主喇叭:Sonus Faber Cremona
會選擇Sonus Faber的喇叭可是有原因的,andychu從小就移民到澳洲西岸的柏斯(perth),是最近才回臺灣的,在澳洲的時候,所用的喇叭就是Sonus Faber Piano Home,對Sonus Faber的表現很是滿意,當時搭配的是Arcam與當地音響店所製作的845 Mono後級。
一般常見到的顏色是maple(楓木色的),這對Cremona顏色則非常特別,是Graphite ecologically sensitive medium gloss lacquer(有點接近石墨的顏色),主要是為了可以搭配家裡的裝潢,為了要這個顏色,代理還特別向國外引進呢!
Cremona是三音路的設計,高音為vifa的凸鼻高音(還是金的喔),中低音單體為scan的製品,除了特殊的網罩設計外,喇叭正面的真皮使用與32層的木材組合而成的專利箱體就是Sonus Faber的招牌,實在非常迷人!
喇叭端子也是自家設計的,single-wired,阻抗為4歐姆
喇叭線為Neotech旗艦 NES-1001 UP-OCC SILVER (單結晶銀)
預留的喇叭管線
Sonus Faber Cremona
System Type: 3-way, Lute-shaped cabinet
Cabinet: 32 individual layers of solid and laminated maple
Driver Complement
Woofer: 2 x 7 in. (180mm) sliced hard paper cone with Symmetric Drive motor
Midrange: 6 in. (150mm) sliced hard paper cone with Symmetric Drive motor
Tweeter: 1 in. (25mm) high-resolution Ring Radiator with copper cap motor
Crossover: 300Hz / 3khz, non-resonant acoustic first-order, optimized acoustic phase response, highest grade components
Frequency Response: 32Hz - 40kHz
Impedance: 4 ohms, nominal
Sensitivity: 90dB 1W/1m, 2.83V
Power Handling: 50-300W, without clipping
Finish: Maple or Graphite ecologically sensitive medium gloss lacquer
Dimensions: 8.9 x 17 x 42.9 inches (WDH)
225 x 430 x 1090 mm (WDH)
Weight: 159 lbs / pr, 72 kg / pr
www.sonusfaber.com
