2013-08-20, 06:16 PM
#341
Dalby D7-1000Um and D72000RSc
D7-1000Um balanced interconnect with solid ebony resonance control.
2013-08-22, 12:29 AM
#342
Dalby Abishai Horn Speakers
2013-08-31, 09:59 PM
#343
The Moon Audio Opulence is a state of the art audio transducer system designed to redfine what is possible in home music reproduction. A strictly limited edition run of only 10 pairs will be produced, each pair hand-signed by the designer.
The Opulence is the latest in the series of what Moon Audio calls its "ultra-limited edition functional acoustic art works". Moon Audio sells its limited edition products to a refined client base offered exclusively through HigherFi, the world’s largest retailer of ultra-luxury audio products.
Each unit is hand-crafted using the world's best materials, parts and drivers and manufactured in the USA. The Opulence weighs over one ton due to an integrated internal vibrational control system derived from stealth fighters and tactical submarine technology.
The Opulence also employs innovative magnetic control systems developed from nuclear reactor containment to structure internal magnetic fields in a way that is non-damaging to music reproduction. The designers of the Opulence have been involved in the ultra high end audio industry internationally for the past 25 years where they methodically crafted the crucial design elements integrated into the products design. Installation and set-up in the customers home anywhere in the world is included in the purchase price.
These speakers play lound, go deep and are silky smooth without adding any coloration.
SPECIFICATIONS:
Finishes: Any adonized color
Frequency Response: 15Hz to 90Khz
Impedance: 8 Ohms
Efficiency: 96db
Connectivity: Single or Bi-wire or Bi-Amp
Dimensions: 72" (H) x 18 1/2" (W) x 32" (D)
Weight: 3,100lbs
Retail Price: $1,100,100 / pair
2013-09-03, 04:30 PM
#344
新生純国産ブランド「 HIRO ACOUSTIC LABOBORATORY 」から、アルミのインゴットから削りだしのスピーカー登場!!
HIRO-SYSTEM modelCCC
HIRO-SYSTEM modelCCC2
HIRO-SYSTEM modelDOCMC3
アルミのインゴットから削りだしで作られたエンクロージャ(中・高域用)とアクトン社のユニットとノードストの内部配線を使用。
http://www6.shizuokanet.ne.jp/hima_3/index.html
2013-09-03, 08:06 PM
#345
2013-09-06, 04:45 PM
#346
Echole Omnia Cables
The Omnia line of Echole is the most expensively built cable in the market today. The idea is the massive usage of the most precious Silver Gold Palladium alloy derived through a research and development program of 3 years.
The final result is reflected as the most organic and life-like, defining naturalness and musical involvement in high-end audio. All audiophile parameters evolve significantly together with a musical involvement that all of our clients state as a paradigm shift. Several opinion leaders in the globe have already stated the Omnia line as their current reference.
Signal (Pr channel) : Several Runs of Teflon-insulated, Solid-Core OMNIAgrade SilverGoldPalladium, hand-braided and fully symmetrical. Termination: Palladium-polished Silver Oyaide terminations.
Powercord : Several Runs of Teflon insulated Solid-Core OMNIA-grade SilverGoldPalladium and several runs of HPDE-insulated, stranded, 8N purity copper. Termination: Palladium-polished Silver Oyaide terminations.
http://www.echole.com/
2013-09-19, 10:24 AM
#347
2013-09-19, 04:25 PM
#348
2013-09-22, 05:43 PM
#349
Andrea Pivetta “Technology Designer”
The Pivetta “Opera Only” project
“ Opera Only “ is a creation of Andrea Pivetta, an Italian designer who for more that twenty years has worked with various companies leaders in different sectors, from mechanics to electronics, experimenting innovative materials.
In the field of sound, he has always wanted to walk the original and unconventional streets, beginning with his “ Pivetta Opera One “, a multi-channel amplifier that still amazes for its many constructive peculiarities.
His latest creation, Pivetta “ Opera Only “ is a product that absolutely differs from everything that normally you can imagine in the field of amplifiers.
This artifact, based on intuition, imagination, genius solution, this object gets out of any scheme, dealing with absolutely unexplored land, and from the first contact, leaves speechless.
Apart from the enormous power that is able to develop and the grandeur of its structure, Opera Only is a fantastic and unique crossing between sophisticated technology and art: it is, in fact, the most surprising mix of creativity and technology applied to the high-end audio devices.
Style, shape, design and performance to the state of the art!
The huge size of Pivetta “ Opera Only “ is not only the result of the technical requirements necessary to be able to provide 160.000 watts, but also comes from the desire to create something very special and unique from a visual point of view.
Having at disposal and operating this device, it may be an absolutely thrilling experience: its “ comes to life “ open and light, foresees the power of its performance. It is not only a technical and functional tool, but a work of art that fascinates and involves in its articulation.
We believe that it is not possible a simply description of the object: the fascination of its operation is absolutely indescribable and it can be only experienced.
Pivetta “ Opera Only “ reflects the expression of creativity, complemented by the inside high-quality audio technology. The external structure is made of aircraft aluminum and the openings or connections are not visible from the outside, and if he or it is switched on, we feel the “Phoenix from the ashes” equivalent – the spectacular act of awakening, which you just have to experience personally.. When turned off, it is an impressive black 12-sides prism, but its structure changes completely once the device is turned on. It is divided into six distinct sections to reveal all the electronics at a glance.
Suddenly you have the impression that you are looking into the technology space.
The Sound must be experienced. In a high-end studio. At a trade show.In our showroom in ITALY. And at some point, preferably at home. However, it is quite easy to imagine how the Pivetta "Opera Only" sounds before being able to audition it. A look at the amplifier is all it takes. Purity and power. The Pivetta "Opera Only" sounds as it looks.
During last High End Munich 2013 we have been invited and Pivetta “ Opera Only “ had a great success. It was the most admired, photographed and envidiest object in all the Exhibition: 30.000 click in 3 days on YouTube.
For the first time the visitors could see live and in colour an unique and unrepeatable work of art.
Technical data: Opera Only
General
Power input 230/400V 50/60 Hz 800 Amp
Power input low 110/230 50/60 Hz 16 Amp 3000watt
Output power 2 x 60.000 watt RMS Class A
Output multich. 6 x 20.000 (or 12 x 10.000) watt RMS Class A
Transistors 2112 High current bipolar output
Control Console elo touch 15,6”
Lighting laser diode - led RGB
Chassis Aeronautic aluminum treated with NECE interference Completely absent from connections and openings
Dimensions:
1250 x 1900 x 1250 mm (width x height x depth, closed)
1850 x 2500 x 1850 mm (width x height x depth, open)
Weight: 1,500 kg
Housing:
No visible connection boxes or inputs, aeronautical, high-grade NECE treated aluminium.
Andrea Pivetta
Via dell'industria,6
36010 Cogollo del Cengio
Vicenza, ITALY
www.onlycreative.it
[email protected]
+39 3209721807
+39 3475850876
Video:
Pivetta Opera Only | High End 2013 News
http://www.youtube.com/watch?v=9EX3VWp91Es
MESSE live.tv HIGH END 2013 TV-Journal:
http://www.youtube.com/watch?v=U2vgFQnx84Y
Beitrag n-tv Ratgeber Hightech über die Highendmesse in München
http://www.n-tv.de/ratgeber/Sendunge...e10568136.html
2013-09-23, 07:06 PM
#350
Doxa 61 amplifier
Like the 8.2 speakers this is something very special.
Phenomenal sound from this single-ended amp.
Doxa 61 is our ultimate musical achievement. It is our reference amplifier.
We handcraft all our amplifiers at our own factory in Kristiansand - Norway. Only the very best of components are used trough out. We try to make everything work optimally with as few components as possible. If the job is done just as well with one transistor instead of two we use one. We use parts of only the highest quality. Poor components sound bad and does not last long.
We offer a 25 year warranty and can not settle for the industry standard as far as component quality is concerned. We want to give you the best sound possible for years to come.
Some design features:
Single Ended operation
Zero feedback
Oversized power supply
Ultra short signal path
Aluminium chassis
The Model 61 sounds even better due to new inventions that has never before been seen in Audio or electronics in general for that matter - however, don't ask us about this - we don't give out answers with regards to our secret technology.
Just listen!
You might wonder why there is less specified power output in the Model 61. We use smaller but better transformers in Model 61 which sound...better. The Model 61 is also more expensive to build due to parts quality. In reality the Model 61 sounds, just not better, but more powerful than the Model 74.
Specifications
Technology:
Single Ended SolidState circuit
Power Supply:
app. 1000VA
Output Power:
35 watt 8 Ohm
70 watt 4 Ohm
140 watt 2 Ohm
Freq. Response:
5-1,6 MHz
Input Impedance:
10k ohm (Mainly Resistive)
Output Voltage max:
30 volt RMS, 220V AC
THD
Less than 5 %
Weight:
21 kg
Dimensions:
43*43*14 cm (w*d*h)
Green Credentials:
Never above 23 watt in idle mode
Handmade with pride, care and skill in Kristiansand – Norway
Lead free silver solder.
Warranty:
25 Years
30 day Money-back-guarantee
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
