顯示結果從 1 到 8 共計 8 條
主題: Thunderbolt
    預設 Thunderbolt
    Apple與Intel合作開發的技術, 當初計畫代號為Lightpeak, 目前看來還是用銅纜線傳輸, 但保留未來用光纖傳輸的可能性; 我個人是覺得用光來傳輸音訊利多於弊, 尤其是real-time的傳輸, 在光通訊的領域, 兩三百米的距離都算短距離, 而且光訊號的干擾源要比電訊號少的多; 光纖的成本不高, 頻寬大, 用在音訊或視訊的傳輸都相當理想
    http://www.intel.com/technology/io/t...bolt/index.htm
    摘要幾段Intel網站上的文字:
    "Thunderbolt technology works on data streams in both directions, at the same time, so users get the benefit of full bandwidth in both directions, over a single cable." (Bi-directional的概念在光通訊領域已經用很久了)
    "Thunderbolt technology was specifically designed with professional audio and video applications in mind, where the inherently low latency and highly accurate time synchronization features play a crucial role."
    "Thunderbolt technology is connectivity without compromise and will enable the full promise of Symphony I/O, Apogee's professional digital audio recording platform."
    – Betty Bennett, CEO, Apogee
    Lightpeak應該已經........不用再理他了.........
    今早發表的 apple mbp 已經使用上此技術了 ....
    虛空有時盡 我願仍無窮
    看來我LAG了....
    原本Lightpeak要與USB 3.0整合,
    而Apple把他跟Display Port整合,
    其實都是這樣, 即使光傳輸用不到, 還可以當USB 3.0用, 在Apple的Case當中是當外接螢幕用,
    所以即使光傳輸起不來也沒有損失
    是, USB3.0的規範其實相容於光傳輸; 未來如果光傳輸關鍵零組件平價化或是能順利跟Si-based IC整合, 也不是沒有實現的可能
    我還以為是講Nola Thunderbolt的sub,離題一下,有人知道為何Nola官網把Thunderbolt從產品列表中移除了呢?
    沒錯今天發表的MBP已經有Thunderbolt的接頭了,
    不過他的controller好大一顆?
    Introducing Thunderbolt.
    The fastest, most versatile I/O ever in a notebook.
    Imagine accessing multiple streams of uncompressed HD video — from your notebook — at speeds that let you edit an HD feature film in real time. That’s how Thunderbolt technology will connect the next generation of high-performance peripherals to the next generation of computers — starting with MacBook Pro. Ultrafast and ultraflexible, the Thunderbolt pipeline is more than 12 times faster than FireWire 800 and up to 20 times faster than USB 2.0, and it offers unprecedented expansion capabilities. It changes what you can do on a notebook.
    The Thunderbolt port will give you plug-and-play performance with a whole new world of Thunderbolt peripherals, as well as with the Apple LED Cinema Display and other Mini DisplayPort peripherals. You can daisy-chain as many as six devices, including your display. And with support for video and eight-channel audio, it’s easy to connect HDMI-compatible devices — like your TV and home stereo — using the HDMI adapter you already have. Current VGA, DVI, and DisplayPort adapters are also supported.
    http://www.apple.com/thunderbolt/
