顯示結果從 1 到 6 共計 6 條
    預設 Paul McCartney [Uncompressed] Band On the Run (Audiophile 24bit/96kHz)
    Paul McCartney and Wings - Band on the Run (24/96) FLAC
    https://www.hdtracks.com/index.php?f...00888072326170
    Whole Album : US$19.98
    Each Song : US$2.49
    :P:P:P
    Remastered Album Tracklist:
    1. Band on the Run (5:11)
    2. Jet (4:08 )
    3. Bluebird (3:22)
    4. Mrs Vandebilt (4:39)
    5. Let Me Roll It (4:49)
    6. Mamunia (4:51)
    7. No Words (2:35)
    8. Picasso’s Last Words (Drink to Me) (5:49)
    9. Nineteen Hundred and Eighty Five (5:30)
    Total Running Time 41:06
    :o:o:o
    Bonus Audio Tracks:
    1. Helen Wheels (3:45)
    2. Country Dreamer (3:08 )
    3. Bluebird [from One Hand Clapping] (3:26)
    4. Jet [from One Hand Clapping] (3:55)
    5. Let Me Roll It [from One Hand Clapping] (4:23)
    6. Band on the Run [from One Hand Clapping] (5:13)
    7. Nineteen Hundred and Eighty Five [from One Hand Clapping] (5:57)
    8. Country Dreamer [from One Hand Clapping] (2:14)
    9. Zoo Gang (1:59)
    Total Running Time 34:19
    Two Download Choices:
    1) [Compressed] The original album mastering in 96/24
    2) [Uncompressed] The newly remastered BAND ON THE RUN in 96/24 with NO dynamic range compression.
    Audiophiles will appreciate that both 96-kHz/24-bit downloads of BAND ON THE RUN sound dramatically cleaner and far more transparent than any previous version of the album!
    :O:O
    Compressed Albums - reduces the difference between the loudest and softest sound for playing music in noisy environments like cars or radios. However in this project compression was used very sparely.
    No Compression - is truest to the master tape, has wider dynamic range, and more impact.
    "The audio industry has seen many technical innovations since BAND ON THE RUN was first released on vinyl in 1973, the most notable being digital recording. However, with the introduction of CD came two advances, 'de-noising' and 'peak limiting' which have become increasingly unpopular within certain areas of the music industry and amongst audiophiles.
    "De-noising was introduced to remove the inherent sound, or hiss, associated with analogue tape. The amount of processing used to remove tape noise can be varied, but when used excessively, many believe that it also has a detrimental effect on elements of the musical sound.
    "Peak limiting is a process that increases the loudness of music. It is achieved by holding the loudest peaks down and raising the overall level of the music. Much depends on the amount of limiting applied, but at its most extreme the result can be a serious reduction in the dynamic range and often audible distortion.
    "The release of The Beatles' remasters in 2009 saw a marked change in attitudes towards these issues, where both noise reduction and limiting were used sparingly with the aim of representing the master tapes more accurately.
    "Such is the case with the newly remastered CD of BAND ON THE RUN: tape noise reduction has scarcely been used and the degree of limiting is subtle. In addition digital technology has advanced with the ability now to offer recordings in 24 bit/96kHz. The high resolution version is being made available via download and is being offered in two formats: limited, which is comparable in volume to the remastered CD, and un-limited, which in comparison with the limited version will sound quieter, but retain the dynamic range of the original master recording."
    :P:P
    High Resolution Digital Audio (Limited and Unimited) : $35.99
    High Resolution Digital Audio - Limited : $19.99
    High Resolution Digital Audio - Unlimited : $19.99
    :o:o
    真想試試看...
    只可惜國外管道不知道該怎麼入手....
