顯示結果從 1 到 5 共計 5 條
    預設 【線材】AUGENE Matchmaker Thin 訊號線
    Cables We have started to introduce our own cables using our Matchmaker® technology because we have discovered that cables influence the performance of equipment enough to make or break a reputation. Through numerous tests, we have determined that cables have to play an important role in matching the receiving end such that it can provide a constant load to the source throughout the audio band. Below we first show a typical input impedance curve using audio cables of various brands. All other commercially available cables that we have measured follow similar trends. The absolute impedance value at higher impedance is not accurate due to measurement equipment input impedance; however, the trend is quite consistent with listening experiences.
    Below is how our cables typically perform at early development stage. Note that we not only want a reasonably flat input impedance with good damping characteristics, but it’s also desirable to have it remain consistent under different equipment input impedance values. Development is ongoing and new releases will evolve.
    We initially introduce three series: The Matchmaker Adapter Series, Thin Series, and the Link Series. The Thin series is designed for people that want to keep the cable as “invisible” as possible. The Link Series is for people that accept normal interconnect dimensions. Initially, two lengths for each series will be provided, 2.5 meters and 10 meters. These lengths are selected for usage of the Exaltation in front and as surround speakers. Other lengths may become available as market demands. Because different cable lengths need to be treated differently, it is not possible to have too many options in stock.
    The Thin Series
    The Thin Series is aimed for those whom desire improved performance, but prefer thin cables for easy routing and easily hidden. These series excel in transparency over the audio range from 30Hz through 20KHz, which is ideal for most systems except for the huge systems that provide well defined performance below 30Hz which normally only large horns can more accurately reproduce.
    Since our cables evolved along with speaker and amplifier design improvements, we decided to keep each interface such that a constant load is presented to the source while we improve each device. Thus our cables will most likely provide best performance with our speakers at the end of the link which is due to design according to the philosophy that each individual link must meet certain engineering criteria so that design changes will not result in degradation of reproduction as designs evolve. When our cables are used with other equipment, it will normally be compatible for input impedances between 1KΩ~30KΩ; however, since not all equipment are designed to the same criteria, installation of our cables may make certain problems in other areas of a system more annoyingly revealing.
    It is well known that almost all cables require some time of break-in for it to reach stable characteristic. This has not only been widely known among audiophiles, but we have also verified this through measurement. Our cables reach stable performance after at least 100 hrs of playing time over a one month period
    www.augene-audio.com.tw
    請問一下這線材是soongsc兄設計的嗎?
    引用 作者: soongsc 查看文章
    不好意思現在才看到這個
    我們設計任何產品的方向是盡量減少器材搭配的不確定性
    因此對於介面設計盡量要求符合一定的標準
    線材設計是輔助器材之間介面的特性維持恆定值
    但這種線材不是和用於LP唱頭這一段
    最主要的原因是因為唱頭所需要的附載是不同的
    為什麼線要這麼細呢?
    主要是希望便於隱藏收納, 讓家裡看起來較清爽
    從顏色上選擇較中性也是為了這個目的
    希望大家會喜歡
    請問這是鐵氟龍銀質訊號線嗎!!
    真不好意思!小弟初入門才疏學淺!我以後不敢亂發問了!!
    引用 作者: soongsc 查看文章
    其實我很好奇
    很多人都要問什麼材質, 什麼處理, 等...
    好像要先想像聲音聲音應該是什麼樣子
    我們其實發現那些不是最關鍵性的因素
    而且技術也是複雜的
    所以實際聽比較重要
    喜歡尬線也不妨去玩玩
    不是最關鍵但也會有影響,這是其一
    二就是,抗阻圖都沒有 Y 軸,單位也沒有
