USB DAC 請問怎樣用ASIO ? (foobar2000)
之前用電腦聽歌感到沒什麼生氣, 用了ASIO 之後令冰冷的電腦音樂檔案生動起來, 但現在用了USB DAC 之後就用不了ASIO, 請問有沒有人知道怎樣解決 ?
啊, 忘了說, 我是用Win 7 64 bit ......
跟USB DAC無關吧
是foobar output 沒有改,還是說ASIO windows 7不能用?
換用 WASAPI 嘍........
作者: 小葉
跟USB DAC無關吧
換用 WASAPI 嘍........
大大, 小弟之前用聲卡作輸出的時候是能用ASIO, 只是選了ASIO 時USB DAC 沒有聲音.......
上圖給大大過目:
只有這些選項....
Null Output 是什麼 ?
有DS 類和DSOUND 類, 有什麼分別 ?
只能選有USB DAC的呀........KS應該是可以吧,我有點忘了
Microsoft developed a new audio architecture.
It was introduced in Vista and as far as I could judge, Win 7 has the same audio stuff on board.
Vista/Win7 do have an audio engine, this is the one who does the mixing, sample rate conversion, etc.
WASAPI (in exclusive mode) bypasses the audio engine and talks straight to the end point (sound card).
My experience is that WASAPI sound slightly more transparent compared with DS
http://www.head-fi.org/forum/thread/...-for-windows-7
null output 無輸出
WASAPI外掛 到foobar網站 下載
ASIO請到左欄asio virtual device新增,方可使用......
The Following 2 Users Say Thank You to sp007 For This Useful Post:
作者: 小葉
KS DAC 能用....不過.....聲音非常怪, 用DS 的也是一樣怪, 只有DSOUND 是最好~
是我設錯了設定 !?
作者: kei8864
Null Output 是什麼 ?
DS應該是指Direct Sound,XP下的audio API,罪惡的淵藪...
別搞這些東西,先去抓WASAPI plugin
The Following User Says Thank You to drunkenlife For This Useful Post:
