2011-05-27, 12:14 AM
#421
The world's most expensive phono stage?
26 May 2011
Some days we're inundated with stories about iPod docks, others it may be a rush of new Blu-ray players. Today it seems phono stages are all the rage.
Swiftly following on from news of a pair of phono preamps from Audio Research comes a release about the Aesthetix lo Eclipse making its UK debut.
Now if you thought the Audio Research pairing were expensive, at £3368 and £6298 respectively, hold on to your hats.
The Aesthetix lo Eclipse starts at £14,000, rising to an eye-watering £21,200 for the top model. Yikes.
"The Aesthetix lo is an all-valve phono stage suitable for the most demanding cartridges, including low-output moving coils," the company claims.
The casework is machined from aluminium billet and sits on four Harmonic Resolutions Systems' Nimbus Couplers (feet to you and me) specially made for Aesthetix.
You also get all-valve amplification (16 valves), a separate valve regulated power supply (8 valves), two sets of XLR and two sets of RCA outputs per channel, plus either RCA or XLR inputs. A second power supply is optional.
It even uses Stealth Technology. A new StealthCap by Peter Moncrief "dramatically reduces corrupting signal reflections in the capacitor plate, just as stealth technology in aircraft reduces radar signal reflections".
Aesthetix goes on to claim that the lo Eclipse "is designed and engineered to deliver the highest attainable sound from a turntable".
Sounds like a candidate for our Temptation section, or maybe a head-to-head with the Audio Research PH8.
The standard Aesthetix lo Eclipse with a single power supply costs £14,000. Add a second power supply and you'll shell out £18,500.
That still not enough? Then you can have the lo Eclipse with volume control and one power supply for £16,700, or with volume control and two power supplies for a range-topping £21,200.
2011-05-29, 11:49 PM
#422
Trans-Fi Salvation Turntable
Price - £2400
Featuring:
Slate plinth - 9kg Wide rim Aluminium platter.
- Inverted bearing, ceramic ball/Lignum Vitae thrustplate
- Direct Rim-drive/DC motor
- Interchangeable Drive Wheels for 33,45 & 78rpm
- Variable Rotary fine speed adjustment control
Preliminary listening tests show this deck to have more detail & pace than the Garrard 301/401 & Technics SP10 with a very low noise floor! Treble is very smooth & refined. Bass is thunderous! Spacious uncluttered presentation.
2011-06-01, 11:00 PM
#423
2萬片黑膠唱片 齊聚誠品
(中央社記者鄭景雯台北1日電)誠品音樂表示,「地下黑膠市集」16日將在誠品敦南店舉行,這次匯集多家黑膠唱片廠商及黑膠愛好者的收藏,現場展售近2萬片的黑膠唱片,是歷年來規模最大的黑膠市集。
誠品音樂表示,從2007年舉辦第1屆「黑膠文藝復興運動」,結合台灣黑膠唱片與硬體唱盤廠商,提供行家難得的交流機會,也帶動年輕族群聆聽黑膠唱片的風潮。
2010年則是首次在敦南誠品舉辦黑膠市集,更成為蒐藏玩家每年期待的規模盛事,讓許多音樂愛好者重新認識黑膠唱片。
今 年6月16日至26日誠品音樂則是擴大舉辦「地下黑膠市集」,匯集包括古碟唱片、亞德音響、音橋、再聲工場、美藝等多家黑膠唱片廠商,以及眾多黑膠達人的 珍貴收藏,音樂種類包括獨立搖滾、爵士、古典、華語、經典搖滾等,現場展售近2萬片的黑膠唱片,也是歷年以來規模最大的黑膠市集。
另外在19日、25日也將舉辦黑膠達人講座,帶領聽眾輕鬆進入黑膠的迷人世界。1000601
http://tw.news.yahoo.com/article/url...1/5/2skhs.html
2011-06-03, 12:58 AM
#424
BENZ MICRO RUBY Z MC唱頭
発売日 2011年6月
価格 ¥346,500(税込)
【SPEC】 ●形式:MCカートリッジ ●出力:0.34mV at 3.54cm/s ●インピーダンス:38Ω ●周波数特性:10~50,000Hz±1dB ●針圧:1.8~2.2g ●スタイラス:3μm/60μm 鏡面仕上げ ラインコンタクト・ダイヤモンド ●コイル:2×2mm スクエア・ルビー ●質量:10.7g
2011-06-05, 10:46 PM
#425
Audio Consulting Meteor MC Step Up Transformer
2011-06-12, 01:57 AM
#426
The Following 2 Users Say Thank You to Edgarhorns in LA For This Useful Post:
2011-06-15, 07:41 PM
#427
作者: 小葉
上周六在新宿RECOFAN看到這套.一時手癢差點買下去.
結帳時竟然忘記了.
今天想到......我如果買了會拿出來聽嗎?
The Following 2 Users Say Thank You to ericbw For This Useful Post:
2011-06-15, 08:08 PM
#428
2011-06-15, 08:45 PM
#429
2011-06-15, 10:49 PM
#430
