2012-12-29, 12:28 AM
#271
Zellaton Grand with Downfire Woofer
2013-01-14, 11:20 PM
#272
2013-01-16, 03:25 PM
#273
2013-01-17, 11:29 PM
#274
Struss R550 Integrated Amplifier
€35000
The Struss R550 is a new generation amplifier, offering an extremely dynamic and detailed sound, while still natural and without the distortions associated with transistor devices. The chief constructor's dream was to obtain the "live music" effect at home. The dream came true after years of work on the Struss R550 the effect of live music with the particular associated system has been reached. Many owners of the Struss R550 amplifier confirm the above opinion. Also Russell Kauffman (Morel Europe) gave the R550 very good feedback, stating that today it is the best and the most powerful amplifier in the world (dual mono). The opinion was formed after many hours of testing of the R550 width the best Morel speakers "Fat Lady".
The Struss R550 amplifier does not possess its own features. Instead, it reinforces exactly what it is given and gives out everything that the speakers can cope with. The technical solutions used are owned by the company and are registered with the numerous patents. The amplified channel constitutes a fully balanced system supplied with two electrolytic compensators with a total capacity of 176 000 uF and two toroidal transformers with a capacity of 2.0 kW (2.8 kW peak), each magnetically and electrostatically shielded. It is the tradition of this company not no include any bipolar transistor in the entire amplified system.
The surreal design is not a matter of chance. The beauty of its compact design is combined with the graphics of one of the most successful post-war Polish artists, the author of many prominent surrealistic works of the contemporary art.
The launch of the new R550 Struss amplifier by the Struss Amplifiers Company proves that the most powerful amplifier in the world (2 monoblocks) can be designed and produced in Poland.
Technical parameters:
Power RMS/Music: 2 x 550 W/8 Ω, 2 x 1000 W/4 Ω (DIN 45500)
Minimum load: 0,5 Ω (momentary)
Distortions THD: 0,05 % with a power of 1 W, 0,025 % of the power of 500 W - load 8 Ω
Frequency Response: 2,5 Hz - 300 kHz +/- 0,05 dB/ 1 W/ 8 Ω
S/N ratio: 145 dB (IHF - A)
Dynamic Range: 140 dB
Inputs: 4 x Universal - RCA, XLR (balanced), separated CD - RCA voltage output for external devices
Security system: advanced against short-circuiting of the speakers and the appearance of the output voltage
Indication of "peak": approaching the maximum output
Transformers: 2 x toroidal, magnetically and electrostatically isolated, power 2000 VA each
Remote control: RC5 code (volume)
Power consumption: 200 VA - 4 500 VA (peak)
Work in Class A: 2 x 55 W
Net weight: 54,5 kg
Dimensions: 530,3 x 155 x 430 mm
The amplifier meets all the requirements and standards applicable in the EU
Manufacturer Warranty: 36 months
2013-01-17, 11:30 PM
#275
Purity Ultra & Ultra GT
The Ultimate Dual Mono, Transformer Coupled, Class A Balanced Linestage
The "Ultra Series" is a no holds bar product for requiring the absolute best. In addition to all the features found in the Purity Silver Statement, the Ultra brings to the table further enhancements that bring the Ultra into a class of it's own.
The Ultra dual mono balanced linestage is a result of years of intensive research directed at attaining the most accurate reproduction of recorded music. Unique topology and application of the most advanced technological resources and processes bring the Purity Ultra to a threshold of excellence in sound reproduction that has yet to be experienced or equaled.
The Series II brings to the table not only a newly design aluminum chassis but also several enhancements to the circuit including new custom made balanced input transformers, highly regulated DC filament supplies (one per channel), new grounding scheme and a new layout design.
The new Series 2 circuit is optimized for both the 6SN7 and 12AU7 tube types. The 6SN7 octal tube sockets are standard on the Ultra series models and all units come equipped with Sophia Electric 6SN7 tubes. Also included is an adapter allowing you to start rolling 12AU7 tube types for even more versatility.
A distinctive feature of the Ultra GT setting it apart from it's competition is it's multiple large capacitance storage banks. Each of the two channels contains 12 large value polypropylene capacitors allowing the Ultra to provide the fastest and tightest dynamics available from a vacuum tube linestage. In addition to the large power rails, also featured in the Ultra is the use of multiple Bybee Quantum Purifiers per channel as well as the latest Bybee Music Rails. One Music Rail per power supply providing a dead quite, black background and ultra low noise floor.
To add to it's main features, the Ultra utilizes 100% silver transformer coupling at both the input and output stages on the GT version. All signal wire is a high grade solid core OCC silver. Transformer coupling output results in a low output impedance making for better integration with any type of amplifier as well as providing an uncanny sense of transparency and resolution Highest quality Dueland copper foil capacitors (with built in Silver bypass on the GT version) are used in the final stage of the circuit with all signal wire duties handled by “VH Audio OCC Silver AirLok” hookup wire. Attenuation is handled by a balanced autoformer design. The GT version brings to the table Silver Bybee purifiers feeding the inputs. Also available by special order are Pure Silver Autoformers for those who appreciate what a silver signal path brings to the table. Located at the output stages is two more pair of Silver Bybee Purifiers. Extraordinary transparency of perceived sound which in turn assures the recreation of a three dimensional soundstage.
The Ultra GT contains a total of 10 Bybee Quantum Purifiers. Four large units found in the power supply and 6 Silver Purifiers found in the signal path providing the absolute best in transparency, resolution and extension at the frequency extremes.
An additional feature of the Ultra is the use of a pair of secondary autoformers feeding the input of the tube circuit allowing for six different levels of output gain to match the Ultra with any power amp on the market. In addition to this feature, the Ultra also has the ability to run in full passive mode while still retaining full transformer coupling as well as the benefits of all the Bybee Purifiers in the signal path from input to output.
Extensive research, testing and listening led to unique, innovative design that achieves very low distortion and wide bandwidth without the need for negative feedback which destroys transient purity.
The full function remote handles volume, mute, balance, source select and phase as well as being able to completely turn off the display. The very precise autoformer attenuation provide 1dB increments.
The power supply is quite possibly the first of it's kind in the industry. The power supply contains a total of 12 large value polypropylene capacitors that make up the Ultra choke filtered power supply storage banks. Each of the two independent DC rails are then fed into Bybee Music Rails further reducing any potential residual noise.
Bybee Quantum Purifiers are installed in both legs between the transformer secondaries and the rectifying stage.
The Ultra's power supply provides what we believe to be the cleanest, most noise free B+ voltage found in most any audiophile product in the industry today.
Price: Starting at $25,995
2013-01-17, 11:31 PM
#276
Dalby Ultimate Ground Wire U-1000
DAD is proud to announce the exclusive D7-1000UE Earth cable. Handmade using mineral loaded pure silver and mono crystal litz copper conductors. Clothed in 9ct gold over brass housings with solid silver spade terminations. Rated conservatively at 70A.
Available in 1.8m and 2.5m lengths. TSP. £5,995.00 GBP (1.8m)
2013-01-31, 12:42 AM
#277
2013-02-13, 10:18 AM
#278
2013-03-03, 11:04 PM
#279
2013-03-08, 03:52 PM
#280
SILVER DRAGON-Audiobyte
集合DAC和耳機擴大機,具有USB連接並支援DSD。
這是D/A?還是擴大機?或是耳擴?這結合了以上三種功能。
*獨特的數位處理架構
使得Silver Dragon相當獨特,不使用現成晶片,而是專用的硬體建立出FPGA晶片,形成強大且特製的前端晶片。使用Synchrono reclocking和消除抖動的技術實現了卓越的性能。讓訊號再進入DAC前的抖動下降到0.3picoseconds。
*雙單聲道轉換是數位輸入階段是一個完美的補充。每個DAC晶片在完全平衡的模式下處理一個聲道,以更好地模擬類比表現和抑噪。
*非同步USB可支援24bit/192KHz PCM。
*DSD的處理能力使Silver Dragon提供精湛的音質。
*完全分離、平衡、零反饋的A類放大,耳擴部分推動從低到高阻抗的耳機都沒有問題。
TECHNICAL SPECIFICATIONS:
Inputs :
1) USB receptacle, typeB, high-speed
2) S/PDIF coaxial, 75 ohms
3) AES/EBU, 110 ohms
4) Toslink
5) I2S/DSD over HDMI (LVDS)
Outputs :
1) Single Ended, 10Vpp max.
2) Balanced, 20Vpp max.
3) Headphone jack 6.3 mm, 10 ohm impedance
Supported sample rates:
1) 44.1k - 192k on S/PDIF, AES/EBU, I2S, USB
2) 44.1k-96k on Toslink
3) 2.8 MHz for DSD
Bit depth :
1) 24 bit on all inputs
Compatibility (usb) :
1) Drivers for MacOS
2) Drivers for Linux
3) WASAPI, KS, DS drivers for Win XP to W7 32/64 bit
4) Recommended players : Foobar2000, Audirvana , Jriver18 etc.
General specification:
1) Power consumption (max): 35 W
2) Dimensions : 240 x 300 x 90 mm
3) Weight : aprox. 4.5 kg
http://www.audiobyte.ro/silver-dragon.html
The Following User Says Thank You to Ted Chen For This Useful Post:
