The Thorens Stabilizer is designed to improve the playback performance of turntables. It features 8 polished and precision balance weights embedded in rubber for resonance dampening.
In actual use, the Thorens Stabilizer holds the record on the platter, helps reduce minor warps thus allowing the stylus to track and trace record grooves more effectively. The result - more sonic detail and harmonics.
The Thorens Stabilizer works with felt and rubber turntable mats. It offers exceptional polish and performance, hallmarks of the Thorens marque.
Specifications:
Construction: 8 balance weights
Dimensions (D x H): 2.7 x 1.1" (69.0 x 28.0 mm)
Weight: 1.21 lbs (0.55 kg)
