第4頁,共10頁 第一第一 ... 23456 ... 最後最後
顯示結果從 31 到 40 共計 97 條
  1. #31
    RS代理有,我們也跟dCS聽過
    http://my-hiend.com/vbb/showthread.php?t=2559&page=29
    就規格上
    RS是指更嚴選的元件與標準,包括海外國家的檢驗
    Overseas MOON RS Series
    The RS series of MOON audio components benefit from an even higher standard of manufacturing process than the regular MOON versions. All significant differences are contained within the circuitry and construction of each model.
    RS versions are built using different materials and parts in certain areas. For example, printed circuit boards are of a higher temperature grade than that of the military specification FR-4 material we normally use; Their traces are gold-plated instead of a tin/lead composite. As well, all capacitors use improved dielectric materials.
    MOON RS models meet and/or exceed stricter manufacturing processes as required to pass many international safety standards such as those imposed by the E-U, Japan and South Korea. Cosmetically, the ONLY difference is the RS logo on the front panel.
    林大哥還蠻容易放棄的...哈,忍一忍也不錯,等癢點再說吧~
  2. #32
    我的預算只能買北美版本,RS版也沒有興趣.何必多花錢買呢?又不是全世界版本,只有某些國家才有,令人感覺不是很好.
    所以放棄買公吧!癢點就買水吧!人怕沒錢並不是怕買不到,想買個北美標準版合理價格都這麼難.
    功成何必在我
    功成不必在我
    功成之日
    離開之時
  3. #33
    Andromeda沒有必要RS版本,除非有LE限量版本才值得投資。
  4. #34
  5. #35
    我想用600i當核心, 向下配喇叭, 向上配訊源
  6. #36
  7. #37
    SIMAUDIO SUPERNOVA CD最近聽了燒友建議,把後面的數碼同軸輸入和同軸輸出用同軸線連接起來效果出奇好,問了師傅才知道等同於時鐘同步效果更加出色有這台機的燒友可以嘗試一下效果會讓你吃驚的。
  8. #38
  9. #39
    600i 好貴喔, 要再存個3~4年才買的下, 算了, 先入手 i3.3 (現在叫i340), 價格大約 340/600 的600i價格, i3.3 報到
  10. The Following User Says Thank You to cc31163 For This Useful Post:
  11. #40
