第17頁,共52頁 第一第一 ... 7151617181927 ... 最後最後
顯示結果從 161 到 170 共計 516 條
  1. #161
  2. #162
  3. #163
  4. #164
    這個厲害!
    Terpsicore 5000 Rack
    Price - from €5145
  6. #165
    Terpsicore 3000c Rack Series
    3001c
    3001c Double
    3002c
    3002c Double
    3003c
    3003c Double
    3000c
    Prices
    3000c - €1500
    3001c/Double - €2780/5235
    3002c/Double - €3790/7600
    3003c/Double - €4840/8975
    Terpsicore
  7. #166
  8. #167
  9. #168
    Ante Audio Integra Standard One Integrated Amplifier
    €20,000
    150/300 Watt 8/4 ohm
    2x600VA transformers
    48A Output current
    4 balanced inputs
    4 unbalanced inputs
    1 pre out
    Dimensions
    WxHxD - 435x165x515 mm
    Weight - 35kg
  10. #169
    法国南部馬賽製造的EERA CD機,沒有在亞洲發售;聽說模擬味十足;個人對法国的聲音沒投訴,但对機械方面有保留。
    http://www.eera.fr/
    設計司Didier De Luca
    網上評論
    http://www.positive-feedback.com/Issue58/eera.htm
  11. The Following User Says Thank You to alhw845 For This Useful Post:
  12. #170
    D7-CST
    Carbon Support Table
    Available in 2012, Dalby Audio Design announces the D7-CST high performance modular support table for use with the D7 Preamplifier and D7-211SE mono valve amplifers. The D7-CST uses a 5mm thick carbon fibre platform, that is decoupled by a ceramic bearing system.
    The tables can be stacked or used in isolation, with the choice of different column heights to fit your own personal requirements. The carbon fibre platform sits in an open frame of solid mahogany, with exterior brass panels finished in 9 carat gold.
    D7-GE90
    Gabon Ebony Isolation Feet
    Engineered from select pieces of solid Gabon Ebony, the D7-GE90 isolation feet represent an interesting alternative to the D7-CBF. The same ceramic decoupling system found in the D7-CBF is applied, using 4 bearings instead of 3.
    An internal ceramic bearing takes the weight load seated in an inverted brass shaft through its' centre. This keeps the flow of kinetic energy central through the foot, whilst the large Ebony body acts as a resonance dissipater, dampening the contact points that support the equipment.
    The D7-GE90 foot is grounded by an Ebony disc finished with a brass gold plated top surface.
    D7-GE90 Isolation Feet DNA
    • 90mm diameter solid Gabon Ebony body
    • Large Ebony body controls resonance and vibrations
    • 3 point ceramic bearing decoupling system to top surface for minimal contact
    • Inverted central ceramic bearing supporting brass shaft
    • Precision engineered to a glass like finish
    • Available in sets of 3
    Working applications: Preamplifiers, CD players and other source components
    D7 ULTIMATE PREAMPLIFIER
    The D7 valve preamplifier is finished in 9 carat gold plated exterior panels with a Tri-composite chassis made from; Mahogany, copper and carbon fibre isolating feet. Point to point wiring is employed throughout, for the purest circuit and signal transfer, using mono crystal cast copper and mineral loaded soft silver, allowing the retrieval of every harmonic detail. The D7 is a 2 box configuration separating the signals of the head unit from the operation of the power supply. Two ‘KYOKU’ mains transformers are used in mirror mode for ultra silent operation. The D7 comes with a 1.8m dedicated pure silver umbilical cord to connect to the PSU, while the head unit is supported by specially designed carbon fibre feet which employ a 3 point ceramic bearing system. These feet can be replaced by the D7-GE90 Gabon Ebony feet as an optional extra on request.
    The D7 Preamplifier configurations:
    • D7-L Line level preamplifier with outboard power supply
    • D7-LP Integrated line level and phono preamplifier with outboard power supply
    • D7-P Phono preamplifier with outboard power supply
    The D7-L and D7-LP preamplifiers can be fitted with the D7-ICB (Isolation Capacitor bank) for bi-amp and tri-amp mode, while mechanically isolating the head unit from further kinetic interferen
