2023-04-18, 08:36 PM
#6971
終於把600w換下去,加入cosel 1500w大軍了!
(Ebay有pba1500-7.5v, 可以調整到最低4.75v
一顆只要50鎂,我買了兩顆,
賣家還剩七十幾顆,有興趣的快上!)
有個很笨的問題......
1500w給usb裝置用,一直插著電會不會很耗電啊?
有點懶得每天拔拔插插,但又擔心一直插著電費會很驚人...
The Following 4 Users Say Thank You to k900733 For This Useful Post:
2023-04-19, 11:42 AM
#6972
 作者: k900733
一顆只要50鎂,我買了兩顆,
賣家還剩七十幾顆,有興趣的快上!)
有個很笨的問題......
感謝 k900733 熱心通報。PBA1500 一部才 50美金、能輸出 5V 的二手品也較少見,淘寶上依品相大概是2.X 倍到 3.X倍的價格(但運費較低)。這下可以開心地用接近(只是接近;我有大電容恐懼症 )教授那種田僑仔的用法加電源啦。這個賣家設定不寄台灣 (可能是設定為不寄送到國外),從台灣買的話要跟賣家商量例外處理、或使用代購服務。
我猜 PBA1500 餵 USB 裝置耗電不大(可以用串接的耗能計量量看)。我不用時還是關機,因為開久了怕變衰聲,也是安全考量(畢竟是二手品、風扇也被我拔掉了)。不過真正的原因是我沒那麼發燒,用了有開關的排插,關機很方便啦(發燒的話就裝個法規開關)。
The Following 5 Users Say Thank You to dequad For This Useful Post:
2023-04-19, 11:59 AM
#6973
JPlay 的 DAC Link
JPlay 老闆說 XACT S1 裡跑的 JPlay,DAC Link 設為 2000Hz。XACT S1 的 JPlay 是特別的 Linux 版本,未單獨發售、裝在 XACT S1 裡已最佳化、沒有提供使用者可自行調整的參數選項:
I can only say that DAC Link in XACT S1 is 2000Hz.
一直有個印象是 JPlay 的 DAC Link 能使用的最高頻上限跟 DDC/DAC 的 USB 介面有關,不知道版上有沒有先進了解或大概猜得到 JPlay DAC Link 的運作機制(DAC Link 到底是指什麼呢)?也想請問一下大家都設在多少 Hz?我的 JPlay 雙機或單機接 DT2 最高都只能到 200Hz(UltraSTREAM 或其他模式都是)。
[補記]
找到 JPlay 的 Joseph 講 DAC Link:
Keep in mind DACLink applies to communication between software player and DAC driver. What DAC driver does internally i.e. how it communicates with DAC via e.g. low-level USB protocol, is entirely up to driver.
ASIO has no support for client to specify buffer size, it is always whatever ASIO driver developer decided (with some drivers it is possible indirectly to set it in driver's control panel as mentioned) so DACLink has no effect there.
However, DACLink also applies to JPLAY internal buffer size so it will have effect between the player (JPLAYmini, JPLAYStreamer, JPLAYDriver etc) and JPLAY Audio Service. Reason why you get silence with >20Hz buffer with your ASIO driver is likely that it is using odd buffer size which is not an exact multiple (or denominator) of DACLink buffer size which means memory needed may be more than maximum size of JPLAY Audio Service internal streaming buffer
還有老闆的解說:
DAC Link is DAC buffer and the value represents how big the buffer is (how often it is filled). 1Hz means that it is refreshed every 1s: https://en.wikipedia.org/wiki/Hertz
Also 1s is 44100 samples for CD format.
PC Buffer is the buffer that fills DAC Buffer. The relation between two is that PC Buffer has to be larger than DAC Link. As NickD wrote, the impact of PC Buffer on sound is smaller than DAC Link, however we've found that larger PC Buffer sounds better.
此篇文章於 2023-04-19 08:56 PM 被 dequad 編輯。
The Following 3 Users Say Thank You to dequad For This Useful Post:
2023-04-19, 12:47 PM
#6974
 作者: dequad
我不用時也是關機拔插頭,但我連續開了7天煲IE900耳機,也沒有衰聲,推測是我房間冷氣一直開著的原因?
The Following 2 Users Say Thank You to gangster.tank For This Useful Post:
2023-04-19, 08:30 PM
#6975
 作者: dequad
我沒有這麼大的號召力..... 樂之邦也真倒楣,前一個認同他的數碼多勸敗功力極強,現在我這個唯一可以辨認出樂之邦USB DDC世界第一的高手嚴重缺乏勸敗能力....
 作者: silaslin
我最近正好實際驗證過教授的猜測
我把 CAT 的 AX1600i 取出給外接硬碟使用,音質確實提升不少。
CAT 改用 RM1000X 後,雖然供電降級了,但是感覺不出明顯的差異。
你的外接是透過 USB?還是照樣使用SATA電源?我的外接特別有效是使用AX1600I的『SATA電源線』,再使用安費諾SATA線內接在主機板上。
 作者: k900733
有個很笨的問題......
 作者: dequad
 作者: gangster.tank
以上統一分享我的經驗:
大瓦數交換電供『需要熱機』但是『不必熱很久』,開機久了會『累積雜訊』嚴重污染聲音,不過很好解決只要關機兩分鐘(大約)再開機就可以了(不能排除是否我的大地盒會加速減噪的可能)。
根據以上邏輯,我的10台1500W是:平時關機,一但開機就一直開到當天絕對不會再聽音響為止。如果中間休息,會先斷電幾分鐘再重新開機。
1、估計大概要開機跑音樂15分鐘,1500W才算熱機完畢。
2、24小時不關機沒什麼危險也不會吃多少電,但是會『累積雜訊』嚴重污染聲音,只要聽音樂前關機兩分鐘(大約)再開機就可以了。
3、只要一直跑音樂,原則上1500W會一直『累積雜訊』並且累積『因發熱而生的熱雜訊』,所以加強散熱一定會有效減少後者
,但是無法消除前者。因此,我從房子本身的110V迴路接5V電源驅動四個直接流電腦風扇來幫AUDIO PC散熱;同時還要乖乖進行『關機兩分鐘(大約)再開機』的消除『累積雜訊』。
The Following 6 Users Say Thank You to psycho For This Useful Post:
2023-04-19, 09:18 PM
#6976
 作者: psycho
我跟教授是一樣的接法,但是有裝一個 SATA 外接卡,SATA 訊號線接在上面,獨立用 AX1600i 供電,主機板的 SATA 在 BIOS 中關閉。
也就是說 SATA 電源線和訊號線全都吃 AX1600i 的電。
獨立供電的方法是參照這一篇,感謝 @tetsuka 提供祕技
https://www.my-hiend.com/vbb/showthr...548#post252548
此篇文章於 2023-04-19 09:33 PM 被 silaslin 編輯。
The Following 7 Users Say Thank You to silaslin For This Useful Post:
2023-04-24, 12:46 PM
#6977
友站 Sam 兄提供了幾個硬碟供電的方案
特別的是那顆 12V 150W GaN 電供,我覺得有可能取代 AX1600i
https://www.stsd99.com/phpBB3/viewto...art=130#p21446
The Following 2 Users Say Thank You to silaslin For This Useful Post:
2023-04-26, 01:06 PM
#6978
數位訊源 VS LP
人一生要修的東西很多。去年我在家自己動手修的就有水刀通廚房排水管、「奈米」修補劑補水管。修的東西難度每年都在提高 。
不過音響迷修最多的當然是音響器材。最近因為組裝中的新靜電喇叭發聲板須送回澳洲處理,來回又要等一個月以上,不得不把原來在倉庫安養天年的其中一對 Quad 57 搬出來整修。之前一聲道的高壓過低導致聲音太小,於是把兩聲道的升壓模組(EHT) 都換新。之後用 REW 邊測量邊調整副低音的相位和增益,因為不用反覆試聽(調整完再聽一下確認即可),很快就把喇叭系統架好了。改了升壓電路後 Quad 的聲音又變得很棒、聽爆棚管弦樂也沒問題。忽然想起之前 LP 唱盤出現誤動作,拖了一兩個月還沒處理,就一鼓作氣,順便把唱盤底蓋打開檢查一下:
這個唱盤是 Sony 在 CD 出現之前傾全力開發的,唱臂用了好幾個線圈做伺服,即使在播放時輕輕敲打唱臂,從喇叭也聽不到敲擊聲。針壓抗滑都是伺服處理。看到裡面的電路複雜程度,就知道這絕對不是我應該動手的。不過既然打開了,還是簡單理一下內部那一把連結唱臂的細線,盡人事聽天命。裝好開機,沒想到竟然不再出現誤動作,聽聲音也十分正常。
想起電腦的 CPU 和記憶體升級後還沒比較過數位和 LP 訊源,於是選了幾張有 LP 和 數位兩種版本的專輯做一下比較,聽聽看現在的數位訊源和 LP 有什麼樣的差異:
上次教授來我家聽到的 Alpha 新錄音 LP 和 Reference Recordings 類比錄音的 Nojima Plays Ravel
Gardot 和 Swift,都是近幾年的數位新錄音
葛立格的鋼琴曲和 The Hollies 的 Long Cool Woman In A Black Dress (The Hollies 最棒的歌),兩者都是老類比錄音。錄音不算特別好
別看這唱盤什麼都自動,聲音比我用過的任何唱盤(包括兩款 Goldmund 和一些皮帶驅動及惰輪驅動唱盤,加各式長短唱臂)都更好,聽起來感覺失真很低。用這部唱盤播唱片比用 JPlay Mini 還簡單,唱片放上去、按一下 START 鍵就好了;播完唱臂自動歸位。
數位訊源用 Windows Server 2022/JPlay 單 PC,JPlay Mini 播放。晚點再寫比較的感想。
The Following 8 Users Say Thank You to dequad For This Useful Post:
2023-04-26, 01:49 PM
#6979
 作者: silaslin
不是完全取代喔! 5V 還是要靠AX1600i。
當然 5V 吃 Cosel 1500W 也是方案啦。
The Following 6 Users Say Thank You to sam0402 For This Useful Post:
2023-04-28, 07:10 AM
#6980
數位訊源 vs LP
這次數位訊源和LP 比較, 整體而言:
- 最明顯的差異在於 LP 的聲音比較 organic(說「有機」覺得怪怪的,只好寫晶晶體
)。不比較的話,數位的聲音非常棒;比較之後覺得還是有一點「數位」聲。 - LP 的人聲幾乎都比較立體、凝聚。
- 數位訊源要調整到好雖然麻煩,調好之後相對穩定。LP 的話,播放的時候很多狀況,有些是可以處理的(例如唱片髒了、VTA 因為唱片厚度不同而改變了)、有些是沒辦法處理的(例如內圈音質比外圈差一點)。
- LP 的頻寬並不覺得比數位窄。
- LP 的透明度比數位好。
在比較了兩三片之後,就覺得應該等 JPlay 雙PC都升級後再比較看看。記憶中雙 PC 的透明度較佳,可能會影響到其他面向的表現。
1)Alpha 的數位錄音 Calling The Muse
由於是數位錄音,想知道的是作為載具,LP 和 數位檔案有什麼差異。原來想說 LP 的頻寬應該不如數位「原樣」完整,聽起來卻不覺得(我的 Quad 加了高頻延伸到 40k Hz 以上的超高音)。找出另一張也是較新的 Alpha 錄音,Sonia Wieder-Atherton 迷幻的巴哈大提琴無伴奏(這是 45 轉版本;我第一次播放忘了切換轉速,用33 轉播,迷幻到像吃了藥),比較起來結論還是一樣,數位訊源的聲音較「平面」一點;總的來說差異微小。 LP 較 organic 的聲音聽起來較自然。
2)Nojima Plays Ravel
這是 Nojima 錄的第二張唱片,也是很多音響迷喜愛的「發燒」錄音。Nojima 1986 錄的第一張 Nojima Plays Liszt 我有24 bit/176.4k 的版本(藍光碟),用雙機 JPlay 播,精彩無比。這張的數位版(44.1k) 聽起來也不錯,但相較之下 LP 更立體一點。數位訊源播好的鋼琴錄音,即使不如 LP 那麼 organic,還是很棒。
3)Gardot 和 Swift
都是較新的數位錄音。Melody Gardot 這張是我剛開始組數位訊源時常播的專輯,所以印象深刻。最早用 Sony 藍光機播,聲音差 LP 好幾條街,尤其是透明度。後來組了 JPlay 雙 PC,終於拉近距離。這次聽,距離還在;就等雙 PC 升級完再聽聽看了。題外話,這張專輯 LP 我買了兩次,因為第一次買到偏心碟,音準飄來飄去,聽不下去。偏心和魷魚碟是 LP 的致命傷。偏心問題如果願意花時間慢慢找中心鑽/擴孔還可以解決,魷魚片則接近無解。我曾經拿了兩張重度魷魚片請唱片行用德國熱壓機處理,結果唱片雖然平了,溝槽卻變得歪來歪去,我連試播的勇氣都沒有。幸好那是一張數位版本聲音明顯勝過 LP 的專輯。
Swift 的 Folklore 和 Evermore 兩張專輯錄音都不錯,比較的情況和 Gardot 類似,LP 勝在立體感和透明度。
4)Eva Knardahl 的葛立格鋼琴曲
BIS 的老類比錄音。狀況類似,但是錄音品質沒辦法跟新數位錄音相比。
5)Long Cool Woman In A Black Dress
這首算是 The Hollies 非典型的歌(他們的歌我只愛聽這首······)。歌聲酷、鼓打得酷、歌詞也酷,是我小時候的回憶。CD 轉錄太差,完全聽不下去;LP 則自然、到位。這類沒有新轉錄/mastering 的老錄音也是聽 LP 的理由之一。古典樂比較沒有懷舊的問題,新演奏好,就不太會懷念舊的演繹。流行樂爵士樂則不同,Coltrane、Miles Davis 之類的不說,不管曲子是誰寫的,我們記得的總是「Fitzgerald 唱的」、「齊豫唱的」,懷舊的成分很高。暢銷的歌手會有新的轉錄版本一再推出,其中總會有轉錄的不錯的。沒那麼暢銷的專輯就只能靠 LP 才有好聲音了。
此篇文章於 2023-04-28 02:31 PM 被 dequad 編輯。
The Following 7 Users Say Thank You to dequad For This Useful Post:
