2011-02-23, 10:43 PM
#101
Liquid Fire
Expected Availability: May 15, 2011
Price: $2750
Pre-production amps will be available for review in early March and the subscription buy will be opened.
Features:
- Fully DC Coupled Hybrid - No Caps in the Signal Path
- Tubes Provide the Voltage Gain
- Transistors and Mosfets Provide the Power Output
- Separate HV and LV Regulated Rails for the Tubes and Transistors
- 6922 Differential Amp Input Stage
- 6922 Voltage Gain Stage with 6922 Current Source
- Mosfet Output Stage Biased at 100mA to Run Class A Most of the Time
- 3W into 32Ω. 650mW into 300Ω
- Inline Capacitance Multiplier Filters Provide Super Clean Rails for the Input and Gain stages
- Wide Theoretical Bandwidth: -1db from 1Hz to over 1MHz
- Voltage Gain Approximately 18.5db (8.5X)
- Input Impedance: ~50kΩ
- Output Impedance: ~1/4Ω
- Opamp Servo Ensures 0VDC Offset
- Regulated DC Heater Supply for Hum-Free Operation
- 20 Second Heater Delay Circuit w/ Indicator Lights
- 20 Second Output Delay and Offset Detection w/ Indicator Lights
- Custom, US made RCore transformer
- Comes with JJ Tesla 6922 tubes, burnt in for at least 25 hours
- Engraved Windows So You Can See The Tubes!!
http://www.cavalliaudio.com/
2011-02-24, 12:14 AM
#102
2011-02-27, 10:37 PM
#103
2011-02-28, 12:02 PM
#104
2011-03-01, 11:59 PM
#105
Bindesbøl Audio
2011-03-06, 09:07 PM
#106
TRACK AUDIO
The 600 stands in black or silver.
600 mm high and available with a choice of top plates :-
W180mm x D200mm or W240mm x D280mm
£1300 a pair
Product Features
Height adjustable stand mounts
Ball locking finely adjustable feet
Uniquely designed spikes
Built in bubble spirit level
Stands come complete with hard floor spike protectors
Designed and Manufactured in the UK
CNC Machined
High specification certificated materials
Manufactured by an ISO 9001 registered company
10 Year Manufacturers Guarantee on all parts
All stands can be purchased in pairs or single units for use with AV centre speakers.
Bespoke colours are available on request.
All prices are UK only and inclusive of v.a.t
www.trackaudio.co.uk
2011-03-07, 07:53 PM
#107
NAT single
Design Features - single ended type - integrated amplifier
- zero feedback design
- triode direct-heated output type
- 50 W of pure class A (@4ohms or @8ohms,set on front panel)
- full dual mono construction
- custom designed double toroidal encapsulated power transformer
- full stabilisation for all amplifier stages
- two tubes (NOS) for driver purposes
- separate toroidal transformer for digital control
- dot-matrix display (15 level of intensity with turn off mode)
- remote control made from solid block of aluminium
- automatic bias
- adaptive bias (to control dissipation of the output stage)
- standby function
- relay (silent type) attenuation network
- all aluminium modulated chassis
- teflon isolated input connectors
http://www.nataudio.com/products/Single/Single.htm
2011-03-08, 09:25 PM
#108
刚买了部样板机:aaronno.1.a 合併機,是德國Sovereign的小弟。
2011-03-13, 09:47 PM
#109
Element 47 cables
Black Widow Interconnect cable xlr or rca 2x1m - €2625
Geisha digital rca or xlr 1x1m - €1630
2011-03-22, 12:53 AM
#110
Aurelia
Aurelia Graphica
€8000
The Aurelia Graphica is a 2-way cylinder wave radiator, where the lower frequencies (below 1.5 kHz) are produced by six DDC Isomatrix-bass units which are placed in a line. The upper frequencies are reproduced by a new innovative tweeter-system which we call the Cylinder Source Radiator. The CSR-waveguide generates a coherent cylindrical waveform for upper frequencies, behaving in a similar way to ribbon tweeters, but without the restrictions which are typical for these.
Thereby, the Graphica reproduces the whole frequency range so that sonic waves proceed to the listener in a cylindrical form instead of in an omnipolaric form which is typical for traditional solutions. In this way, reflections from the floor and ceiling are almost completely eliminated.
http://aurelia.fi
