2010-06-09, 05:43 PM
#211
以前的我在調整唱盤尺規AB點都習慣由唱頭蓋上往下看!!但是好像都調不出個所以然~~(sweat)
後來調整都只注意唱頭前延的線是否水平對齊~~自己感覺好像好調些~~:o
2010-06-10, 03:38 AM
#212
THE NBS UNIVERSAL PHONO PRE AMPLIFIER
Sixty Five pounds of silence. Encased in ¼" solid copper, the phono pre amplifier is universal in several ways:
First, you can plug it in anywhere in the world with no adjustments. It has a universal AC mains input with power factor correction.
Second, you can use any pickup..from the lowest output moving-coil to the highest output moving-magnet type.
The solid copper chassis provides exceptional shielding and grounding. A generous grounding post is provided adjacent to the inputs. Not only that, the copper enclosure is also beautiful to look at.
The moving-coil input and the moving-magnet input can be connected simultaneously and selected from the front panel. Low and High moving coil gain can be selected from the front panel as can moving coil loading.
The input selector also has a Mute position for noisy operations like cleaning the stylus or making connections to the inputs.
Balanced and unbalanced outputs are provided and both can be used simultaneously.
For the serious LP connoisseur the proof is in the listening. This pre amp reveals your LP collection in a way that makes you want to rediscover it. This is due to a signal-to-noise ratio and signal headroom which greatly exceed what the disc and pickup can deliver. The pre amp will never be a limiting factor. Further, the accuracy of the RIAA equalisation is unmatched by any preamplifier of which we are aware. The equalization is true RIAA without the IEC low frequency rolloff. Turntables appropriate for use with the NBS preamp do not require it and the low frequency reproduction is much better without it.
Also, the so-called "Neumann" stop in the de-emphasis is not present. This prevents the output of ultrasonic "junk" and generally improves the clean quality of the signal.
Specifications:
Inputs: L&R Moving coil, RCA connectors
L&R Moving magnet, RCA connectors
Input loading: MC: 50,100,250, 500, 1000 Ohms
MM: 47K Ohms
Outputs: L&R balanced, XL connectors, Pin 2 Hot
L&R unbalanced, RCA connectors
Output loading: Balanced 600 Ohms or greater
Unbalanced: 600 Ohms or greater
Gain: MC Low: 60 dB at 1 kHz
MC High: 70 dB at 1 kHz
MM: 40 dB at 1 kHz
Mute: -100dB
Equivalent input noise: MC: 150 nV, 22Hz - 22 kHz, unwtd
Equalization: RIAA +/- <0.08dB
Power requirements: 85-265VAC, 50-60Hz, 15 Watts
Dimensions: 16"(406mm)D
17"(431mm)W
2.25"(57mm)H
Plus feet and cable clearance
Mass: App 65 lb (30Kg)
Supplied accessories: Custom NBS Mains cable
Price: $30,000.00
http://www.nbscables.com
2010-06-10, 09:52 AM
#213
2010-06-16, 11:08 AM
#214
SARAH MCLACHLAN/LAWS OF ILLUSION LP
Item Number: SONLP55367
Brand/Label/Format: *SONY LP*
Unit Price: $19.99
In Stock
Sarah McLachlan's First Studio Album Of Brand New Material In 7 Years!
Multi-platinum and Grammy-Award winning singer/songwriter Sarah McLachlan releases her first studio album of new material in 7 years entitled THE LAWS OF ILLUSION. The album includes the single "Loving You Is Easy".
The album was recorded in Montreal and Vancouver with Sarah’s longtime collaborator/producer Pierre Marchand.
A resident of Vancouver, Sarah performed at the opening ceremony for the 2009 Winter Olympics and wrote and recorded "One Dream," which was used as part of NBC's marketing campaign for the Vancouver Winter Olympics.
Since joining Arista in 1988, every one of Sarah McLachlan’s studio and live albums has been certified gold, platinum, or multi-platinum by the RIAA, starting with Touch (1988) and Solace (1991), both gold sellers.
Founded by McLachlan, The Lilith Fair is an historic all-women touring festival which has become one of the highest grossing touring festivals in the world. Between 1997-1999, Lilith Fair enjoyed over 2 million fans in attendance and over $10 million dollars raised for national and local women’s charities. Lilith Fair 2010 features performances by Mary J. Blige, Sheryl Crow, Kelly Clarkson, Erykah Badu, Sugarland, Heart, Norah Jones, Ke$ha, Corinne Bailey Rae, Loretta Lynn, Emmylou Harris, Tegan and Sara, and many more!
Features:
• Special Edition Vinyl LP
• Includes the single "Loving You Is Easy"
Selections:
1. Awakenings
2. Illusion of Bliss
3. Loving You Is Easy
4. Changes
5. Forgiveness
6. Rivers of Love
7. Love Come
8. Out of Tune
9. Heartbreak
10. Bring On the Wonder
http://www.elusivedisc.com/prodinfo....medium=special
2010-06-16, 11:38 AM
#215
團一下................................:)
2010-06-16, 11:44 AM
#216
2010-06-16, 03:19 PM
#217
瑞士Rowen MC 唱頭
2010-06-16, 03:25 PM
#218
ROWEN MC-06 MC cartridge
As the more cost-efficient solution this MC pick-up with excellent resolution quality and extraordinary high homogeneity truly enhances all music styles.
* MC system with elliptic diamond
* 0.4mV at 3.54cm/s, 20Ω
* Recommanded termination impedance: 200-1000Ω
2010-06-16, 03:37 PM
#219
2010-06-16, 03:39 PM
#220
ROWEN是一瑞士當地很發燒的牌子,一直沒時間做出口....
