Network-Player |
Ayon S-3 |
Conversation rate |
192kHz / 24 bit |
Tube complement |
6H30 |
Dynamic range |
> 118dB |
Channel separation |
>105dB 20 Hz to 20 kHz |
Output level @1 kHz / 0,775V -0dB /RCA
2V fixed or 0 – 2V rms variable |
Output impedance Single-Ended-RCA |
~ 700 Ω |
Digital ouput |
75 Ω S/PDIF (RCA) |
Digital inputs |
75 Ω S/PDIF (RCA & up to 24/192kHz), TosLink (up to 24/192kHz)
110 Ω AES/EBU (up to 24/192kHz)
75 Ω BNC (up to 24/192kHz)
I2S (up to 24/192kHz)
Front mounted USB type ‘A’ socket for USB “pen”/hard disk drive
Rear mounted USB type ‘A’ socket for USB “pen”/hard disk drive |
Network inputs |
RP-SMA plug Wifi Aerial input (“wireless” network connection) 802.11b/g
UTP RJ45 10/100Mbps socket (“wired” network connection) |
S/N ratio |
> 110 dB |
Frequency response |
10Hz – 50kHz +/- 0.3dB |
Total harmonic distortion @ 1kHz |
< 0.002% |
Remote control |
Yes |
Analog – Line Inputs & output |
2 pair RCA and 1 pair RCA out |
Analog – Main outputs |
1 pair / RCA & 1 pair / XLR |
Dimension (Wide x Deep – incl. terminals x High – incl. feet) cm |
48 x 39 x 12 cm |
Weight, unit only |
12 kg |
Specifications subject to change without notice
