第51頁,共52頁 第一第一 ... 4149505152 最後最後
顯示結果從 501 到 510 共計 516 條
  1. #501
    Gyrotension VEGA Audio Vibration Isolator
    http://www.highendcity.com/gyrotension-vega-audio-vibration-isolator/
    [Features & spces]
    -Floating type vibration isolator by radial symmetry silicone ring structure.
    -Adjustable tension setting by the number of rings.
    -Double vibration isolation design by silicone rings and 3-point support ceramic balls
    -Radial symmetry ring design absorbs, diffuses and dissipates all kinds of vibrations more effectively.
    -Precisely machined duralumin body and hard anodized top plate.
    -The number of silicone ring layers: Small - 4 layers (48 rings), Large - 6 layers (72 rings)
    -Height adjustment range: 20mm(0.79 inch).
    -Size(Diameter*Height): Small - 60*40 mm(2.35*1.57 inch), Large - 79*47 mm(3.11*1.85 inch)
    [Recommended load]
    -Small: 12kg/each (36Kg (79 lbs) for 3-point supports)
    -Large: 18Kg/each (54Kg (119 lbs) for 3-point supports)
    [Ring tension / each]
    Max: 500g (1.1 lb)
    Recommended: 250g (0.55 lb)
    [Recommended tension adjustment by applied loads]
    (Assuming 3-point supports and large 6-layer ring Gyrotension.)
    Under 9Kg: 1 layer
    9 - 18Kg: 2 layers
    18 - 27Kg: 3 layers
    27 - 36Kg: 4 layers
    36 - 45Kg: 5 layers
    45 - 54Kg: 6 layers
    *You can adjust the tension by the number of rings and arrangement.
    Vibration in audio equipment is a serious problem that can't be ignored. If you remove it in any way you can improve
    the sound more than you can imagine. It makes very firm, disctinct and deep bass level. Mid-range is very smooth
    and detailed and no irritable and aggressiveness in high frequecy range. Clear, firm and wide sound stage mean that
    it's getting close to the natural sound.
    The Gyrotension Isolator is the ultimate resonance/vibration control device that employs the most precise and absolute
    resonance/vibration absorbing, dissipating and eliminating function.
    The Gyrotension Isolator is the most effective device for the vibration from the outside. One of them is "Ground-borne
    vibration" and universally accepted as one of the major reason for the variability in the performance of audio equipment.
    However tiny a vibration may seem to us, it will affect huge impact to the hi-fi audio signal processing systems.
    You can set the optimum load by hooking the calculated number of rings. Recommended: 250g (0.55 lb)/each ring
    3 Ceramic balls for 2nd vibration isolation.
    You can adjust the height even under working load state by rotating the main body (written in 'VEGA').
    Recommendations for the best support points.
    Source players including CD Player
    and Turntable.
    [Recommending points]
    Bottom part of
    -CD transport
    -Power supply
    -Analog output
    -Turntable Motor
    -Turntable Spindle
    Amplifiers
    Bottom part of
    -Main transformer or power supply
    -Other 2 or 3 points for balancing
    相信不少發燒友針對器材所產生的震盪,施加適當的避震手法,來增強重播時的效果,乃十分常見的調聲手法,而當中可謂各師各法,市場上更加衍生了 許多不同流派,以不同的避震理念,去解決器材所產生的震盪問題,從而提升或還原器材原有的實力,這次來自來自韓國的廠商,以獨特的浮動式懸空避震方式,設 計出趣味性極高的避震腳Gyrotension VEGA 浮動式懸空避震腳。
    Gyrotension VEGA 稱為浮動型隔離器,主要透過採用了矽環作懸吊,這些有如橡筋一般的環,作為可以調節張力方式支撐著主體,而在底層則以陶瓷球作三點支撐,用戶只需將橡筋環 塞進一個硬鋁柱體,便能以懸吊方式支撐著一塊硬質陽極氧化的翅板,這塊板上面承著頂層的硬質氧化頂板,整體更提供了 20 毫米左右的高度調整,在設置上極具彈性。
    Gyrotension VEGA 分別推出兩種不同大小的 2 個型號,較小型的由橡筋圈 4 層、 48 圈組成,而大型的型號則由 6 層與 72 圈懸吊方式組成,小型( 4 層、 48 圈)能支撐高達 36 千克/ 79 磅,而大型的( 6 層與 72 圈)承重能力則提升至 54 千克 / 119 磅,用家更可自行調節橡筋的數量及配置方式,來達至不同的調聲效果,玩法十分多元法。
    產品特點及規格:
    • 型懸空隔振器由徑向對稱矽膠圈結構
    • 可調節張力的振鈴次數設置
    • 雙隔振設計,陶瓷球以矽環以 3 點支撐
    • 環形對稱式設計吸收,能擴散並更有效地去除各種振動
    • 高精度及高密度鋁製主體與硬質氧化頂板
    • 矽膠圈層數:小- 4 層( 48 環),大- 6 層( 72 圈)
    • 高度調節範圍:20 毫米( 0.79 英寸)
    • 尺寸(直徑 x 高):- 小 - 60*40 毫米( 2.35 * 1.57 英寸), 大 - 79 * 47 毫米 ( 3.11 * 1.85 inch)
    原廠推薦負載設定:
    • Under 9Kg : 1 layer
    • 9 - 18Kg : 2 layers
    • 18 - 27Kg : 3 layers
    • 27 - 36Kg : 4 layers
    • 36 - 45Kg : 5 layers
    • 45 - 54Kg : 6 layers
    用家可自行調節橡筋的數量及配置方式
    相信不少發燒友,曾用過不少避震釘腳或絕緣體,但像 Gyrotension VEGA 一般,能透過自行調節橡筋圈的數量及設置方式,以達到不同的效果,相信十分罕見吧?光是這一點,相信已經值得愛好此道者關注。
  3. #502
    Aavik Acoustics U-300 綜合擴大機
    看起來是跟丹麥Raidho有關,因為消息是Raidho所發佈的,Raidho以喇叭為主,所以Aavik Acoustics就以推出電子產品為主
    U-300是一台綜合擴大機,具有24Bit/192kHz DAC與RIAA唱放功能,一台就解決所有的要求, U是Unity一件的意思,當然也有類比輸入
    輸出為2 x 300 W/8Ω, 2 x 600 W/4Ω
    In the high-end audio industry, the different audio components are commonly built as separate boxes: one box for the phono amplifier, another box for the digital to analog converter, a third box for the preamplifier section and one or more separate boxes for the output stage. Therefore, one important concept behind the Aavik U-300 -“U” for Unity - was to unite state of the art functions and components into one single, compact, high performance unit. This new amplifier would allow you to enjoy high-end performance, without having to live with numerous, odd-sized boxes and a forever-growing cable snake pit. With the Aavik U-300, you get one unit that has it all. You do not just get an amplifier; you also get 3 analog line inputs, a truly unique performing phono RIAA section and a superb 24 bit/192 kHz DAC. Another important reason why we chose “U” for “Unity” is because the Aavik U-300 is a joint project between the designer behind the multiple award-winning loudspeakers of Raidho Acoustics and the high performance cables of Ansuz Acoustics, Michael Borresen, and some of the best analog and digital designers that the world has to offer. This ensures that the Aavik U-300 is an integrated amplifier, which is in the top of its league!
    DAC
    The Aavik U-300 DAC section is designed around 5 digital inputs, which all excel in performance. The DAC performs without any digital signature, which makes any music sound "analog". The digital circuits are created with the best high frequency skills tools available and great care was embedded in the PCB design. We made a lot of effort to ensure we have a 100% equal treatment of the differential signals, with time-aligned, ultra-short, 4-layer PCB traces. The DAC's circuits are fitted with ultra-low jitter onboard clocks in order to minimize timing errors in the digital-to-analog conversion. In the Aavik U-300 all DAC circuits are isolated with 13 onboard, separate low-noise, high-PSSR voltage regulators each feeding only one stage of the signal handling.
    The USB input is galvanic isolated to avoid noise pollution from the host. The digital signals from the 5 digital inputs are routed to an ASRC, where they are resampled and re-clocked to 200 kHz/24 bit PCM, feeding current output DAC chips. The current-to-voltage conversion is performed with a differential floating topology with virtual GND. This isolates the signal path from the potential GND noise and signal induced GND modulation.
    VR
    The Aavik U-300 line stage uses a unique, inverted, virtual GND amplifier topology, which preserves the finest musical details on a dark, quiet, black background. The line stage gain can be adjusted between 3-6-12 dB. These adjustments give you the opportunity to adjust individual levels of all inputs on the Aavik U-300 amplifier. The volume control is realized with a resistor ladder (R2R) circuit in 80 1dB steps.
    Design
    The Aavik U-300 design is typical Scandinavian, with a simplistic functionality and a minimalistic look. The cover is made of anodized aluminum, which gives it a stunning matte black finish. The only other colors seen on the front panel of the Aavik U-300 are small LED lights, indicating your current volume/gain/source/cartridge settings and three silver buttons on the top panel.
    Adjusting the Aavik U-300 settings is easy – all settings are controlled with the three buttons and a big rotating knob.
    Output:
    • 2 x 300 W/8Ω, 2 x 600 W/4Ω
    • Distortion: <0.005% (THD+N: 1-100 W / 8Ω)
    • IMD<0.0008%
    • TIM<0.002% (10W, 8Ω)
    Phono:
    • Floating RCA (1 set)
    • Load-impedance adjustable from 50Ω to 5 kΩ;
    • Frequency response: +/-0.15dB (20-20 kHz)
    • Noise < -100dB re @ 2V out
    • Distortion < 0.01% (20-20 kHz)
    • RIAA correction curve
    • Gain: 62 dB
    Line:
    • Line 1, Line 2, Line 3
    • Gain adjustable in 3 steps (3, 6, 12 dB)
    • Input impedance: 10 kΩ
    Digital:
    • 2 x RCA SPDIF (32 – 192 k-samples, 24 bit)
    • 2 x TOSLINK optical (32 – 96 k-samples, 24 bit)
    • 1 x USB fully isolated, UAC 2, asynchronous (PCM 32 – 192 k-samples, 24 bit)
    Volume control:
    • Volume adjustable from -100 dB to 0 dB in 80 1 dB steps
    Dimensions:
    • 100 x 440 x 370 mm
    Weight:
    http://www.aavik-acoustics.com
  4. The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
  5. #503
    Audio Alchemy DDP-1
    沒想到還能看到Audio Alchemy重生,發表了新產品,記得可能快20年前我還有用過他們的DAC呢?主事者Peter Madnick正是Constellation的核心工程師,若能維持以前可負擔的親民路線,那可就太好了,其維持以前的特色,擁有齊全的數位輸入,包括USB, Coxial, Toslink, AES.EBU, I2S等等,類比輸出有RCA, XLR,還有耳擴,DAC採用 dual 32/384 晶片與 FPGA 的路由器,多級鎖相環式的抖動衰減器,無源抗混疊式濾波器,以 discrete FET 形式驅動的輸出級等等。
    在日本的展覽上,我們還看到同時有其他三樣產品亮相!
    http://www.audioalchemy.com/
  7. #504
    有天線的不知是何?
    快20年,擁有的第一部DAC。至今仍有整套系統。
  8. The Following User Says Thank You to BBWW For This Useful Post:
  9. #505
    應該是網路串流DAC吧...............
  10. #506
    附件圖片 附件圖片
  11. #507
    Juno Audio Viotone M One – Violin Loudspeaker
    Juno Audio 所製作的第一款揚聲喇叭,從名字從照片上都可以看出是以小提琴為設計發想。
    Viotone M One 是利用小提琴的木質箱體和自然的形狀來重現最自然的聲音,Viotone 正在為其技術 InstruSound technology 申請專利。
    該揚聲器所使用的木板超過 300 年的歷史,並由具有專業知識、工藝最精湛的工匠細心打造而成,達到即使是優異的音樂家也很難分辨出聲音是由喇叭出現還是真正的小提琴聲。
    Viotone M One 使用高性能的 8 吋 Kevlar 音盆加上釹磁鐵,和鈦球頂高音。並使用陶瓷固態傳感器,並有三個獨立的擴大模組,每個都有 DSP 微調,總共提供 1,500 瓦的能量。
    Viotone M One 的售價約為 25,000 美金。
    Juno Audio: http://www.junoaudio.com/
  12. #508
    Stelle Audio Mini-Clutch Speaker
    Stelle Audio 推出 Mini-Clutch Speaker,具備時尚外型以及多功能攜帶式無線喇叭,而且售價低於 200 美元。
    新的 Mini-Clutch Speaker 具有無線藍芽,可以走到哪,聽到哪。如同化妝包般,打開後還有一面鏡子,非常特別,很適合攜帶外出使用。
    時尚的 Mini-Clutch Speaker 有三種顏色造型,適合各式各樣的場合。Dazzling Diamond ($200),金光閃閃的適合夜晚外出時搭配衣服,不但具有功能性還能成為時尚的配件。Blue Love ($149),提供一個有趣的塗鴉設計,非常適合年輕人的活潑個性。另一款 Metallic Purple ($148),搭配金色元素不論是白天還是黑夜都適合任何一個場合。而搭配的配件也能夠讓 Mini-Clutch Speaker 像包包一樣斜背在身上,打開後除了有一面鏡子外,還能找到放置信用卡、手機、口紅的區域。
    Mini-Clutch Speaker 的無線功能不但能夠隨時隨地利用無線串流播放音樂,能備有麥克風,在電話響起時還能透過他接聽電話。藍芽功能能簡單的對應智慧手機、平板和電腦,內建有 6 瓦立體聲數位擴大機,非藍芽設備可以透過 AUX-in 插孔連結。內建的鋰電池不但能夠撥放長達 15 小時,甚至在緊急的時刻可以為你的手機充電。
    Features
    • Designed to be both lightweight and portable for any stylish occasion
    • Includes interior with credit card slots and room for essentials like lipstick
    • Pocket that fits mobile devices up to 5.5″ x 2.75″ including iPhone 6
    • Contains a built-in mirror for easy on-the-go touch ups
    • Wirelessly streams high-quality audio to any Bluetooth-enabled device including smartphones, tablets and computers
    • Contains a built-in speakerphone for chatting on-the-go
    • Offers voice prompts and easy setup and pairing
    • Offers a removable chain link strap for shoulder bag or cross-body purse wear
    • Contains interchangeable bangle for wristlet wear
    • Features a 15-hour rechargeable battery
    • Offers emergency charge for USB enabled devices, such as mobile phones
    • Connects to non-Bluetooth devices via AUX cable (included)
    • Dimensions: 6.4” (W) x 4.3” (H) x 2.9” (D)
    Stelleaudio: http://www.stelleaudio.com/
  13. #509
    Abendrot Audio
    STUTE & HENGST
    True Digital / Analog Conversion System
    看起來是來自英國的新品牌,推出兩樣產品,STUTE為10MHz的銣時鐘(USD 39,000),HENGST是與STUTE搭配的DAC(USD 36,000),同時還發表了兩台機器間專用BNC線(1M, USD 500)。就規格上來看,HENGST只有AES/EBU與SPDIF輸入,解碼能力為24Bit/192kHz,沒有最流行的USB或網路,類比輸出部份只有一組XLR,以一套總價超過200萬的售價來看,我想賣點勢必將回歸到聲音表現了!
    http://www.abendrot.co.uk/
  14. #510
    附件圖片 附件圖片
