2012-03-23, 11:45 PM
#581
Sumiko announced the entry-level Debut Carbon Turntable, successor the Pro-Ject Debut III, which sets a new standard in terms of performance and value. The most profound upgrade is the addition of the 8.6" completely carbon fiber tonearm that increases stiffness while decreasing unwanted resonances resulting in a higher fidelity presentation of your treasured recordings. Fitted to the carbon fiber arm is a true high-end cartridge, the 2M Red by Ortofon. This arm/cartridge combination is quite capable of exceptional tracking and recovery of the musical nuance found within the records grooves. The attractive resonance-reducing MDF plinth supports a heavier 300mm diameter metal platter for smoother rotation and lower wow and flutter.
Additionally, a felt record mat is employed for superior record support and coupling. The platter and plinth assembly sits upon four-point "O"-ring feet designed for energy absorption and the plinth-mounted motor is isolated by a new Sorbothane suspension keeping unwanted noise and vibration to a bare minimum. Chassis mounted RCA output jacks allow for the use of higher quality interconnects for even better sonic performance.
Price and Availability
The Sumiko Debut Carbon will be available April 2012 for $399 in seven high-gloss fashion colors (Black, Red, Green, Blue, Yellow, Silver or White) and a full-sized hinged dustcover is included. See more about: Turntables, Sumiko Turntables.
2012-03-28, 11:46 PM
#582
From Danish music lover Soeren Hartvig comes the Hartvig TT Signature turntable with battery power supply "to ensure incredible reproduction of sound and distinguish itself from digital media as the analog sound is both smooth and reproduces the music down to the last detail.
Hartvig Audio will be represented with a booth in Munich Exhibition in Room 120f.
2012-03-31, 12:11 AM
#583
The Absolute Sound Guide to Vinyl Playback-2012 is an online buyer’s guide that helps audiophiles and music lovers choose among the latest high-performance turntables, cartridges, tonearms, phonostage preamplifiers, vinyl accessories, and terrific-sounding LPs.
The 2012 Edition of the Guide includes:
• “On The Horizon”—twelve (12) capsules of promising analog gear about to be released.
• “The Ten Most Significant Turntables of All Time”—a look back at ten turntables that help explain the enduring popularity of vinyl playback.
• Fifteen (15) Expert Reviews of Turntables.
• Twelve (12) Full-Length Reviews of Phono Cartridges.
• Seven (7) Expert Reviews of Phono Preamplifiers.
• The Absolute Sound Editor’s Top Picks for turntables, tonearms, phono cartridges, and phono preamplifiers.
• “Behind the Scenes At Mobile Fidelity”—learn what makes this legendary label’s vinyl reissues sound so good.
• “The 100 Best-Sounding Vinyl Records”—the TAS team recommends recordings that offer the unbeatable combination of great music and superb sound quality.
Note: Download may take up to several minutes to complete. Thanks for your patience.
__________
The Absolute Sound encourages readers to support the following sponsors and advertisers who made the FREE distribution of this Guide possible.
Premier Sponsor
• Music Direct
Advertisers
• Better Records
• Channel D
• KEF
• Merrill Williams Audio
• Musical Surroundings
• Pass Laboratories
• Reference Recordings
• Walker Audio
2012-03-31, 12:44 AM
#584
Terpsicore Tonearm Bases
Base Reference - from €900
Base Reference Stand - from €3655
Vinyl sound reproduction is achieved starting from a high quality capture of information. At present, there are many well manufactured plates, tonearms and capsules to choose from but we've added more control over positioning, resonance and synergy for both the Tonearm and capsule thanks to our TERPSICORE tonearm base.
Whatever your plate, you can better incorporate the capsule and tonearm to achieve a more realistic musical experience. Our TERPSICORE tonearm base is compatible with all existing models.
The Following 2 Users Say Thank You to Leo Yeh For This Useful Post:
2012-04-02, 09:09 PM
#585
2012-04-04, 08:17 AM
#586
Audio Fidelity supports all of the Indie Retailers around the world that are participating in Record Store Day On 4/21/12! Make sure that you get our LIMITED EDITION Record Store Day Release, "Spot The Pigeon" from Genesis an AWESOME 12" Blue Vinyl split-speed (33 1/3 & 45 RPM)! EVERY GENESIS FAN MUST HAVE THIS IN THEIR COLLECTIONS! This will SELL-OUT FAST!
2012-04-04, 02:26 PM
#587
The Following 2 Users Say Thank You to acapellaaudio For This Useful Post:
2012-04-04, 11:55 PM
#588
2012-04-05, 01:22 PM
#589
2012-04-05, 02:53 PM
#590
