顯示結果從 1 到 7 共計 7 條
    預設 Audio Research LS27 前級
    USD 7,000
    Hybrid JFET/tube stereo line stage with remote control.
    Features:
    * Controls: Selectable high/medium/low gain settings, BAL/SE selection, balance control, invert (phase), and stereo/mono selection
    * Processor pass-through for home theater applications
    * Dimmable display with the option of being turned off
    * All of the inputs and outputs have balanced XLR and single-ended RCA connectors, including six pairs of discrete inputs, a processor (unity gain) input, a monitor loop, and two sets of main outputs
    * Monitoring of tube hours
    * A new microprocessor controls all functions
    * Pure Class-A design with zero feedback
    * Fully regulated power supply
    * Gain is provided by twin 6H30 triodes
    * Rear panel includes a 12V trigger and a 15A IEC connector
    www.audioresearch.com
    改款改的好勤勞. . .;(
    引用 作者: 臭酸石頭 查看文章
    改款改的好勤勞. . .;(
    請那麼多工程師當然要做點事啦! (sweat)
    換了主事者後,這種頻繁改款的作風實在不敢恭維,Hi-End器材這樣做恐怕會有損品牌形象。
    這版的輸出交連電容換了,長得真像台產的UXX電容...
    沙米亞咚的窩
    Eric Chu's Audio Lab
    http://98.to/ericc0922
    下次升級要換品牌了. . .買了兩年就改款. . .
    引用 作者: ericc0922 查看文章
    很差
    原本還考慮他們的某產品
    現在已經完全沒興趣了
    這樣的經營策略實在很 low end
    他現在出的款式其實應該命名為另一系列,因為是利用較為省電電路設計產品,其實跟原本的產品未必有衝突,如果Audio Research這些新產品不定位好的話,的確會造成消費者的疑慮。
