第27頁,共52頁 第一第一 ... 17252627282937 ... 最後最後
顯示結果從 261 到 270 共計 516 條
  1. #261
    CT-1 Interconnects: $1600 for 1 meter (each additional 0.5 m is $200)
    http://www.highfidelitycables.com
    http://www.hpsoundings.com/2012/12/h...interconnects/
    The CT-1E interconnect is the first in a new line of products released by High Fidelity Cables which feature our patented Magnetic Conduction technology. Once you experience the clarity and lack of distortion Magnetic Conduction brings to your audio system, there is no going back to older cable technologies.
    $2800 for 1 meter
    (each additional 0.5 m is $350)
    • ENHANCED VERSION
      The CT-1E has all the features of the normal CT-1 along with the following:
      A new conductor alloy is used in the enhanced version which has a greatly increased ferromagnetic permeability for increased levels of Magnetic Conduction and peformance.
      The conductor is treated with a proprietary material that lowers dielectric absorption so signals are not held back by the change in electrical charge of the teflon dielectric.
      The PinLok connector has been redesigned for increased ferromagnetic permeability in the pin itself. This allows low level signals to move more easily into the conductor.
      Precision 24K gold plate is applied at 300 microns which is double the industries thickest plating standard. The ground ring is also plated to help ensure optimal low level signal performance.
  2. #262
    Daber Audio Products
    Monitor 3
    Tired of always wanting more? More output? More low end extension? More realism? More value? A wider soundstage? Congratulations....your search is over. No speaker in it's price range can compete with Daber Audio Monitor 3. At Daber Audio, we are Redefining Affordable High End. These speakers offer superb imaging, incredible detail, solid bass performance, amazing soundstange width and height. Soundstage placement so realistic you feel like you can touch the performers, shimmering cymbals, horns that glimmer and shine, piano that seems as if it were being played in your listening room, detail retrieval of an unmatched caliber in it's price point can all be yours. Packaged neatly together in a cabinet that you will find beautiful, finished in either Cherry Veneer or Piano Black.
    As new speakers they come with a 3 year warranty covering workmanship and mechanical/electromechanical failure. Abuse, such as overpowering, is not covered. Each pair is made to order, so please allow 7-10 days lead time. Features/Specs 8 inch Magnesium/Aluminum woofer 2 inch Aluminum dome midrange Planar Tweeter Satin Nickel binding posts Hand built crossovers using hand selected parts 150 watt RMS power handing 91 db efficiency 35-21k response 8 ohm nominal impedance Rear facing port 32 pounds each 22" H X 9" W X 14" D Price - $1,799
    http://www.daberaudio.com
  3. #263
  5. #264
    Absolare Bybee Omni Purifier and Loudspeaker Bullets
    Euro 3000
    Euro 3500
  6. #265
    這個音響架感覺很厲害
  7. #266
    引用 作者: star 查看文章
    這個音響架感覺很厲害
    敗吧~......................
  8. #267
  9. #268
  10. #269
    Lamm LP1 Signature phono preamplifier
    $33000
    Booklet
  11. #270
    Soniccraft Odin Revolution Mono Amplifiers
    $75000 /pr
    Power output 8/4 ohm - 800/1600 watt, Class A up to 40 watt
    S/N 105dB
    Size WxHxD 24x49x53 cm
    Weight 60 kg each
