第52頁,共158頁 第一第一 ... 242505152535462102152 ... 最後最後
顯示結果從 511 到 520 共計 1578 條
  1. #511
  2. #512
    預設 DaVinci Master Reference Virtu tonearm
    Da Vinci's latest masterpiece Master Reference Virtu. Peter Brem's original invention of 4 point gimbal bearing. Finish of the bearing and the arm of the Virtu is comparable to a Patek Phillipe watch.
    These are a few highlights:
    Invention of a 4 point gimbaled magnetic- sapphire bearing
    Better VTA adjustment
    New azimuth adjustment
    Optional accessories available at a later time: Exchangeable tone arm tube for better matching with different cartridges.
    The basis version is an hybrid arm tube made of ebony, steel and aluminum with an SME adapter:
    Master's Reference Virtu tone arm is a precisely engineered product with uncompromising quality with vaunted Swiss precision evident in its design.
    Description pictures:
    Jewels created by Zigerli-Iff, Bern, Switzerland
    White-gold with Turmalin
    Patek Philippe (Men's complicated watch - world time platinium) meets DaVinciAudio's new tone arm.
  3. #513
    TW Acustic Raven One Turntable w/Raven AC Controller
    Pre-owned and I'm Loving it!
    November, 2011
    http://www.stereotimes.com/acc111811.shtml
  4. #514
    引用 作者: SGIREM463 查看文章
    Linn Troika
    Introduced 1986, 當時 Linn 的旗艦唱頭
    幾個月前收了一個 Sound Smith (USA) Retip (全新) 的, 一聽驚艷.
    到現在一共收了三個, 除了 Sound Smith Retip 之外, 一個是原廠未改,
    一個是英國 Expert Strylus Retip (2011 二月 Retip, 極新)
    Sound Smith 細節多, 溫潤如管機, 音場寬廣, 低頻驚人, 讓人覺得聽 LP 真是幸福.
    Expert Stylus 保有 Sound Smith 絕大部份優點, 聲音較中性, 透明度更高, 速度快, 循軌似乎更上ㄧ層樓.
    這兩天比較 Expert Stylus Troika 跟 Lyra Skala, 整體明顯較喜歡 Troika. 唯 Skala 似乎在高頻的甜度略勝.
    原廠未改的那個還沒聽, 實在沒時間 :-)
    附記: Linn 的類比 Blog 裡 不少人覺得 Troika 比後繼的 Arkiv A/B 和 Akiva 更優
    Expert Stylus retip是用他最著名的Paratrace針尖嗎?
    網路上對Paratrace針尖的評價非常高. Decca reference就是用它.
    River的blog: 聲音的無上幻覺
    FB粉絲專頁: LIGHTIX
  5. The Following 2 Users Say Thank You to River For This Useful Post:
  6. #515
    是的.
    引用 作者: River 查看文章
  7. #516
    終於把第二個 LP 系統裝好了
    Linn LP12 + Ekos 2 Tonearm + Lingo 2 + Carbon Fiber sub-chassis + Linn T-Kable
    當初買來聽了幾天之後就收了好幾年
    一直的想法是弄一個難搞的經典(或是經典的難搞) 唱盤來玩個夠
    我的朋友 (是 Linn 經銷店) 稱它是 British Royal Pain, 大約是說 "皇家級的難搞".
    唱頭是 Lyra Argo
    唱放是 Jeff Rowland Cadence
    剛弄好, 聽了兩張唱片, 其實真的是不錯聽.
    還沒仔細跟參考盤 Brinkmann LaGrange 比較
    大略的印象是細節稍微少一些, 低頻下潛少一些也鬆一些.
    我換的 Carbon Fiber sub-chassis, 解決 LP 12 最被垢病的剛性問題, 據說音像會比較凝聚, 細節也會比較好, 不過有人說這就失去 LP12 原有的味道.
    我覺得蠻好聽的, 也蠻漂亮的.
    參考盤
    Brinkmann LaGrange + Graham Phantom 2 + Lyra Skala:
  8. The Following 8 Users Say Thank You to SGIREM463 For This Useful Post:
  9. #517
  10. #518
    終於把第二個 LP 系統裝好了
    當初買來聽了幾天之後就收了好幾年
    唱頭是 Lyra Argo
    我覺得蠻好聽的, 也蠻漂亮的.
    參考盤
    誠心建議,請將Target架的承板去掉。可將Linn12的底板也去掉直接在Target架的支撐架上面。這樣更能方便調整。而且聲音更能放開!Target架是尊為Linn12而設計製造。
  11. The Following 3 Users Say Thank You to philcoyuen For This Useful Post:
  12. #519
    終於把第二個 LP 系統裝好了
    當初買來聽了幾天之後就收了好幾年
    唱頭是 Lyra Argo
    我覺得蠻好聽的, 也蠻漂亮的.
    參考盤
    Argo 和Skala相對的在細節和頻寬有很大的差距
    相信同樣的唱頭LP12也能表現的很出色
  13. #520
