第29頁,共52頁 第一第一 ... 19272829303139 ... 最後最後
顯示結果從 281 到 290 共計 516 條
  1. #281
    LongDog Audio VDti DAC
    £3000
    It accepts DSD over the USB input.
    LongDog Audio
  3. #282
    Thrax Maximinus Dac
    €24000
    Universal DSP controlled discrete resistor ladder 32bit/384kHz audio dac without output buffer or filter at the dac output providing the cleanest possible output signal.
    We also use separate power supplies for (not separate regulators but physically separate transformers and all) the Converters, Clock, DSP and Control logic all with floating ground planes and our unique constant current regulator technology.
  4. #283
  5. #284
    Metrum Acoustics-MK2 Octave DAC
    Metrum Acousics發表一款新的MK2 Octave DAC,是少數DAC不要求Concero or Audiophileo介入即可達到最佳效能。
    跟MK1比較,可支援192kHz和更小的震動,前面板也做小改動,但還是走樸實路線。
    稅前售價€785.00,稅後約€1075.00。
    http://www.nosminidac.nl/Octave_English.html
  6. #285
  7. #286
  8. #287
    Pure Audio Reference Class A Monoblock
    €14400 /pr
    65 watt class A
    Pure Audio Control Preamplifier
    €8100
    Pure Audio Vinyl Phono Preamplifier
    €4400
    http://www.pureaudio.co.nz/
  10. #288
    Amare Musica Silver Passive Power Station
    Case made of 2 mm thick surgical stainless steel, possessing an excellent screening abilities against EMI /RFI distortions.
    Bottom base made of highest quality 10 mm stainless steel, further covered with few layers of thermo hardened paint, to prevent bar against parasite micro vibrations. - Additional internal damping with bituminous- aluminium mats applied to the walls to support anti-vibration even further.
    The best Furutech Inlet G IEC sockets used. Inner cabling executed with solid silver 1.5 mm thick, high polished wire ( 4 N purity ).
    Completely parallel inner circuit for 100% galvanic sockets isolation. ( means every single socket is wired separately, and not taking power from the previous one), no feedback between sockets for highest signal purity.
  11. #289
    OMA Metamorphosis Rack System
    OMA offers the BK 807 amplifier constructed not in a wooden chassis, but in solid, heavy steel. An entirely new look for our 807 triode connected, class A push pull amplifier, but exactly the same circuit and components as the wood enclosed version. The two chassis BK 807M (for metal) can stand alone, but allows OMA a very new way to present audio equipment, by going back to the earliest state of the art.
    The Metamorphosis amplifier rack system is inspired by RCA and Western Electric cinema amplifier rack systems from the 1930's. Metamorphosis dispenses with conventional audio shelving to house the BK 807 Amplifier and PD1 Pre or PD1 Phonostage in a new and elegant way. From the original handmade solid walnut chassis of the BK 807 amplifier, the new metal amplifiers and rack metamorphose into a work of audio art. Taking up a much smaller footprint than ordinary audio shelving would require, Metamorphosis is an aesthetic statement, showing that high end audio does not have to be a collection of boxes on shelves.
    Metamorphosis can be configured in different heights and number of shelves to accommodate any possible combination of OMA components. There is space on the lower stand for peripherals, CD players and DAC's, computer audio or other devices. Composed of two sections to facilitate transportation and assembly, with its rigid, sturdy construction, Metamorphosis allows easy access from all sides, and is visually stunning from all angles.
    Constructed of heavy steel, with black wrinkle powder coat finish.
    Height for four shelf version for BK 807 and PD1 Pre - 62.5"
    three shelf 53"
    width- 32.5"
    depth 22.5"
    As Shown Height 67" X Max Width 32" X Max Depth 22"
    http://oswaldsmillaudio.com/metamorphosis
  12. #290
    SPaudio A400 amplifier
    A400 specs
    Output: 2x 400W 4 ohms, 1 kHz, 1%, 2 x 230 W 8 ohms, 1 kHz, 1%
    Frequency response: 20 to 20 000 Hz +0 / -0.05 Db, 20-550 000 Hz +0 /-3dB
    Slew rate > 185V/us 3.9 Ohm
    S/N: >-100dB 1W / 8 Ohm, > 120 db 20Hz-20kHz ref P nom.
    Harmonic distortion: - 0.001% -200/350 watt 8/4 ohm
    Intermodulation distortion: - 0.001%
    Damping factor: 950 1KHz, 8 Ohm, 620 10kHz, 8 ohms
    Input impedance: 10 kOhm
    Inputs XLR / RCA Balanced / unbalanced
    Outputs Double Opportunity bi-wire connections
    Weight 40.8 kilograms
    Dimensions 450x220x400 wxhxd
    Supply voltage 230 V ~, 50 Hz
    €4000
    http://www.spaudio.cz
