第119頁,共715頁 第一第一 ... 1969109117118119120121129169219619 ... 最後最後
顯示結果從 1,181 到 1,190 共計 7143 條
  1. #1181
    我的兩台還在等,電池供電. . .嗚. . .
    引用 作者: 小余 查看文章
    網路上跟國外很多人在改這耶~~~~
    真是服了大家對音質的狂熱~~~加油加油!!!
  2. #1182
    真的假的?那會很可怕喔!....
    AIRPORT EXPRESS 有一個很大很大的問題,就是『實在太耗電』!!當然所謂的耗電不是物理學上的,而是聽感上的。很多音響器材,給12V1A就會有還可以的聲音,但是一定要給到12A20A才能有『暫態反應夠快』的聲音,這就是我所謂的『太耗電』。
    依此觀點,按我估計,La Rosita Pi 壯觀的供電水準,就是 airport express『至少需要的供電量』!而 rendzaw 的改裝,則是用到到超大的工業用交換式電源,一樣壯觀哩!
    沒想到 MAXXIS 你也有在玩 AIRPLAY!....
    什麼是靜音模式?是指風扇的管理模式嗎?
    靜音模式是NAS電源管理設定選項
    我開始用NAS時還沒有air play
    所以一開始就是用iPod插在Wadia 170i
    透過WIFI接收NAS的數位訊號給DAC
    播放器是PlugPlayer
    可以支援到24/96
    Air play是很方便,我很少用它
    現在用DSAudio也很方便
  3. The Following User Says Thank You to hong For This Useful Post:
  4. #1183
    也可以前端用Amarra 後端再利用Airfoil把聲音送給AirPlay DAC
    http://www.sonicstudio.com/amarra/amarrafaq.html
    Q: How do I use use an Airplay Device (Airport Express, Apple TV, etc.) with Amarra?
    A: Using Rogue Amoeba's AirFoil software application you can route Amarra to your Airplay Device.
    - Ensure Audio Midi Setup is set to use Built in Input and Built in Output for sound input and output respectively.
    - Download and install Airfoil from http://www.rogueamoeba.com/airfoil/
    - Ensure Amarra and iTunes are both quit
    - Launch Airfoil
    - In the top part of the window, set the Transmit application to Amarra
    - In the bottom part of the window, click on the music note for the device you want to listen through.
    You should see Airfoil launch Amarra which will launch iTunes. Choose tracks from your iTunes library or an Amarra Playlist (44k tracks) and you should see the meters in Airfoil startup and you should here your music playing through your Airplay Device to your speakers.
    此篇文章於 2012-12-19 09:45 AM 被 小余 編輯。
  5. The Following 2 Users Say Thank You to 小余 For This Useful Post:
  6. #1184
    照上面這個方法,能傳出高解析給airplay嗎
  7. The Following User Says Thank You to AndyChu For This Useful Post:
  8. #1185
    引用 作者: AndyChu 查看文章
    不行啊~~~~~ 目前唯一解=Rosita Plugin +Rosita DAC
  9. #1186
    Rosita Plug in的授權制度是跟MAC電腦,還是跟Rosita機子,不會要一台Rosita播就要付一次錢吧,那兩台付兩次?
  10. The Following User Says Thank You to AndyChu For This Useful Post:
  11. #1187
    引用 作者: AndyChu 查看文章
    授權是綁Rosita機子上的網卡mac addrs
    所以N台mac電腦都可以灌同樣的plugin~對同一台rosita dac
    如果你有兩台rosita dac,得加購plugin的授權~ 就可以一份軟體對兩台機器
    (總而言之不綁電腦~ 綁機器)
  12. #1188
    引用 作者: 小余 查看文章
    所以要傳出高解析給airplay,還是得有一台Mac電腦在旁邊。
    不知道有沒有辦法弄出個Rosita plug-in for NAS? 這樣就可以跟Mac電腦掰了!
  13. The Following User Says Thank You to tvec For This Useful Post:
  14. #1189
    引用 作者: tvec 查看文章
    這個我跟SYNOLOGY 都在研究中....
    目前看來除了是Rosita原廠願意合作外...應該是有很大的困難~~~~
    全世界至今也只有Rosita辦的到~
  15. #1190
    44.1k都弄不出好聲,高解析有用處嗎???
  16. The Following 2 Users Say Thank You to rendzaw For This Useful Post:
