2012-10-10, 10:39 PM
#231
dc10audio The Instrument speaker
$35000
The massive front baffle, measuring 2.25 inches in thickness, is milled of solid active/resonating tonewood. Acting as a backbone for the structure, the solid wood plinth and baffle are loaded with a vacuum-formed multilayered non-resonant elliptical plywood cabinet containing a special 30-inch internal tonewood resonator, or "Instrument," in vintage Rosewood with French violin finish, signed, numbered and photographed prior to installation.
This magnificent loudspeaker features an extra-large 14.5-inch hand-turned solid Maple horn, loaded with our 1-inch textile dome tweeter. The horn also serves as the port (an exclusive innovation).
The Instrument will set a new standard in dynamic realism. From airy violins to the thunder of the deepest bass, sound is delivered with speed and nimble posture. The Instrument is a symphony much greater than its parts and operates as a whole without truncation, using the organic power of the horn to correct the limitations of the antiquated cone/panel transducer. It is beautiful to look at and even more beautiful to listen to.
• Turned solid 14.5-inch Maple horn
• Two 10-inch high-impact bass drivers
• 8-inch full-range papyrus fiber cone driver
• Exclusive horn-loaded tweeter doubling as bass-reflex port
• Special signed and numbered "Instrument" (internal tonewood resonator)
• Solid Sapele active tonewood baffle
• High-efficiency 2.5-way hybrid crossover
• Frequency response: 22 Hz-25,000 Hz
• Sensitivity: estimated 102 dB
• Impedance: 4 ohms
• Cabinet module finished in Sapele (other options available at additional cost)
• Size: 48.5" high x 12.5" wide x 21" deep each
• Weight: 245 lbs each
dc10audio
2012-10-10, 10:40 PM
#232
Stahl~Tek Ariaa USB DAC
Hailing from the heritage of the Opus Series, the Ariaa responds to the needs of the industry as Stahl~Tek brought on additional audio engineers. These new engineers labored under the love of the craft to produce a work of art. Their goal was to matched both their desire for the purest audio as well as a more comfortable price point still within the reach of most audiophiles.
The Ariaa is the result of their endeavor with proven engineering plus certain forms of testing were used that are not found within the general industry. Hailing from the heritage of the Opus Series, the Ariaa features handling audio data up to 24-bit/192kHz, remote control with volume adjustment and full galvanic isolation of all outputs.
Digital inputs include I2S, S/PDIF, AES/EBU and USB 2.0 (asynchronous).
Analog outputs include balanced XLR and unbalanced RCA.
Frequency response is from 0 Hz to 100 Hz, signal to noise ratio is >127dB and dynamic range is >127dB. Dimensions are 17.63" x 15.73" x 4.19" (WxDxH).
2012-10-10, 10:52 PM
#233
這牌子又可以好好研究了
臺灣又沒代理了!
http://www.hegel.com
Hegel HD25 Dac
$2500
HD25 is using AKM 4399 32bit dac-chip.
Maximum sampling rate on the inputs is 24/192.
HD25 has a asynchronous USB input.
Release date: End of November.
2012-10-10, 11:05 PM
#234
Fried Audio announced their premier model as the first in a new series of designs. The Bud Fried Tower "a slim floorstander incorporating a mass-loaded quarter-wave transmission line with three drivers in an MTM configuration - a 20mm ferrofluid–cooled Hiquphon OW2F tweeter and two 7" Peerless Exclusive mid/woofers. The 45" tall tower has a 8.5" face and 14" depth. Specs are 35Hz to 20kHz response +/-3dB, 88dB sensitivity, 4-ohm nominal impedance, 58lbs weight and a minimum power requirement of 35wpc tube, 50wpc transistor."
http://www.friedaudio.com/
2012-10-10, 11:06 PM
#235
"Violin" Vacuum Tube Phonostage
$3800
Click for a larger image
The "Violin" is an all-new design that borrows the best circuitry from the "Trumpet", "Cornet", and "Piccolo" preamplifiers and combines them with microprocessor controlled pushbutton switches and relays for seriously convenient operation and world-class features. The relatively compact chassis has two separate phono inputs (MM and MC), adjustable loading, gain, polarity, and equalization. The front-end MC gain uses low-noise matched JFETs to boost up to MM levels, where the vacuum tubes take over providing all gain, equalization and output buffering. Components used in the design are of superb quality, chosen for their sonics and contribution to the overall harmonic performance of the amplification chain. No corners have been cut.
Features
Pushbutton control
Two inputs
Adjustable loading, gain, mono, polarity
Four difference EQ playback curves
Class-A operation, no feedback
Regulated DC heaters
Passive, split equalization
Cathode follower outputs
Vacuum tube B+ rectification
Specifications
Gain: 44dB (MM) / 54dB, 60dB, 63dB, 65dB (MC)
Input Impedance: 50k (MM) / 955, 305, 170, 122, 84, 70, 59, 52 (MC)
Output Impedance: 600 ohms
RIAA Response: +/-0.5dB from 20Hz to 20kHz
Bandwidth: 6Hz to 500kHz
Distortion: <0.5% @1kHz
Noise: 82dBA (MM) / 74dBA (MC)
Size: 17" x 8" x 6.5"
Weight: 12 lbs.
Power: 120Vac/240Vac 35W
Tube Compliment: 12AX7 x 2, 12AU7 x 2, 5AR4 x 1
http://www.haglabs.com
2012-10-10, 11:07 PM
#236
這家也是Taiwan Dealer Wanted
http://www.centrance.com/
2012-10-10, 11:42 PM
#237
Baetis Audio
The Very Best in Media Computers
· Price without dealer on-site set-up and service: $2995, including a 1.5T external USB 3.0 silent drive. Overseas clients --- Please email us for information on developments in your country. Each machine is custom built, so you must order by telephone, 406-686-4282, or email: [email protected]
The Baetis media server is on the left side of the bottom shelf; less than one-half the size of the high-end CD/SACD player. Below, we have it in Silver – both cases are 100% thick aluminum and built tough.
2012-10-12, 01:31 AM
#238
Zellaton Studio Reference One Speakers
#239
Audiograde Ardora speakers
2012-10-14, 02:13 PM
#240
Ansuz-acoustic's Darkz (footer) and Sparkz. Look out for this brand in future reviews.
http://ansuz-acoustics.com/index.php/home
The Following User Says Thank You to bigtree For This Useful Post:
