的USB!
  13. #69
    说老实话,古河实在不咋样,我虽然也买了古河,但是并不推荐大家上古河。
    虽然古河的材质看起来很好,PCOCC镀银,但是音乐性上与欧美名线厂相比差了一截。
  14. #70
    最近老是用我的金嗓子E550做前级与W4SSX1000搭配,使用效果不太满意,是否因为E550的前级与后级共用电源,如果只做前级,效果不会好于独立前级?
