第109頁,共158頁 第一第一 ... 95999107108109110111119 ... 最後最後
顯示結果從 1,081 到 1,090 共計 1578 條
  1. #1081
  2. #1082
  3. #1083
  4. #1084
    Langer No.7 Direct Drive Turntable
    使用最新的直接驅動技術。低噪音、晃動少、速度穩定。獨特的模擬驅動控制器發送平整及非常低的控制電壓到馬達上。
    轉盤的重量約為3公斤,優化過的質量對馬達和控制技術來說是最好的結果。固體的橡膠片增加了重量,並消除轉盤的共振。
    操作非常簡單且舒適。可選擇33或45轉。
    機體的設計有副底座。馬達、轉盤和唱臂被安裝在金屬板上。全金屬版本重達20公斤。完整的轉盤配有4組可調式金屬支架,以用在水平精確定位。
    可安裝使用種類繁多的9吋唱臂。採用特殊設計的轉盤。整合第三方唱臂時非常簡單。
    馬達是無刷設計。使用霍爾感應器和集成電子電路板傳達給線圈。為了平滑的馬達運作和消除失真這是必須的。所以沒有磁性休息點或耗損。在速度反饋上使用光學感應器。
    對於langer的馬達,設計了一個特殊的速度控制器。在正常的驅動下,馬達運作只會使精密軸承產生一點磨擦損失。並能增加驅動電流所需的水平,不再需要時間等待轉盤速度穩定和低晃動及低噪音。
    http://www.langer-audio.de/Page14.html
  5. #1085
    IKEDA SOUND LABS. - IKEDA SAI(彩)
    IKEDA SOUND LABS預計將在今年一月中旬後發佈最新唱頭MC唱頭IKEDA SAI,此唱頭為IKEDA-9 Musa U的後繼者。
    採用硬質天然木材、純銅和鋁製成,銅磁氣迴路。
    日幣售價:380,000
    以下為IKEDA-9 Musa U的規格:
    Type: MC phono cartridge with cantileverless
    Output Voltage: 0.17 mV (5cm/sec. 45 degree, 1 kHz)
    Internal Impedance: 3.0 ohms
    Stylus Force: 2 grams
    Stylus Tip: Special Oval
    Weight: 47 grams
    Remarks: Integrated Shell
    http://www.soleberry.net/cartridge.html
  6. #1086
    Teragaki-Labo 試作原型8號機。
  7. #1087
  9. #1088
    Simon Yorke Designs new S45 recordplayer
    Nominal Dimensions: 300 x 200 x 115mm. Nominal Weight: 10,5kg.
    The S45 is a recordplayer exclusively for 7” singles. It will not play 12” long-playing records, compact discs or oven-ready pizzas, just singles.
    It features just one speed, 45rpm, and an integrated tonearm specifically optimised for the playing of 7” discs. And it is all made by hand.
    The S45 is supplied complete with an appropriate mm cartridge such that, following a brief installation process, it needs only to be connected to any amplifier with a phono input to immediately enjoy your singles collection.
    The S45 was designed to celebrate the ‘single’ format and its golden age – mostly the 1960’s and 1970’s – with an architecture reflecting that epoch and its technologies, though realised through a lens of the 21st century.
    It will be produced in a strictly limited edition of exactly 100 pieces, each one individually signed and numbered by Simon Yorke and accompanied by a certificate of authenticity – making it a genuine Collectors Piece.
    Price: 2,500 euro (ex works, excluding sales taxes & shipping costs).
    Availability: exclusively from Simon Yorke.
    http://www.recordplayer.com
  10. #1089
  11. The Following 2 Users Say Thank You to Leo Yeh For This Useful Post:
  12. #1090
