顯示結果從 1 到 5 共計 5 條
    預設 買Simaudio Moon 340i 送平衡輸入模組
    慶祝越點音響成立34周年,特別推出Simaudio Moon 340i超好康免費升級方案,即日起到6月底,凡是到越點音響購買Simaudio Moon 340i,免費升級加送平衡輸入模組,市價1萬元以上,請好好把握這個入手Simaudio綜合擴大機的好機會。
    Significant Design Features:
    · An oversized power supply using a custom toroidal transformer design
    · Rated output of 100 watts/channel into 8 ohms and 200 watts/channel into 4 ohms
    · 5 line-level inputs including a front-mounted 1/8” mini-jack for personal media players
    · One audio input which functions as a “pass-through”, bypassing the gain stage to
    accommodate a component such as a home-theater processor, whose own volume
    control is used instead.
    · Headphone output on TRS jack located on the front panel
    · RS-232 port for i) full unsolicited bidirectional feedback in custom installation setups
    and ii) firmware updates
    · IR input for external control
    · SimLink controller port allows for 2-way communications between other compatible
    MOON components
    · 12 Volt trigger output for remote operations
    · Four (4) bipolar output devices per channel in the amplification section which offer
    superb linearity throughout the entire audio frequency spectrum
    · Class A output to 5 watts for greater efficiency
    · PCB w/ pure copper tracings & gold plating that yields low impedance characteristics
    · Optimized selection of very high quality electronic components
    · A symmetrical circuit design
    · Rigid chassis construction to minimize the effects of external vibrations
    · Designed to be powered up at all times for optimal performance
    · Low operating temperature to ensure a longer than normal life expectancy.
    越點
    www.acdc.com.tw
    www.simaudio.com
    洪老闆不錯, 但我訂的銀色目前沒貨
    最新消息
    原廠目前在擴廠
    要六月才能出貨了...
    更正
    是加送
    加送平衡輸模組
    不是
    加送平衡輸模組
