第19頁,共23頁 第一第一 ... 91718192021 ... 最後最後
顯示結果從 181 到 190 共計 227 條
  1. #181
  5. #185
    请问:有没有weiss man301固件升级的图片?初始密码是多少?Thanks
  6. #186
    來報到一下好了...目前在測試耳機,所以暫時先這樣放,下週才會搬動器材位置
    唯有質近,方得共鳴
  7. The Following User Says Thank You to heartsnow For This Useful Post:
  8. #187
    引用 作者: charlie2009 查看文章
    試一下:WeissMAN301
  9. #188
    過去兩個月,Weiss 升級了 40 多部 Golden DAC module (DAC-B),得到的反應都非常正面,聲音獲得進一步提升,很大部分要感謝 OP1-BP 離散輸出級。最下方附上 DAC-B 的數據表。
    The measurements below have been taken at the following conditions (unless noted otherwise):
    • 1 kHz measurement frequency
    • maximum selectable output level
    • 176.4kHz sampling frequency (Fs)
    • 22kHz measurement bandwidth, unweighted
    • 0 dBr equals the output level at 0 dBFS input (dBFS = deciBel Full Scale)
    XLR Connector Output:
    Output is DC coupled, short circuit proof
    Output Impedance: 94Ω.
    Output level selectable from:
    7.5 Vrms, +19.7 dBu, with a 0 dBFS sinewave input
    2.3 Vrms, +9.7 dBu, with a 0 dBFS sinewave input
    0.75 Vrms, −0.3 dBu, with a 0 dBFS sinewave input
    0.23 Vrms, −10.3 dBu, with a 0 dBFS sinewave input
    These levels are achieved with all faders / gain trims set to maximum level.
    RCA Connector Output:
    Output Impedance: 47Ω.
    3.75 Vrms, +13.7dBu, with a 0 dBFS sinewave input
    1.15 Vrms, +3.7dBu, with a 0 dBFS sinewave input
    0.375 Vrms, −6.3dBu, with a 0 dBFS sinewave input
    0.115 Vrms, −16.3dBu, with a 0 dBFS sinewave input
    Frequency Responses:
    • Fs = 44.1 kHz, Filter A, 0Hz−20kHz: within ± 0.25dB
    • Fs = 44.1 kHz, Filter B, 0Hz−20kHz: within ± 1.3dB
    • Fs = 88.2 kHz, Filter A, 0Hz−20kHz: within ± 0.25dB
    • Fs = 88.2 kHz, Filter A, 0Hz−40kHz: within ± 0.8dB
    • Fs = 88.2 kHz, Filter B, 0Hz−20kHz: within ± 0.25dB
    • Fs = 88.2 kHz, Filter B, 0Hz−40kHz: within ± 1.5dB
    • Fs = 176.4 kHz, Filter A, 0Hz−20kHz: within ± 0.25dB
    • Fs = 176.4 kHz, Filter A, 0Hz−40kHz: within ± 0.8dB
    • Fs = 176.4 kHz, Filter A, 0Hz−80kHz: within ± 2.5dB
    • Fs = 176.4 kHz, Filter B, 0Hz−20kHz: within ± 0.25dB
    • Fs = 176.4 kHz, Filter B, 0Hz−40kHz: within ± 0.8dB
    • Fs = 176.4 kHz, Filter B, 0Hz−80kHz: within ± 3.5dB
    Total Harmonic Distortion plus Noise (THD+N):
    • Less than −116 dBr (0.00016 %) at −3 dBFS input level
    • Less than −125 dBr (0.000056 %) at −40 dBFS input level
    • Less than −125 dBr (0.000056 %) at −70 dBFS input level
    Linearity:
    Less than ± 0.4 dB deviation from ideal at 0 dBFS to −120 dBFS input level
    Spurious components (including harmonics):
    • All components at less than −120 dBr at 0 dBFS input level, maximum output level, 1 kHz
    • All components at less than −115 dBr at 0 dBFS input level, maximum output level, 4 kHz
    Crosstalk Attenuation:
    Less than 120 dB, 20 Hz–20 kHz
    Inter-channel Phase Responses:
    • Less than ± 0.05° 20 Hz–20 kHz
    • Less than ± 0.30° 20 Hz–80 kHz
    資料來源 : http://designwsound.com/dwsblog/2014...dule-datasheet
    此篇文章於 2014-08-29 04:13 PM 被 Ted Chen 編輯。
  10. #189
  11. #190
