2012-08-25, 09:29 AM
#711
2012-08-26, 09:36 AM
#712
2012-08-26, 09:39 AM
#713
Pink Floyd on B&o
http://www.worldrecords.me/notion.html
The Cure on B&o
Ac Dc on Dual
Little Richard on Garrard
The Party on PE
Joy Division on Revox
Eagles on Sony
Motorheah on Thecnics
The Velvet Underground on Thorens
The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
2012-08-26, 10:58 PM
#714
Ikeda KAI Reference M/C cartidge
weight: 10gr
Stylus Force: 1.8gr 10Hz-45kHz
IKEDA Sound Labs new KAI Reference MC cartridge is the highlight of over four decades of experiences in cartridge design.
The new KAI moving coil cartridge is the culmination of technology and craftsmanship to now represents his best efforts to date.
High quality materials and components include:
The body unit being crafted from solid aluminum alloy.
The base of the cartridge to sustain the generator unit is made of titanium
The cantilever is made of Boron to ensure proper delivery of oscillation.
Highly efficient Permalloy core, low impedance coils, ideally shaped magnet yoke and the generator unit embedded a samarium-cobalt magnet are further highlights of the new IKEDA KAI MC cartridge design.
Each cartridge is hand assembled, precisely aligned and inspected one by one.
Output voltage is 0.19 mVrms, coil impedance is 2.5 Ohms and appropriate stylus force is 1.8 gram (+/-0.2 grams). Frequency response is from 10 Hz to 45 kHz, channel separation is over 27dB and channel balance is within 1.0 dB. (1kHz).
The newest flagship Ikeda “KAI” MC cartridge is the very special model that uses the high quality materials and components in each part of cartridge in order to further improve the performance of conventional models.
The body unit is made of a solid aluminum alloy by lathing a piece of aluminum alloy one by one precisely. The base of the cartridge to sustain the generator unit is made of the strongest ally, that is, Titanium. This strongest Titanium will bring out thoroughly the possible abilities of both of the micro-ridge stylus chip which will be able to trace a groove accurately upto the super high range and also of the cantilever made of Boron which can secure a superior delilvery of oscillation.
In addition, thanks to the highly efficient Permalloy core, low impedance coils, ideally shaped magnet yoke and the generator unit embedded a samarium-cobalt magnet, it is possible to reproduce the sound as close as the original at the highest level.
Ikeda “KAI” cartridge is always sophisticatedly assembled, precisely aligned and inspectingly produced one by one by spending a plenty of time with the fulfillment of various kinds of conditions required for the best phono cartridge as a playback device, for an instance, in order to extract the musical elements as it is recorded in LPs/SPs, especially the outperformance hidden in the specifications.
Specifications
Electromagnetic Generator : Moving Coil (MC)
Output Voltage : 0.19mVrms (1kHz 35.4mm/sec. at 45° peak)
Coil Impedance : 2.5 ohms.(1kHz)
Appropriate Stylus Force : 1.8gram ± 0.2gram
Frequency Response Range: 10Hz ~ 45kHz.
Channel Separation : over 27dB (1kHz)
Channel Balance: within 1.0dB (1kHz)
Stylus Chip : Micro-ridge sold pure diamond.
Cantilever: Boron
Weight : 12grams
Compliance : 7 x 10-6cm/dyne
Change of stylus : Change of generator unit including stylus coil.
Connecting terminal: Right channel: Hot --- Red. Ground --- Green
Left channel: Hot --- White. Ground --- Blue
2012-08-28, 12:31 AM
#715
2012-08-29, 12:56 AM
#716
貓王!
2012-08-29, 10:12 PM
#717
2012-08-30, 01:00 AM
#718
2012-09-01, 11:29 PM
#719
2012-09-02, 09:23 AM
#720
Sperling M-2 Turntable
25 kg platter
Bearing with Silicon Nitride Ceramic Ball
The sound is exceptional, one of the best turntables in this price class. It can compete with other turntables up to around €50000.
Price is €22000
Sperling
